2016 Tundra w/ 75k miles and transfer case failure.
Discussion in '2.5 Gen Tundras (2014-2021)' started by goodfight, Jun 6, 2023.
  1. Jun 6, 2023 at 3:19 PM
    goodfight
    goodfight [OP] New Member
    Hi guys,
    Looking for some insight.
    I bought a 2016 tundra double cab with 71k miles 7 months ago. 4x4 worked fine when tested.
    Used it once for the beach a month ago with no issues. Used it again last week for the beach with no problem until leaving. Tried to switch back to 2wd and it would not get out of 4hi. I would eventually get it out of 4lo to 4hi with some switching around and messing around. In the process, going from neutral to drive would have some major grinding. Eventually was able to get it to 2wd and drove home without any issues.
    few days later I wanted to try 4x4 at home to see if it was a fluke. I ended up getting stuck in 4hi.
    I ended up taking it to the dealer last Wednesday in 4hi. They told me it was the transfer case actuator, a 2000 dollar repair. They replaced it that next day, Thursday. One cycle it worked but then would not go in and out of gear. They kept it for a few more days, eventually draining the transfer case fluid and seeing metal and said something was binding and that they couldn’t move it by hand.
    Today I was told it was a total transfer case failure, which is very rare and they’ve almost never seen. They quoted me for 4900 for the entire job. I went down and spoke to them and got the price down to 4400.
    I called a local mechanic and they quoted me to do the job for 4200.
    so I told the dealer to just do it but It’s just not sitting right with me. It only has 75k miles. The new transfer case will be brand new and have a 1 year warranty but money is tight right now.
    I understand I could buy a used one online but I feel that I am playing with fire there and it could possibly happen again. I felt safer going new at this point.
    what if they mis diagnosed that? What if it wasn’t the transfer case or actuator?
    anyone ever hear of this? Any suggestions or advice? I basically already told them and I think they ordered it but it will take 2-3 days to deliver.
  2. Jun 6, 2023 at 3:33 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Replacing the actuator requires splitting the transfer case, if I recall correctly, so there's a chance they killed it reassembling Incorrectly. Hmm.
    Backslider likes this.
  3. Jun 6, 2023 at 3:34 PM
    goodfight
    So, they said for the newer (2016) they do not need to split the transfer case and that it was true for the older models. I thought they maybe damaged the transfer case by not actually opening it?
  4. Jun 6, 2023 at 9:18 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have never heard of this before, but it’s awesome. So, before I go down the rabbit hole here for my own edification, does this add the lever through the floor like my old Chevy trucks from the 90’s?
  5. Jun 6, 2023 at 9:29 PM
    I would not spend that kind of money on your truck. Buy a good used one with a warranty for under 1000.00
    ZappBrannigan likes this.
  6. Jun 6, 2023 at 9:32 PM
    Yes, unless you opt for the cable shifters and then mount the transfer case levers where you want (within reason).
    ZappBrannigan[QUOTED] likes this.
  7. Jun 6, 2023 at 9:34 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    For $4k you can get a Torsen from LX570/Sequoia and have a full time 4WD.
  8. Jun 6, 2023 at 10:24 PM
    blenton
    blenton New Member
    I haven't heard of this happening, either, but I wonder if it had to do with shifting between D an N while trying to get out of 4Lo and the associated grinding that you heard. Either way, that's a bummer. The transfer case encoder getting fouled up is plausible - did they keep the part for you to inspect? Sometimes they get water in them and seize up.
    I'd ask them for the new actuator, find a used t-case, and swap the new actuator to the new t-case. You've already paid for the actuator, after all. Installing a transfer case isn't horribly difficult or particularly time consuming, but much easier for a mechanic.
    ColoradoTJ likes this.
  9. Jun 7, 2023 at 5:23 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I think this only works for the 2007-2013 trucks…
    texasrho83 likes this.
  10. Dec 18, 2023 at 6:34 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I'm a little late, but just had my Transfer case fail as well. also a 2016 83K miles
  11. Dec 18, 2023 at 7:02 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Out of curiosity, how it failed?
  12. Dec 18, 2023 at 7:30 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Once fixed you should get another 200 to 300k miles out of the truck, with proper maintenance. If you average that price out 10 years of ownership, it is small. If you plan on selling or trading it in 3 years, it hurts but you have no choice now.
    Friend of mine just dropped over $5,000 in a transmission rebuild in his near 300,000 mile Nissan Titan because it is paid for and he says he doesn't want to drop $60,000 or more to replace it. He expects to get another 200,000 miles out of it.
  13. Dec 18, 2023 at 7:57 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I’m not sure the math pencils out on a 300k Nissan product, but I wish him the best of luck. I would say he got his monies worth out of it.
    cmiles97[QUOTED] likes this.
  14. Dec 18, 2023 at 8:15 AM
    cmiles97
    cmiles97 New Member
    XP package
    In his words, "I know the maintenance on this truck and $5k is cheaper than $60k. I can do quite a few repairs for $60k". The math only works when you want to replace it. Plus at crazy high new truck prices with the crappy interest rates. that $5k is recovered in 5 months of new truck payments.
    He is still amazed at folks thinking they got a deal when they pay MSRP at $70,000.
  15. Dec 18, 2023 at 8:35 AM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    I think the Titan and Frontier are pretty well regarded for their reliability, at least among their own circles. On the other hand, Nissan cars/suvs with CVT transmissions are notorious for transmission failures at low mileage.
    cmiles97 likes this.
