2015 Navigation System/Entertainment Thingy. Any Joy with This?
Discussion in 'Audio & Video' started by 7.62Tundra, Sep 2, 2019.
  1. Sep 2, 2019 at 3:06 PM
    7.62Tundra
    7.62Tundra [OP] Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Hi again, I see a lot about mechanical and fun stuff here. But I'm wondering is the Nav system anything to really spectacular that I'm missing out on. I use Waze for nav and listen to AM radio talk shows on long drives. I'm fairly tech savvy but over the years it bores me after having do it for a living. TIA
  2. Sep 2, 2019 at 3:17 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I couldn’t stand the regular radio with the scout app navigation. I “upgraded” to a stock unit with integrated navigation and like it much much better. But most upgrade by going aftermarket. Apple CarPlay, dvd, etc......possibilities are limitless. I mostly do Spotify, local radio and waze. I will eventually upgrade speakers and way down the road maybe get a new head unit.
  3. Sep 2, 2019 at 3:24 PM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    I use my iPhone XR when I need to access a map quickly. I found the scout connected-navigation app to be atrocious and didn't find the integrated entune navigation much better (aside from not having to run an app on my iPhone). Aftermarket with carplay/android auto is the way to go, IMO.
  4. Sep 2, 2019 at 5:47 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Thanks I'll research. Would be nice to use the screen to run an app instead of playing around on a phone. The after market sounds interesting.
  5. Sep 2, 2019 at 6:34 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    I bought the Kenwood DMX7706S from Crutchfield with the most expensive harness and ready harness service. Works like a dream, has carplay/auto and improve stock speaker sound dramatically. Also now have access to OBD car reading info like engine temp, transmission, electronic speedo and rev counter, list goes on.
    NewImprovedRon likes this.
  6. Sep 2, 2019 at 6:46 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Cool. Does it fit in the existing dash set up?
  7. Sep 2, 2019 at 6:51 PM
    cnoyes72
    cnoyes72 New Member
    CT
    Crutchfield sells everything you need to mount the head unit, including replacement dash trim and the steering wheel control adapter. Simply input your make/model/year/trim level.
  8. Sep 2, 2019 at 7:03 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Mighty nice. Looks like I need the full monty and add $220. This is the only vehicle that I actually use the back up camera.
  9. Sep 2, 2019 at 7:06 PM
    Corpus Christi, TX
    They currently have a rebate for Kenwood purchases right now...
  10. Sep 3, 2019 at 2:31 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Thanks for the input so far out there. Do you have to pay for Apple car play? Is it an app that you load on your phone with a monthly fee? TIA and please excuse my lack of knowledge. I'm sorta of not that much into gadgets anymore as I'm getting close to 60.
  11. Sep 3, 2019 at 5:09 PM
    Corpus Christi, TX
    It should be a free app download from your app store.
    You just plug your lightning cable charger into the radios usb port and it should come up on the radio screen
  12. Sep 3, 2019 at 5:38 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Will do. I'll do the install. Just don't want to be scratching my head anymore. I have an associates in electronics for back in the TTL CMOS day:thumbsup:. Our 1st course was vacuum tubes.
  13. Sep 3, 2019 at 6:10 PM
    cnoyes72
    cnoyes72 New Member
    CT
    Carplay is built into iOS. You just need to connect your iphone to a carplay compatible head unit and you'll be good to go.
  14. Sep 3, 2019 at 6:20 PM
    Corpus Christi, TX
    Android user here! Lol
  15. Sep 3, 2019 at 7:18 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Thanks.
