21 TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by MannyR, Apr 18, 2024.
  1. Apr 18, 2024 at 12:57 PM
    MannyR
    MannyR [OP] New Member
    21 Tundra TRD Pro Lunar Rock
    I’m running Nitto Ridge Grapplers 275/65R18 what is the psi they should be at? Thanks for the feed back.
  2. Apr 18, 2024 at 12:58 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Do a chalk test
  3. Apr 18, 2024 at 1:44 PM
    MannyR
    I was debating on doing it but thought I would ask because I know a lot of people have probably done it already. So I was just trying to get some input.
  4. Apr 18, 2024 at 8:07 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Need more info if you want us to do the work for you...
    What load range are the tires??
    What is the weight of the vehicle in 'normal' configuration (people, dogs, other payload in the cab and bed, etc...)???
  5. Apr 18, 2024 at 10:51 PM
    MannyR
    Oh yeah forgot to add that, they are the 275/65R18 116T. Normal use some payload and some hauling not close to max just normal truck usage. 21 TRD pro Crewmax normal bed length and just my wife, my small dog and I daily for the most part.
  6. Apr 19, 2024 at 8:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is a great tool for getting air pressure in the ballpark when changing from stock size or load rating tires
