2023
Discussion in '3rd Gen Tundras (2022+)' started by Icy Tundra, Mar 10, 2023.
  1. Mar 10, 2023 at 3:38 PM
    Icy Tundra
    Icy Tundra [OP] New Member
    Has anyone installed a cold air intake? I’d like more turbo noice and an intake made a big difference on my wrx
  2. Mar 10, 2023 at 3:40 PM
    Efreet6669
    Efreet6669 New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    Not many out yet beyond A&E or something like that. Waiting for volant
    Skidmarcx likes this.
  3. Mar 10, 2023 at 3:47 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
  4. Mar 10, 2023 at 4:24 PM
    Breathing Borla
    Northern Illinois
    I don’t really think those things do much but make noise
    many dynos out there yet on one, maybe too early
  5. Mar 10, 2023 at 4:41 PM
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Just ordered these. But it will be a month or so before they ship.
    S&B Filters
  6. Mar 10, 2023 at 4:52 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    I'm kind of in the same boat, don't feel like there will be much measurable difference. The boxes on the ones available and likely all the ones to come are still pulling air from the same part of the engine compartment. How would that air be any cooler. The other argument is density/increased airflow from the larger filter. Which still doesn't seem like there would be any benefit unless the throttle is wide open at higher RPMs. Which we all know this vehicle doesn't really run at high RPMs. So considering that, the amount of airflow required where most of us run this is well below the handling capacity of the current filter. Not only that, but the throttle body is going to limit the amount of air let in regardless at that point. So your only advantage at that point is denser/cooler air which I don't see how you get with it located in the exact same spot pulling air from the same spot. Maybe someone smarter with actual diagnostic data for the current gen stock vs cold air intake can chime in.
    graf_von_tundra likes this.
  7. Mar 10, 2023 at 5:09 PM
    Efreet6669
    But you add a snorkel to the air box and they will breath. That’s why I’m waiting on volant or arb.
  8. Mar 10, 2023 at 5:19 PM
    Efreet6669
    So I’m a Boeing engineer, my job is air flow. Tell you wait till they can breath.
  9. Mar 10, 2023 at 5:27 PM
    Breathing Borla
    Northern Illinois
    another words, they don’t do shit, lol
    woohoo
  10. Mar 10, 2023 at 5:40 PM
    Don't get me wrong, they'll provide some improvement with other mods or accessories, but the ones listed and many others that come later won't make much difference. If you've got a snorkel or get the breather to a spot with cooler air coming in, you'll likely see some measurable improvement in gas milage, but probably wouldn't feel any difference in power. I saw a formulation once that showed you'd need a 60 degree drop in air temp to get a hp improvement of 0-5 hp. While that's an improvement, I'd be willing to bet no one on this forum could objectively feel a difference between 389hp and 394hp for iForce or 437hp vs 441hp for the hybrid.
  11. Mar 10, 2023 at 7:37 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    I got them for the turbo noise...love it paired with the BMS BOV plates
    Tundra Dude 45 likes this.
  12. Mar 10, 2023 at 7:51 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Those damn BMS spacer valves only make noise when the window is down.. Useless as hell
  13. Mar 11, 2023 at 3:00 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    The ("cold air" allegedly) intake boxes actually pull air from front quarter panels,some people have installed 1/4" galvanized screen between the box and quarter panel to prevent mice from entering and making a condo out of the filter box...
  14. Mar 11, 2023 at 5:14 AM
    Icy Tundra
    k&n makes a kit too but shows it out of stock. Maybe the drop ins are the way to go until there are more options in the market.
    my Subaru kit came with a box to separate the hot engine bay from the colder air and also makes it look stock
  15. Mar 11, 2023 at 6:12 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Couple of years back-2018??? on the 4Runner forum-same discussion. What does a CAI system really do? What are the improvements. So a 4Runner owner did a dyno run to find base, then installed TRD CAI and another Dyno run couple hours apart. Improvement was there and from memory was like 8 WHP and 16 FT Pounds of torque. MPG increase was negligible.
    The biggest increase was the noise from the engine in WOT = Sounded like a SC in the bay.
  16. Mar 11, 2023 at 6:22 AM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    How did you already order these? Did you call them and reserve a set?
  17. Mar 11, 2023 at 8:49 AM
    eddiefromcali
    Eddie
    100% Stock
    My windows were up in that vid, not sure what you're talking about
  18. Mar 11, 2023 at 9:45 AM
    chill_trd
    '22 TRD limited
    Local dealer I know that works with them called and placed an order.
  19. Mar 11, 2023 at 2:32 PM
    xc_tc
    xc_tc New Member
    Big difference for turbos vs naturally aspirated engines. A lot of turbo engines pull boost and timing when the air charge is hot. Keeping the air cold doesn’t really increase power but rather mitigates power loss when it’s hot.
    The intake from the fender that Toyota does on all trucks is not really a cold air intake though. Ford’s stock intake is a good example of a cold air intake because it takes air in right between the grill and the hood. Old WRX’s have a similar system.
