22 TRD PRO wont start
Discussion in '3rd Gen Tundras (2022+)' started by Yotax109, Sep 17, 2022.
  1. Sep 17, 2022 at 9:27 PM
    Yotax109
    Yotax109 [OP] New Member
    Los Angeles
    08 SR5 Crewmax > 22 TRD PRO > 20 TRD PRO
    Picked the truck up yesterday. Dropped it off for some window tint today. Did all 4 windows, windshield and sunroof. The shop drove the car to the street and when I went to pick it up 20 min later, it wouldn’t start.
    All the electronics turn on, but the motor won’t turn over. All of the warning lights on the dash are on “hybrid system malfunction”, “check engine visit your dealer”, “secondary collision brake system malfunction” and the gas tank cover started to pop open.
    Heard the windshield tint might be the cause, but I also know people with 22 models who have tinted their windshield without issue.
    Have to wait until the dealers service department is open on Monday….
  2. Sep 17, 2022 at 9:35 PM
    Could they have drained the battery? Do you have a meter to check the voltage?
    BTBAKER, Yotax109[OP] and 4wd TRD PRO like this.
  3. Sep 17, 2022 at 9:49 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    The tint could be the cause? How does that work?
  4. Sep 17, 2022 at 9:53 PM
  5. Sep 17, 2022 at 10:02 PM
    NWPirate
    Zach
    WA
    Maybe the installer got a little wild with the spray bottle and fried something?
    That's a stretch but the only thing I can think of.
  6. Sep 17, 2022 at 10:07 PM
    Yotax109
    Los Angeles
    Thought maybe the battery was dead so they tried jumping it.
    A tech at Toyota said he’s seen tinting the windshield can cause issues with all the sensors new cars have. I have no idea. But I read on some forums that when people tint the windshield, excess water can drip down into the dash and cause problems. And things go back to normal once it’s all dried. Hopefully that’s it.
    Terndrerrr and AGTundra like this.
  7. Sep 17, 2022 at 10:44 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Did they tint the windshield for you?
    We use a soak rope wedged down in the firewall to hopefully soak up any water tryin to run down there …& also cover the entire dash with microfiber towel to protect it
    A lot of these new vehicles make me nervous but get asked constantly to tint them
    Hopefully you get it resolved
    Edit
    Just re-read that they did do the windshield
    Hopefully they used some of those precautions
  8. Sep 18, 2022 at 9:50 AM
    Yotax109
    Los Angeles
    Thanks man.
    Shop just told me they tried starting the truck and it’s completely dead now. Had to use the key to manually open the door.
    So maybe it’s a battery issue. They just told me they tried jumping it with one of those little portable jumpers yesterday. Gonna connect it to some actual cables today and see what happens. Fingers crossed!!!
  9. Sep 18, 2022 at 9:57 AM
    Retired...finally
    I have a Fiat 124 that's similar to the new Miata. Both Fiat and Mazda owners have electronic problems after window tinting. Something inside the door gets wet when the tint shop does the side windows. Knowing this my first guess is it's due to the tinting.
    doublethebass and Yotax109[OP] like this.
  10. Sep 18, 2022 at 11:33 AM
    Yotax109
    Los Angeles
    Jump starting it worked!!! The truck started but all of the system malfunction warnings are still going off.
    Hopefully as it dries out they go off. If not then I’ll remove the windshield tint and/or take it to the dealer tomorrow.
  11. Sep 18, 2022 at 3:59 PM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    I would wait for it to dry and then take it to the dealer. The physical tint itself should have no impact on this, although I guess the moisture theory is plausible. I tinted my truck all around a few weeks after I purchased it and have had no issues since then.
    Yotax109[QUOTED][OP] likes this.
  12. Sep 18, 2022 at 6:06 PM
    Yotax109
    Los Angeles
    Well drove the truck around for 40 min to charge it. Parked it for lunch and then it wouldn’t start again. Even with a jump. Had to tow it to the dealership so we’ll see what they say…..
  13. Sep 18, 2022 at 6:27 PM
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Dang.. super frustrating
  14. Sep 18, 2022 at 6:31 PM
    MBTraff
    MBTraff New Member
    Mine wouldn’t start as well at one point. 1974. Called the 1800 number. It’s possible the key isn’t paired with the truck. I tried my app and nothing as well. If you check the manual there’s a process to reset it. Something like hold it by the start button for 20 seconds…. worked for me. The person on the phone walked me through it. I’d try this before paying for a tow.
    I originally thought my key battery was dead but it wasn’t. good luck.
    Yotax109[OP] and RookieEP like this.
  15. Sep 18, 2022 at 7:07 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Yes. I know for a fact that on certain Mercedes cars you have to go as far as disconnecting a module in the trunk. When doing the back window water always falls on this module and fries it. Cost around $2k to replace I believe, expensive tint job if the installer doesn't know. Maybe its something different on the OPs truck but could be possible.
    Yotax109[OP] likes this.
  16. Sep 18, 2022 at 8:55 PM
    Yotax109
    Los Angeles
    Late night update- Pulled the windshield tint off before the dealer got it in the morning, and everything works now. Reset the battery and all of the system malfunction lights are gone. Started the truck 20 times to be sure and it fired up every time.
    For anyone wondering it was the almost clear (70% I think) ceramic tint. My friend with a limited off road tinted his windshield without issue. I’m not sure if the windshield on the Pro has different sensors or something but I’m glad it’s resolved.
    Thanks for the input everyone!
    T-Rex266, Sean492, AGTundra and 2 others like this.
  17. Sep 18, 2022 at 9:01 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    So it was just the tint that caused this, and not the water, or was it a combination? Thanks for the update.
  18. Sep 18, 2022 at 9:07 PM
    Tremor F-250, Roush Mustang, Jeep Crawler
    That is some good news!!!
  19. Sep 18, 2022 at 9:11 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Well they decides I won’t get the pro tinted
  20. Sep 18, 2022 at 9:19 PM
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    Wow - that is weird. I had a full tint including windshield with same 70% tint a little over a week ago. No issues on mine. It’s a platinum.
    Yotax109[OP] and chaztizer like this.
  21. Sep 19, 2022 at 5:14 AM
    chaztizer
    2023 Tundra TRD Pro
    See, I still feel like something is odd here. My Pro is tinted on all four side windows, the rear, the windshield, and the moonroof. No issues with my tint, so this is mystifying.
  22. Sep 19, 2022 at 5:32 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I would still ensure the dealership give it a once over…maybe at least pull the codes that went off and see if you get a clue as to what the issue was.
  23. Sep 19, 2022 at 5:40 AM
    xc_tc
    xc_tc New Member
    Seems ridiculous that the tint did it… truck start at night…
    The hybrid ECU sits somewhere behind the dash around the glovebox area. It’s possible water got there and shorted something temporarily, causing the hybrid fault and no start.
    Did the dealer find any codes?
  24. Sep 19, 2022 at 6:42 AM
    beminsi
    beminsi New Member
    '22 White Tundra TRD Pro
    I had ceramic tint put on my TRD Pro late last week. Immediately after I picked it up from the tint shop, my fuel door kept popping open on its own. I ended up having to pull the fuse for it. About 24 hours later I put the fuse back in and no issues since. Definitely think there is something to the theory about water getting places it shouldn't be and causing some (hopefully temporary) issues.
  25. Sep 19, 2022 at 8:48 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Is windshield tint put on the inside of the window??? If so, why?
  26. Sep 19, 2022 at 9:05 AM
    Yotax109
    Los Angeles
    My best guess is that it was the tint. The water seems more likely, but it’s so strange that it started as soon as the tint was removed. The likelihood that it dried up just enough as the tint was removed is slim, but I don’t know.
    The temperature on the dash also was not working when the tint was on.
  27. Sep 19, 2022 at 9:07 AM
    Yotax109
    Los Angeles
    I will DEFINITELY still take it to the dealer to see what they say. And I’ll let you guys know the results so nobody else has to deal with the same headache.
    The fuel door also happened to me. Replaced the fuse and is solved the problem.
    Tundrastruck91 likes this.
  28. Sep 19, 2022 at 9:09 AM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    Yes, it is on the inside. And the tint percentage is usually like 70-80% for a windshield, and really doesn't look tinted at all. The reasoning is for the ceramic films heat rejection.
    AGTundra likes this.
  29. Sep 19, 2022 at 11:33 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Tinted the windshield on my platinum...no issues
  30. Sep 19, 2022 at 12:59 PM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Hopefully its something simple but I wonder if some lights got switched on by accident as they were inside installing tint and that didn't drain the battery. Would be easy to do. Just not sure if you had it there overnight or just a few hours.
