22 Engine Recall
Discussion in '3rd Gen Tundras (2022+)' started by Ted Browning, Feb 19, 2025.
  1. Feb 19, 2025 at 11:15 AM
    Ted Browning
    Ted Browning [OP] New Member
    Ted
    2007 Tundra SR5 XTra Cab, 2010 Tundra SR5 XTra Cab, 2020 Limited Crew Max TRD, 2022 Platinum Crew Mas
    Hello everyone. My '22 Platinum with just over 26K miles started surging so I took Toyota of Dallas up on their offer to give me a free loaner while my truck was getting retro'd with a new powerplant. Well, that was September 25 2024, and I'm still waiting to hear that they've got a engine for me. I inquire on a monthly basis and am told that they still don't have a remedy for my particular VIN; curious though, as a friend was shopping for a Tundra in Searcy, Arkansas and told me they have engines sitting on blocks waiting for candidate trucks. I called them, verified the engine availability, but when I gave the service tech my VIN, I was again told that 'they don't yet have a remedy'. What could be so different about my early '22, purchased in April '22, that Toyota has yet to provide a replacement???
  2. Feb 19, 2025 at 11:17 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    That's strange. I purchased my 2022 in March of 22 and just had my engine replaced last week.
    Ted Browning[OP] likes this.
  3. Feb 19, 2025 at 11:21 AM
    Ted Browning
    Ted
    Well hopefully, then, they're replacing in order of purchase date and mine will arrive shortly! Have you noticed any differences in engine performance?
  4. Feb 19, 2025 at 11:28 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The Toyota app will tell you if you’re motor is recalled.
  5. Feb 19, 2025 at 11:31 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    I haven't had a ton of time to drive it as I have a work truck I drive most of the time. But the short amount of time I did drive it the engine seemed to run a lot smoother and with less noise(ticking) than my original engine.
  6. Feb 19, 2025 at 11:42 AM
    AZBoatHauler
    So.Arizona
    Do you have a hybrid?
    KNABORES likes this.
  7. Feb 19, 2025 at 12:07 PM
    Ted Browning
    Ted
    No, straight 3.4 dual turbo v6. Definitely in the recall, but still NO REMEDY. I've been making payments for the last six months now with no truck to show for it. Granted, the engine isn't the only issue - rough down shifting at highway speeds, A/C must have a leak since it takes a loooong time to cool down, and the front passenger window regulator went out last spring and it took 6 weeks for the part to come in. During that time, the service tech had to tape the window in the up position to prevent it from dropping. Also had other numerous recalls, so it certainly makes a strong argument for not buying early models of new generation vehicles to give Toyota time to work out all the kinks. I know that the fact it was built during COVID didn't help matters either!
  8. Feb 19, 2025 at 12:11 PM
    Have you run your vin to see what it says? Build date? Recall status? At a minimum they should be short blocking your truck, or you have checked into lemon law for your state?
  9. Feb 19, 2025 at 12:14 PM
    Ted Browning
    Ted
    I'll need pointers to run the VIN. I've thought about the Texas Lemon Law and starting the process, but can't help but wonder if the dealership will attempt to hang the rental expense for the last 6 months on me if I go forward. I'd asked about just picking up the truck and driving it until it either crashes and burns or they contact me with an engine replacement, but was told I'd be responsible for the rental expense! Between a rock and a hard place doesn't seem to adequately explain things....
  10. Feb 19, 2025 at 12:17 PM
    22TXAG
    22TXAG New Member
    Dealers are performing this recall in stages depending on VIN so if you have a later build date they are prioritizing earlier builds first.
  11. Feb 19, 2025 at 12:30 PM
    Ted Browning
    Ted
    Logged in to Toyota.com and entered the VIN, only to be AGAIN be told that a remedy is not available. It didn't give me a build date, just a dealer reference number. No link to click to get further, more in-depth info on where my particular VIN sits in the process. When I spoke with the tech in Arkansas who has engines, she told me that it's the full engine complete with turbos. Who knows.....?
  12. Feb 19, 2025 at 1:08 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I think I would at least call another dealer, sounds like yours is just sitting on it.
  13. Feb 19, 2025 at 1:28 PM
    Ted Browning
    Ted
    That's my immediate suspicion, but the service tech in Arkansas ran my VIN and got the same response. They'd otherwise have been more than happy for me to bring my truck to their dealership and replace the engine but can't per Toyota. If JRiedy85 who bought his in March of '22 just had his engine replaced last week then maybe mine will be up in rotation soon.
    Raven67 likes this.
  14. Feb 19, 2025 at 2:21 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think I saw an estimated recall schedule from Toyota based on build date...somewhere. I even think they revised it once.
    Maybe someone could post that.
  15. Feb 19, 2025 at 2:24 PM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
  16. Feb 19, 2025 at 2:51 PM
    Ted Browning
    Ted
    Thanks for the info! Looks like my truck is in Phase 2 for engine replacements, though it's obviously slipped a month or so. I appreciate everyones help!
  17. Feb 19, 2025 at 3:06 PM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    What’s your loaner vehicle?
  18. Feb 19, 2025 at 3:17 PM
    Ted Browning
    Ted
    Toyota of Dallas had contracted with Hertz and they put me in 4 different vehicles, the last one being a 25 Dodge 2500 crew cab. Rode rougher than a old wooden wagon. I mentioned the discomfort vs my Tundra, and was informed by their contact person that they'd gotten so many complaints on Hertz that they transitioned over to Enterprise. They put me into a relatively new Tundra crew cab with 65K miles, but at least all of the controls are the same as my '22. Why do you ask?
  19. Feb 19, 2025 at 3:21 PM
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Just curious if they helped you with something similar for that time. Not saying that makes it right. I like the opportunity to drive different vehicles when renting etc. (don’t get one of those E jeeps). Sucks you don’t have your truck but one benefit is you’ll get it back with less miles I guess. Good luck getting it replaced! I’m in phase 4 I believe.
  20. Feb 19, 2025 at 4:09 PM
    JDAZ
    JDAZ New Member
    I thought they were prioritizing trucks that were broke down and waiting for engines. Toyota paying for a a loaner for 6 months seems kinda dumb as there are obviously trucks not broken down that are getting motors
    mrlittlejohn likes this.
  21. Feb 19, 2025 at 6:05 PM
    Ted Browning
    Ted
    True dat! I was told that the vehicles they had on hand that had broken down would get first dibs, and others would be FIFO.
  22. Feb 19, 2025 at 6:06 PM
    Ted Browning
    Ted
    BTW, they told me that if at any time I felt unsafe or that the engine was experiencing any of a number of symptoms, to bring it in and they'd keep me in a loaner for as long as it took.
    kirkb likes this.
  23. Feb 20, 2025 at 5:51 AM
    sudobash
    sudobash New Member
    Yaboy likes this.
  24. Feb 20, 2025 at 6:33 AM
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Intersting. Looks like my phase got pushed to July. Also of note is for those uncomfortable with possible failure with longer trips, from what I can tell you can just request a loaner now and until your Tundra is addressed.
  25. Feb 20, 2025 at 6:38 AM
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    That's what my dealer told me. I called a couple of weeks ago and they said they're currently only taking those that have broken down. However, what they said and what people have posted here don't exactly match up. There have been people who have posted here who mentioned getting a new engine without having broken down. Further, the other day I was chatting with a random guy at the store who mentioned he was in the process of having his swapped out - same year as mine, and he wasn't experiencing any issues. And, he was having the work done at the same dealer I had called! So, I just don't know what the truth is.
  26. Feb 20, 2025 at 7:08 AM
    Ted Browning
    Ted
    Unfortunate conflict on information. Let's hope our loyalty to the brand pays off, and sooner than later! This is our 5th Toyota, with my wifes 2017 Highlander being the only non-Tundra.
  27. Feb 20, 2025 at 10:00 AM
    2021 work truck
    2021 work truck New Member
    22 Tundra Crewmax 6.5
    33" Tires, Black Toyota Rims, TRD shocks
    My Truck is in the dealership getting the motor replaced as well as a few other items checked/hopefully replaced while still under the 36,000 mile warranty. My dealership reached out and I scheduled the appointment about three weeks ago and they ordered the engine for me. They had completed 4 when I scheduled. Hopefully they have enough experience to get it done properly without getting so comfortable that they rush.
  28. Feb 20, 2025 at 10:02 AM
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    What is your build date?
  29. Feb 20, 2025 at 8:25 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Nope, I would say nearly all the scheduled replacements are pulling motors that are running perfectly and getting scrapped. While guys like this are waiting. Seems like something only a tremendously large corporation could pull off.
  30. Feb 24, 2025 at 5:57 AM
    Talkin_Tundras
    ‘22 Tundra Limited
    3/22
