20x12 wheels on a 17 tundra
Discussion in 'Wheels & Tires' started by Dacfleming, Feb 17, 2021.
  1. Feb 17, 2021 at 2:33 PM
    Dacfleming
    Dacfleming [OP] New Member
    I got a 2017 tundra and I'm looking to put 20x12 on the truck. I was told by a tire shop that this won't fit on the truck. I see this is a common set up, although is any major cutting required? This truck is factory ride height. Sorry if this is repeated question
  2. Feb 17, 2021 at 2:39 PM
    GNTundra
    Gino
    2013 White
    Welcome to the forum. I run 20x12 -44 offset with 7" of lift. What kind of offset you looking at? Are you willing to lift your truck?
  3. Feb 17, 2021 at 2:45 PM
    Dacfleming
    I'm not looking to lift, if anything I'd like to lower some, so would a 20x12 -44 fit stock/lowered?
  4. Feb 17, 2021 at 4:16 PM
    Dacfleming
    I was thinking 305/55/20
  5. Feb 17, 2021 at 4:45 PM
    Dacfleming
    What would be an ideal set up then?
  6. Feb 17, 2021 at 5:49 PM
    Blazing Blue
    Blazing Blue New Member
    I don’t think they would fit without a lift.
  7. Feb 17, 2021 at 5:55 PM
    Blazing Blue
    I run 22x12 -51 on 3.5 lift aggressive bmc pinch weld and still rub at full turn.
  8. Feb 17, 2021 at 7:20 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    OP, there is a subforum on here called Wheels. These subforums are used to keep like minded posts together so they are easily found/read/browsed. . Welcome to the forum, remember to search first and good luck shoe shopping.:thumbsup:
    @Squatting Pigeon- should be moved.
  9. Feb 19, 2021 at 1:18 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I'm running a 20x12 wheel with a -44 offset, 305/50/20.......going to a 22x12 this spring with a 305/40/22
