2020 1794
Discussion in 'New Member Introductions' started by haynes4u2, May 26, 2024.
  1. May 26, 2024 at 9:45 AM
    haynes4u2
    haynes4u2 [OP] New Member
    I just got a 2020 1794 and realized the bass sucks, I just want to replace the the sub for now which one do you recommend?
  2. May 26, 2024 at 11:02 AM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    I have this one
    https://www.amazon.com/Rockford-Fos...9c37fb34233e3e6a91e41c719ca0f206&gad_source=1
    I use a kicker zx1000.1 to power it. Fits great behind the passenger seat of my crewmax and I bought the additional grill to help protect it.
    https://www.amazon.com/Rockford-Pun...sprefix=rockford+fosgate+groll,aps,164&sr=8-2
    There’s also a guy named James who does tundra specific setups. He can work with you based on your needs but can be pricey.
    https://tech12volts.com/
    Edit: I also stuffed the enclosure with poly fill and that seems to have made it even better.
  3. May 26, 2024 at 11:29 AM
    haynes4u2
    So I will have to replace the amps that came with the Truck?
  4. May 26, 2024 at 12:36 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    I didn’t replace any amp I just added my kicker amp and spliced off of the subwoofer input and my kicker already has high level(speaker wire type) inputs on it.
    Otherwise you could get an amp that doesn’t have high level inputs and connect the spliced wires to a line out converter to clean up the signal and provide the input type you need.
    Previous to the 2020, the JBL amp could power a better sub all on its own and you could just replace the sub itself, but in 2020 and 2021 models the amp sub output has been neutered for whatever reason.
    Also I read here that splicing off of one of the door speakers would give better input to an amp for a subwoofer but I didn’t want to do that and run the wiring so I just spliced into the factory sub harness. It’s sounds good enough for me, at least for now.
  5. May 26, 2024 at 1:10 PM
    haynes4u2
    Thanks I will try that but I had a 2017 and it sounds better than the 2020
  6. May 26, 2024 at 1:38 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Just know that there’s a lot of options for upgrading your sound out there.
    Head units.
    Speaker upgrades.
    Amps that are plug and play with your factory cables.
    There aren’t too many subwoofer options though unfortunately.
    I wanted to keep my head unit for now as I don’t feel like throwing money at that as I’d rather buy a sway bar, FRAC front camera system, and other things I would prioritize over a different head unit.
    Also yes the overall consensus is that the previous JBL systems were better than the 2020-2021 so I can understand why you would feel that way about your 2017.
  7. May 27, 2024 at 8:54 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. May 27, 2024 at 2:29 PM
    Welcome from NY.
  9. May 27, 2024 at 2:39 PM
    haynes4u2
    thanks form Florida
