2017 Tundra Tow Plug - no tail lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by laltaffer, Jan 9, 2021.
  1. Jan 9, 2021 at 12:02 PM
    laltaffer
    laltaffer [OP] New Member
    So maybe my memory is wrong but using the 4pin connector I would swear that I used to get taillights working on my trailer - currently only brake and turn signals are working.
    To troubleshoot I bought a tester, and then bought a new 7/4pin plug. An OEM part. But still no tail lights when I connect the trailer and turn on my lights. My truck tail lights work, but seems like the signal isn't being passed down through the plug.
    Any ideas? Anything I should check? Do I just go to a dealer now?
    I don't like doing long trips with the trailer knowing the tail lights aren't working.
  2. Jan 9, 2021 at 12:12 PM
    AZBoatHauler
    So.Arizona
    See if you have voltage with your headlights on at the 11 o’clock pin on the 7 pin connection. Or the pin that feeds the brown wire on the 4 pin.
    ETA if you’re under warranty the dealer is a fine choice as well.
    laltaffer[OP] likes this.
  3. Jan 9, 2021 at 12:18 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Check your fuses too in case you have not.
  4. Jan 9, 2021 at 12:19 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Having this same issue as well with my 6x10. They worked initially, but in the past 3 months have gone out. I can't track down the issue. Don't think it's a trailer issue as it is only a year old. Brakes/turn signals work just no running lights on the trailer. Haven't gotten around to testing the voltage at the truck's connector.
  5. Jan 9, 2021 at 12:23 PM
    laltaffer
    I'll check those items. One thing I should mention is that I started this DIY fix by fully re-wiring my trailer since it had been through a lot and it was easy enough. But it didn't change anything. I'll check the fuses in a few minutes, but don't have a way to check voltage right now. Will look to see how I might be able to get that done
  6. Jan 9, 2021 at 12:27 PM
    AZBoatHauler
    So.Arizona
    This
    Katzco Voltage Continuity and Current Tester - 6-12 V DC - 24 V AC Circuit - Heavy Duty - Long Probe Tester With Indicator Light - 54 Inch Cord for Low Voltage Systems, Cars, Live Wires, Fuses https://www.amazon.com/dp/B01BGZ9XRS/ref=cm_sw_r_cp_api_glc_fabc_EgH-FbQVX5NXM
    or one of these
    AstroAI Digital Multimeter with Ohm Volt Amp and Diode Voltage Tester Meter Continuity Test (Dual Fused for Anti-Burn) https://www.amazon.com/dp/B01ISAMUA6/ref=cm_sw_r_cp_api_glc_fabc_zfH-Fb3N0382M
  7. Jan 9, 2021 at 12:31 PM
    laltaffer
    Thanks!
