2023 tundra running board lights
Discussion in '3rd Gen Tundras (2022+)' started by drcuface, May 25, 2023.
  1. May 25, 2023 at 2:08 PM
    drcuface
    drcuface [OP] New Member
    Anyone know if we can tap into the interior fuses to wire a running board?
    or if we can tap into the tail light to turn it on when its running?
  2. May 25, 2023 at 4:10 PM
    drcuface
    can i tap into this 5a fuse to run the running board led strip only when we turn the headlight on?
  3. May 25, 2023 at 9:00 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Coming soon
    Hey never thought of that. I think would be really nice. Looking forward to seeing this mod. What type of lighting are you planing to use?
  4. May 25, 2023 at 9:24 PM
    drcuface
    I was going to use a running board light from Amazon. I was just going to tap into the puddle light and the fuse up front just wanting to see if this is the right fuse
  5. May 26, 2023 at 1:04 PM
    drcuface
    So I tapped into the interior fuses and the lights are now working I will write awrite up about it. I was able to tap int other dome cut light so when i open the doors the running board strip is white and tap into the extra accessory fuse so when i start the car the strip is on.
    AND likes this.
  6. May 26, 2023 at 3:20 PM
    drcuface
    Well Dome cut fuse always has constant power so when you tap into their the light is always on
  7. May 27, 2023 at 12:46 AM
    drcuface
    I got it to run while powering it to a fuse accessory. Not sure how to do it using puddle light
    RickyBobbysTundra likes this.
  8. May 27, 2023 at 3:38 AM
    TSS Army Green
    TSS Army Green New Member
    So the lights are always on when the truck is on?
  9. May 27, 2023 at 7:04 AM
    drcuface
    Yup it looks awesome. You could wire it to turn on when you open the car but i dont know how to remove my headliner without messing it up
