5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Nov 13, 2021 at 9:08 AM
    #1141
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    For installation of the setrabusa 15 row the instructions say the following.
    with the orientation of the thermostat inlet/outlet it makes flow through the cooler go in at bottom of cooler, out at the top going back to the thermostat.
    Is the correct?? Seems like flow through cooler should be top to bottom?
  2. Nov 13, 2021 at 9:49 AM
    #1142
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I though the same when installing mine. I believe bottom to top helps ensure there is no air trapped in the system.
    GODZILLA and SSPey like this.
  3. Nov 13, 2021 at 9:57 AM
    #1143
    OGDark Knight
    Jeff
    Thats a good point. Any other thoughts?
  4. Nov 13, 2021 at 10:15 AM
    #1144
    pursuit2550
    pursuit2550 New Member
    I did my own system and messed up on the line, kinda. It’s been long argued that air gets trapped. Some say trans oil pressure will always push out any air some say it doesn’t. I noticed to late and had all my lines hooked up. I used a temp gun and the temp through out the whole cooler was as it should be. Hot on the inlet and cooler as it reached the outlet. I am OCD and will eventually buy more hose and reroute it but top or bottom I think is a moot point. Also the system doesn’t stay pressurized when you shut off the truck so there will always be air pockets till pressure builds back up.
    Dsptundra[QUOTED] likes this.
  5. Nov 13, 2021 at 10:47 AM
    #1145
    a_double
    a_double New Member
    MHX documentation states the inlet is on the bottom.
    EDIT: when the heat exchanger is oriented horizontally.
  6. Nov 13, 2021 at 10:59 AM
    #1146
    OGDark Knight
    Jeff
    Thanks for the reassurance.
  7. Nov 14, 2021 at 6:03 AM
    #1147
    OGDark Knight
    Jeff
    Install tip:
    When fitting the 3/8” lines to the hard lines up front, use a q-tip to coat the inside of the rubber hose with ATF and get the rubber line started onto the hard line. Once started use a heat gun to heat the line which makes it more flexible. Once the line is warm, use a twisting motion to push the rubber line onto the hard lines without so much fuss.
  8. Nov 14, 2021 at 6:07 PM
    #1148
    BrianH
    BrianH New Member
    2019 Tundra
    7" BDS Lift, Transmission cooler install
    I installed the kit a few days ago with one of my friends. I called around to two dealerships as well as an independent shop and no one wanted to install it, glad that happened b/c it really is pretty straightforward and I saved myself some money.
    So for the install, having a second set of hands makes the install go much easier. The guy that made the you tube video of the install did a phenomenal job and its well worth the watch.
    A couple things we did when installing it was to put the "coolant in" and "coolant out" hoses on the thermostat before installing it. The hard lines were pretty easy to snake into place with two people, and once you get it in place all the bends on the lines make sense. To get the rubber hose onto the hard lines we put a little ATF in the rubber hose and I pushed them with a slight twisting motion onto the hard lines from the top of the engine while my friend held the hard line in place from under the truck. I got the MHX radiator with the plumbing on the side, so we hooked up the lower port first, held the radiator in a vertical orientation, filled the radiator with ATF, then secured the line to the upper port. Was quicker to get the ATF fluid in this way vs pumping it in from the quart bottle under the truck.We then attached the radiator/bracket assembly to the truck. Again, much easier to do with a two person install.
    I chose to keep the thermostat pinned and have been monitoring the pan temperature for the last few days. I don't think its gone over 170 even when really pushing the truck. I drive on the beach, have a lift kit with 35's, and have had the transmission high temp light come on about 7 or 8 times over the last two years. Of course the service advisor blamed the lift and larger tires, but I had a 2011 Tundra with the same lift and tires and never had the transmission high temp light come on in the 8 years I drove it on the beach.
    I'm getting the transmission serviced in the morning tomorrow, so I am interested to see if they say anything to me about the install. I hope the tips help, and thanks Nick for putting together a great kit at a great price!
  9. Nov 14, 2021 at 6:25 PM
    #1149
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Let us know if the dealer says anything about the cooler setup. Would be interested to know if they care about it
    Mike59 likes this.
  10. Nov 15, 2021 at 5:17 PM
    #1150
    BrianH
    BrianH New Member
    2019 Tundra
    The service advisor I had today actually acknowledged that Toyota did omit the transmission fluid cooler in the new Tundras. I was actually shocked they did. They also agreed that it was a good mod to install, and didn't understand why Toyota got rid of it in the first place. Now only if we could get Toyota to reimburse us for the cost of the kit!
    Kung, Jtundra81, FISHN43 and 2 others like this.
  11. Nov 16, 2021 at 8:51 AM
    #1151
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    As far as accessing some of the more difficult to reach fasteners: any tips or special tools recommended?
  12. Nov 16, 2021 at 10:06 AM
    #1152
    Chip_Tundra
    Chip_Tundra New Member
    Sockets with u-joints, ratcheting combo wrenches, long nose pliers for the clamps. The thermostat bolts don't require too much torque, so just get them snug with an extra 1/4 turn.
    I used a slim long reach combo wrench to fasten the hardline mounting point on the engine block near the transmission. U joint with socket, ratcheting socket wrench and extension for the front mounting point.
    The thermostat required a socket wrench to break the bolts loose, then I used a ratcheting combo wrench to fasten the thermostat after getting the bolts hand tight.
    DZ_[QUOTED] likes this.
  13. Nov 20, 2021 at 5:46 AM
    #1153
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    I plan on installing the cooler and hardlines tomorrow. I will cap the hardlines at the transmission end to keep dirt out. I will do the thermostat and fluid at a later time. I have access to a lift for a few hours tomorrow.
    Mike59 likes this.
  14. Nov 20, 2021 at 12:59 PM
    #1154
    Genuine Cooling Systems [OP] New Member Vendor
    That looks great!
  15. Nov 20, 2021 at 1:02 PM
    #1155
    I have decided to not add the MHX-514 cooler to the line up of kits available for the 2019-2021 Tundra. Improved Racing has upped the price of this cooler from $299 to $349 and that does not include the brackets which will make the price of the kit more unreasonable for most. The only option going forward will be the Setrab 15-Row kit.
  16. Nov 20, 2021 at 3:07 PM
    #1156
    I’m looking for a YouTuber willing to make a quality install video for the Setrab 15-Row kit. This person will receive a kit free of charge. Please email me if you or someone you know would like to do this.
    Email: genuinecoolingsystems@gmail.com
  17. Nov 21, 2021 at 2:38 PM
    #1157
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Installed cooler and hardlines today. Also installed tubing from cooler to hardlines. Heat gun does make the soft tubing go on the hardlines easier. I take it the second ridge on the hardlines are a stop for the soft tubing to go against? It seemed pointless to slide the tubing over the second crimp?
    diablodalton likes this.
  18. Nov 21, 2021 at 3:58 PM
    #1158
    OGDark Knight
    Jeff
    Correct. Stop at second nub. The goal is to cover most/all of the non-painted area then the hose clamp goes between the two nubs.
  19. Nov 21, 2021 at 6:54 PM
    #1159
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    I know a Dark Knight from The OG
    Interesting SN coincidence?
  20. Nov 22, 2021 at 4:40 AM
    #1160
    OGDark Knight
    Jeff
    Dark knight was my SN across tacoma world and 4runners since about 2008. When i got to Tundras it was taken so its OG Dark knight over here.
    Pig Rig likes this.
  21. Nov 22, 2021 at 2:31 PM
    #1161
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Completed install today. All went well. Toyota rubber lines went on fairly easy between thermostat and hard lines. I lubed with trans fluid and slid them on to the hardline first. I did color code all hoses and hardlines. Red going from thermostat to cooler and blue from cooler back to thermostat. helped when putting everything together while working under the truck. I'm glad I did the install. I was a bit hesitant at first but it really was not that bad. Just take your time and triple check all your work. I would say I got a little over a pint of fluid back doing the trans fluid check.
  22. Nov 22, 2021 at 5:25 PM
    #1162
    charliebison
    charliebison New Member
    Attached is the acceptable temperature range image Toyota emailed to me. Needless to say, mine was operating well above these numbers so I installed the Setrab kit. Not trying to start a debate, I’m just saying Toyota gave me the info that pushed me to install this kit—and it works awesome.
    Chip_Tundra likes this.
  23. Nov 22, 2021 at 5:32 PM
    #1163
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
    I had my eye on this kit as I’m planning to add a magnusson supercharger in the next year or so. Will the setrab kit work with the magnusson?
    Thanks!
  24. Nov 22, 2021 at 6:16 PM
    #1164
    DZ_
    DZ_ New Member
    Frederick Co., MD
    With the Setrab 15, how much space is between the heat exchanger and the bumper cover support rail? Seems like it might be rather close?
    Also - fair to say most behind-the-grille light bar kits would be in conflict with these cooler kits?
  25. Nov 22, 2021 at 6:38 PM
    #1165
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    I think it is rather close. I will try to look tomorrow.
  26. Nov 22, 2021 at 8:59 PM
    #1166
    It’s about 2 inches. I don’t know if any behind the grill light bar kits that would work with either kit.
  27. Nov 23, 2021 at 10:51 AM
    #1167
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Thanks. Could you post a top view photo? I'd like to make sure there is adequate clearance. Wouldn't want a minor fender-bender to puncture the HX. It just looks very close from the perspective of this photo:
  28. Nov 23, 2021 at 10:58 AM
    #1168
    OGDark Knight
    Jeff
    2” is 2”
    but… my wife thinks we live in a 5000sqft mansion
  29. Nov 23, 2021 at 11:15 PM
    #1169
    I currently don’t have the Setrab cooler installed. I’m sure a someone who is installing their unit could chime in. I wouldn’t worry, though. This cross member only supports the grill, the actual bumper is about a foot below that.
  30. Nov 24, 2021 at 4:02 AM
    #1170
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
