22 Fan clutch failure
Discussion in '3rd Gen Tundras (2022+)' started by havasubud, Apr 5, 2024.
  1. Apr 5, 2024 at 7:45 AM
    havasubud
    havasubud [OP] Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Curious if anyone has had a fan clutch go bad. My 22 Limited, non hybrid sounds like a jet taking off. The fan clutch is staying engaged all the time. Happened one other time but only lasted a day and went away. Now doing it all of the time. Have close to 42k miles.
  2. Apr 5, 2024 at 2:37 PM
    mass-hole
    mass-hole New Member
    It can certainly happen, at least its not getting stuck unlocked so you dont get adequate cooling.
    Seems like a problem for a dealer to me on a truck in warranty. Although, being Toyota, they will probably tell you its a wear item and should be replaced at every oil change or something dumb.
  3. Nov 5, 2024 at 10:49 AM
    RedXRunner
    RedXRunner New Member
    Nate
    2022 Toyota Tundra TRD Sport
    Any updates on this? Mine started doing this. 50k miles.
