23 SR- Tow/Haul mode?
Discussion in '3rd Gen Tundras (2022+)' started by Hawkeyenorth, Oct 19, 2023.
  1. Oct 19, 2023 at 2:53 AM
    Hawkeyenorth
    Hawkeyenorth [OP] New Member
    Earl
    2023 Tundra SR
    Just bought a 2023 Toyota SR. Is there a Tow/Haul mode? I don’t see a button, and it does not have the mode switch like a SR-5
  2. Oct 19, 2023 at 3:11 AM
  3. Oct 19, 2023 at 4:34 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Just put it in S10 mode, keeps the RPM a little higher before each gear shift. When towing a heavy trailer helps a lot.
  4. Oct 22, 2023 at 6:49 AM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    U-Haul sells Curt Heavy Duty and DrawTite Heavy Duty. I had them install hitch to a RAV4 without issue.
  5. Oct 22, 2023 at 7:16 AM
    Markysharky
    Markysharky New Member
    If towing on the heavier side I’d put it in s7. That will keep it out of overdrive gears <1.00 to keep the transmission temps down. If you’re towing a few thousand lbs on flat ground probably not necessary.
    Eurodriver, Woocawachie and chaztizer like this.
  6. Oct 22, 2023 at 9:14 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Check first with the dealer. Nothing like OEM. Your truck might have the trailer harness there and all you need is a pig tail to complete it.
    Nashtucky[QUOTED] likes this.
