22’ Tundra recalled engine replacement leaking oil
Discussion in '3rd Gen Tundras (2022+)' started by Ultimatet, Sep 14, 2025 at 7:27 AM.
  1. Sep 14, 2025 at 7:27 AM
    Ultimatet
    Ultimatet [OP] New Member
    Tony
    2019 Tundra Limited TRD Off Rd
    2022 Tundra Limited Crewmax 4x4
    3.5” Lift 20” Fuel wheels 275/65/20 Michelin LTX AT
  2. Sep 14, 2025 at 7:37 AM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Not a lot of information here. The replacement engine is leaking? If so, were you able to identify where the leak is originating?
    My engine was also replaced under the recall in early June and I've put about 6k miles on it. So far it has been flawless. Fingers crossed it stays that way.. I change my own oil and did an oil change at 1k miles post replacement then another at 5k and didn't notice any fluids leaking anywhere. My original engine had what seemed like a very small oil leak from the rear main seal that never amounted to more than a wet bell housing on the transmission bottom. Never noticed a drop of oil in the garage either. Just enough that the wind would blow it back onto the bell housing and a cross-member behind the engine. That went on from about 500 miles to about 30k miles when the engine was replaced.
    GeoNeo likes this.
  3. Sep 14, 2025 at 8:23 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Is there a point to this post? Do you have a question? Are you just letting us know? Do your trucks specs have any relevance?
    help us out here.
  4. Sep 14, 2025 at 9:13 AM
    lapoolboy
    lapoolboy New Member
    Take it back to the dealer who did the work??? Unorthodox I know, but maybe start with that? :confused:
