5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Nov 10, 2020 at 2:57 AM
    #121
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    For anyone not wanting to do the install I had a local shop do it for me. Install took them 2.5hrs and their labor rate is $88. The guy doing the install said it was super straight forward he just took his time because he didn't want to have to redo anything. Total cost $220
  2. Nov 10, 2020 at 6:30 AM
    #122
    Architect
    Architect New Member
    marc
    New Jersey
    2020 CMTRDPRO
    Hi Guys.. I received my trans cooler kit the other day.. Can't wait to install it.. I want thank Nick for setting this up.. My trans temps have been running around 200f here in the flat lands of Jersey (with no cooler).. Definitely a good idea if you are going to keep the truck for a while, IMHO... Thanks again, Nick.
  3. Nov 10, 2020 at 9:10 AM
    #123
    JWB
    JWB New Member
    2020 Tundra Limited TRD Off Rd
    TRD Exaust, Scanguage II, Tundra inserts for Tundra under radio, Husky X-Act w/Red Tundra inderts,TRD oil cap and Grey/Tundra center console insert
    Kit arrived!! Going on today. Will update this evening or tomorrow. Taking same route to and from work into DC (Hwy plus stop and go).
  4. Nov 10, 2020 at 10:29 AM
    #124
    Genuine Cooling Systems [OP] New Member Vendor
    For those about to install their kits, I updated the instructions a couple days ago to clear up a couple steps.
    Don't hesitate to shoot me a email if you have any questions.
    KC.Tundra likes this.
  5. Nov 10, 2020 at 10:47 AM
    #125
    BamaJoe
    BamaJoe New Member
    Joe
    2020 white Tundra Double Cab SR5 4wd
    I am installing my transmission kit. I am at the point of putting the Hayden in. I have this black looking wrap that I assume is to wrap the hose that goes behind the cooler for heat protection. Problem is with it wrapped around hose and trying put the orange clamp around it is impossible. Please advise. I am guessing now that I just clamp the hose and then cut this stuff and put in between.
  6. Nov 10, 2020 at 10:58 AM
    #126
    Do not clamp the hose with the spiral hose around it, it will not fit. After the hose is clamped with the Adel clamps slide the spiral hose protection around the portions in the picture below. The reason I include the spiral hose protection in the kit is to give piece of mind that the hose will not rub against the bracket and cause abrasion.
    JRock, Wallygator and GODZILLA like this.
  7. Nov 10, 2020 at 11:06 AM
    #127
    BamaJoe
    BamaJoe New Member
    Joe
    thanks Nick. Yeah I figured it wouldn’t fit. Just didn’t want to get to far and then have to take the cooler back off. Now to the finish line.
  8. Nov 10, 2020 at 11:44 AM
    #128
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    If you cut the hose correctly and tighten the fitting while maintaining the hose where you want it, the hose will not be close to rubbing anywhere.
  9. Nov 10, 2020 at 1:09 PM
    #129
    BamaJoe
    BamaJoe New Member
    Joe
    Almost finished. One more question. In the instructions where the hoses connect to the cooler. It looks like a plastic piece where the clamp is located. That will be my first picture. My last is what I have left. I think I can just push the in the connector to the hose clamp and I am done? Just asking. Sorry not sure if I am missing something.
  10. Nov 10, 2020 at 1:25 PM
    #130
    Saab95v6
    Saab95v6 New Member
    I have been thinking about doing this next year , but I don't tow anything . Always learn something from your videos .
    2020Platinum[QUOTED] likes this.
  11. Nov 10, 2020 at 1:26 PM
    #131
    Saab95v6
    Saab95v6 New Member
    Where about's are you located ?
  12. Nov 10, 2020 at 1:54 PM
    #132
    The fittings in the pictures are a different brand than what I provided with your kit. The fittings I have on my truck just have a rubber cap on the end and are just for looks. Slide a clamp on the hose and push the hose on the fitting (add a coating of atf inside the hose) than place the clamp over the fitting and snap in place.
    Wallygator and BamaJoe[QUOTED] like this.
  13. Nov 10, 2020 at 1:57 PM
    #133
    BamaJoe
    BamaJoe New Member
    Joe
    That’s what I thought Nick. I have OCD so I double and triple check everything and combined with the age and health issues I don’t accomplish anything fast.
  14. Nov 10, 2020 at 1:59 PM
    #134
    Joe, I private messaged you.
    BamaJoe[QUOTED] likes this.
  15. Nov 10, 2020 at 5:59 PM
    #135
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I’m still debating adding this to my 2020. I’d probably be doing the install myself. Would it be possible to install the thermostat last? My thinking is if I have everything but the thermostat installed I can drive it if needed. Once the thermostat piece goes on you have to finish or it’s undriveable
  16. Nov 10, 2020 at 6:17 PM
    #136
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    i too thought about going this route. my only concern would be dust and road debris (as minor as it would be, unless it rained - that could get messy) could get into the hardlines unless they were protected / sealed off somehow.
    expecting my kit to arrive later this week. was going to lay everything out on the table, re-read the instructions for the 50th time and then decide my plan for install.
    i am sure that i am overthinking this, but i like to have a game plan before starting any project, no matter how large or small.
    believe it or not, checking the final level after completion is really my only concern. i do have the veepeak odb / fusion app w/ upgraded $10 toyota package. confident in my ability to properly check temp.
    now that patrick has stated that he'll be doing an install vid soon. i may wait another week or two check out his install prior to performing my own.
    Wallygator and Doxiedad[QUOTED] like this.
  17. Nov 10, 2020 at 6:22 PM
    #137
    Doxiedad
    James
    Charleston, SC
    Yeah if I had to drive it i would tape up the ends to keep crap out.
    Jtundra81 likes this.
  18. Nov 10, 2020 at 6:37 PM
    #138
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks for the feedback, glad to know the videos are helping!
    my kit is scheduled to be delivered Thursday, I have several guys waiting for the install so I’ll get it done asap, I’m shooting to hopefully have video live on the channel by Sunday at latest!...thanks for the support guys!
  19. Nov 10, 2020 at 6:40 PM
    #139
    shackleford rusty
    TEXAS!
    :yes: with a side of :headbang:
  20. Nov 10, 2020 at 7:01 PM
    #140
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    I would install everything and just have dealer hook up thermostat and adjust oil level. I don't wanna mess up a 6000$ transmission
  21. Nov 11, 2020 at 5:27 AM
    #141
    Lake.Life24
    Shawn
    Upstate, NY
    Upstate NY about 15 minutes from the NY / PA border
    Saab95v6[QUOTED] likes this.
  22. Nov 11, 2020 at 5:34 AM
    #142
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Why would you trust a dealer to do trans fill. It just isn't that hard. park on level, have temperature between 99 and 111F when slow stream level is correct. Even if you added zero transmission fluid it wouldn't mess up transmission. Truth be told add 3/4 quart your done. You are well within spec. thing holds 13 quarts? I did mine and it took 5/8 of a quart. We are installing the identical system. When you remove the spacer plate very little drips out, enough to lube your hose connections. then you have the rubber hoses and cooler. So if you want add the volumes up or just add 3/4 quart. I installed 1.5 quarts, and .75quarts drained out when setting the level. I had to back truck down driveway and drive back into garage and thermostat was pinned open so that should have purged all air out before I checked.
  23. Nov 12, 2020 at 1:53 PM
    #143
    JWB
    JWB New Member
    Kit on my 2020 CR Limited. Went for a solid 40 minute ride with 70/30 Hwy/stop and go. Convertor never got over 220 and pan stayed between 185-188. Well done Nick!
    jetfishn, Wallygator, rebmo and 2 others like this.
  24. Nov 12, 2020 at 3:41 PM
    #144
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    Now I am questioning myself. I put the level on my actual pan, not the frame of the truck, due to it sitting angled down on one end. Had the pan perfectly level. Truck was not level.
  25. Nov 12, 2020 at 3:46 PM
    #145
    Redcon41318
    Redcon41318 New Member
    If i am keeping my tundra I will have to purchase
    This kit. To the OP poster, how does your product compete against if i were to take my tundra to a dealership and they agree “to install a kit in my tundra?”
    ref #23,41 my literature what do those
    Numbers mean? Why are they all different when indicating a
    Hot tranny?
    betotundra likes this.
  26. Nov 12, 2020 at 4:21 PM
    #146
    betotundra
    betotundra Toyota for Life
    Interesting.
  27. Nov 12, 2020 at 4:29 PM
    #147
    Redcon41318
    So do some trucks
    Have diff standards of overheating? This manual was when i was in my army
    Days as a truck driver.
  28. Nov 12, 2020 at 4:45 PM
    #148
    2020Platinum
    Patrick
    Northeast PA
    Well UPS sucks, original delivery date was today, now it’s Tuesday??? :mad:
  29. Nov 12, 2020 at 4:52 PM
    #149
    shackleford rusty
    TEXAS!
    secondeded about ups... my original delivery date was Friday (would have been perfect for a nice cool weekend install). now it's monday.
    i will see your :mad: and raise you :rant::rant::rant:
    an alternative & positive outlook... it'll sure look nice laid out on my dining table as the centerpiece...
  30. Nov 12, 2020 at 6:29 PM
    #150
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The guy on the couch in your screen grab looks very happy and satisfied.
    What gives? Have you tried upgrading to Premium?
