22+ OEM Tonneau cover parts
Discussion in '3rd Gen Tundras (2022+)' started by atomic4877, May 9, 2024.
  1. May 9, 2024 at 6:08 PM
    atomic4877
    atomic4877 [OP] New Member
    2024 Toyota Tundra TRD PRO
    Looking at purchasing a second hand OEM tonneau cover. Can you purchase replacements for the foam block fillers that go under the rails near the cab? Looking for these ones: upload_2024-5-9_21-8-42.png
  2. May 10, 2024 at 2:17 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I wouldn’t worry about the foam. My dealer didn’t bother putting them back on after the recall fix. I think it’s meant to keep water out. If you are set on using the foam you can possibly use a piece of sponge. It just might do a better job.
  3. May 10, 2024 at 3:24 PM
    2301CC
    2301CC New Member
    23Tundra Platinum Hybrid
    Realtruck .com has a upgrade kit for the backflip mx4 for $19.99 it looks like it may have the block your looking for in the kit
  4. May 10, 2024 at 6:51 PM
    atomic4877
    Thank you, appreciate it all. I was able to get the blocks from the original seller, hoping to be able to use some heat to re-stick them, or use some double sided tape. I may use the real truck kit if that won’t work.
