2024 Differential/Transfer Case Washers
Discussion in '3rd Gen Tundras (2022+)' started by okk3n, Sep 16, 2024.
  1. Sep 16, 2024 at 5:08 PM
    okk3n
    okk3n [OP] New Member
    Need washers or the size of the washers for when I replace front/rear diff and transfer case fluids. Also if anyone knows the lbs to torque them too that would also be helpful!
  2. Sep 16, 2024 at 5:57 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
  3. Sep 16, 2024 at 6:13 PM
    okk3n
    Awesome! Thank you! Mind me asking where the heck you found the specs?!
    what kinda fluid did you use? I ordered Red Line synthetic D6 for the transfer case and Red Line synthetic 75w-85 GL-5 for the diffs.
  4. Sep 16, 2024 at 9:00 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    I got specs from Toyota TiS.
    For fluids I went with Toyota ATF WS for transfer case since it was pretty cheap, $12 per qt. I got amsoil 75w90 for both Diff since Toyota wanted $36 per qt for their 75w85
  5. Sep 16, 2024 at 9:11 PM
    okk3n
    wow that’s high! I only got the fluid I did because I had a 20% off code for o Riley’s and it saved me $48.
    Would you happen to remember the size sockets you used, etc? If you don’t mind typing it for me. I like having a list before going into doing this kinda work so I don’t spend 30mins trying to figure out what I need. Thanks!
  6. Sep 17, 2024 at 7:43 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    The front diff I used a 10mm Hex bit socket for drain and fill plug. Rear diff is a 24mm 6 point socket for drain and fill plug. Transfer case plug is a 3/8” ratchet.
  7. Sep 17, 2024 at 8:02 AM
    okk3n
    You have saved me so much headache. I tried finding this all on Toyota TiS but I must have looked in the wrong spot. Found fluid type/amounts but that was it.
    Thank you again!
    Tundrastruck91 likes this.
  8. May 29, 2025 at 8:11 AM
    buffaluphagus
    buffaluphagus —————————————
    Your suppose to replace the transfer case plugs as well?
