24 Tundra 5th Wheel
Discussion in 'New Member Introductions' started by Wise River TUNDRA, Jun 20, 2025.
  1. Jun 20, 2025 at 11:40 AM
    Wise River TUNDRA
    Wise River TUNDRA [OP] New Member
    24 Tundra
    So read a prior thread but still confused a bit. Need 5th wheel hitch for my 24 Platinum 6.5 bed Tundra. Saw the one from B&W companion...does that require in the bed rails? Does it auto slide? Used to have a Pullrite autoslide for 2014 Tundra and it worked great, but they are not making them anymore for Tundra's. Also, don't get the turnover ball part...? does the hitch just attach to the turnover ball? Wasn't sure why would need both...help...
  2. Jun 21, 2025 at 4:28 AM
  3. Jun 21, 2025 at 4:45 AM
    The ol pull a 5th wheel with a half ton bit. Good luck sir, that thread linked above will help, also search, numerous threads have been created for this all containing some information that could be helpful. There’s a reason they don’t make a hitch for these trucks…..
  4. Jun 21, 2025 at 8:17 AM
    BIGUGLY
    Paul
    2018 Limited
    Can it be done, of course. Good idea, absolutely not.....unless it's some super light application.
    Tons of useful towing info here and Colorado TJ has been kind enough to grace us with amazing info on what you can and shouldn't ever do.
    Not to piss in your cheerios,
    Welcome
  5. Jun 22, 2025 at 6:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Jun 24, 2025 at 6:43 AM
    Wise River TUNDRA
    24 Tundra
  7. Jun 24, 2025 at 6:45 AM
    Wise River TUNDRA
    24 Tundra
    So I have pulled my half ton series Cougar 5th Wheel for over 8 years now, WITH my 2014 Tundra...so, not sure what the nay saying is all about. The 2024 has an even greater towing capacity, so just looking for useful ideas. Thanks
    sask3m likes this.
  8. Jun 24, 2025 at 8:28 AM
    The nay saying isn’t that the truck won’t do it. It’s that it’s not rated for it. That’s all. The short bed CM configuration also isn’t ideal for an over the axle bed mounted hitch, 5th wheel or gooseneck. The DC 6.5 is has the hitch and trailer sitting in a much better position and has more payload comparatively. Just rarely enough for the pin weight of a 5th wheel camper. Again, not usually rated for enough, not that they aren’t capable of more than they are rated for.
    ColoradoTJ likes this.
