2014 Tundra crew max door speaker question
Discussion in 'Audio & Video' started by Michealmyers99, Jun 26, 2023.
  1. Jun 26, 2023 at 8:55 AM
    Michealmyers99
    Michealmyers99 [OP] New Member
    2015 Tundra
    Looking at replacing all 4 door speakers in a 2014 Tundra Crewmax. I think when the vehicle was cleaned the speakers got wet and none are working. This is the non JBL version.
    From what I'm reading looks like 6x9 up front and 6x5 in the rear, is that correct?
    Did these come with a sub or is that just the JBL version?
    Any recommendations on speakers that you guys have used?
  2. Jun 26, 2023 at 2:20 PM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    i went thru tech12volts. got a package deal on all 4 speakers, harnesses and tweeters. the sub is only on the JBL. i did a Dasaita head unit which really made it loud vs the stock head unit
  3. Jun 26, 2023 at 2:36 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  4. Jun 26, 2023 at 11:55 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Audiofrog for the win. You have 6.5 in rears. If I were you, I would put 6.5 on front too. I have adapters you could use.
  5. Jun 27, 2023 at 6:45 AM
    Michealmyers99
    2015 Tundra
    ok so after looking at this some, looks like there is an amp under the front passenger seat? Apparently the dash speakers work but I heard those are driven by the radio and then the door speakers are driven by the amp. I find it hard to believe that all 4 door speakers are bad which leads me to believe it's either a fuse or the amp has gone bad. Anybody replaced the amp?
  6. Jun 27, 2023 at 7:12 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    It's true, door speakers are run by the "amp" (if you can call it that) under the passenger seat. Grab the bypass harness from Amazon for $15. Color-codes for easy bypassing.
  7. Jun 27, 2023 at 7:14 AM
    Michealmyers99
    2015 Tundra
  8. Jun 27, 2023 at 7:25 AM
    MedCityMoto
    Well, if you weren't dissatisfied with the audio quality previously, you can just replace the amp. I have one from my 2016 you can have for shipping costs from MN to you, and just plug it in.
    That bypass harness would be if you replaced the headunit and speakers already, which on my breezing through pages here at work, I misread that you'd done that already.
  9. Jun 27, 2023 at 11:04 AM
    Michealmyers99
    2015 Tundra
    Ok yeah if your willing to let go of that "amp" I'll gladly take it!!
    I can PM you my address and then pay ya the shipping.
  10. Jun 27, 2023 at 11:19 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The OEM amp has it's own fuse.
    Did you check it?
    It's the 30 amp under the 'short pin' in the under-hood fuse box.
  11. Jun 27, 2023 at 11:21 AM
    Michealmyers99
    2015 Tundra
    yeah thats the first thing I'm going to check when i get the truck
    1lowlife likes this.
  12. Jun 27, 2023 at 11:28 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The OEM amp sends lows and mids to the door speakers.
    Hence your OEM door speakers are designed for mid/low frequencies.
    As stated the dash mid/tweeters and rear door tweeters run off the OEM Entune HU.
    You could replace the OEM amp without replacing the HU using the adapter.
    Amazon.com: 2010-2019 Toyota Tundra (w/o JBL Audio) AutoHarnessHouse.com Factory Amp Upgrade Harness AHH-4438 : Electronics
    But you either need a LOC to convert the HU speaker outputs to low level RCA plugs, or get an amp that acceptes speaker-level inputs.
    You'll also need to run a dedicated power line from the battery for the amp.
    Everything you need would be that adapter.
    Remote on feed for the amp, front/rear/left/right speaker output to the doors, and front/rear/left/right speaker input from the HU.
    If you do replace the OEM amp, go with a 5-channel, you're eventually going to want some kind of sub for bass.
    Plenty of room under the pass seat for a decent 5-channel amp.
    Good luck..
  13. Jun 28, 2023 at 3:57 AM
    Michealmyers99
    2015 Tundra
    Fuses all check out so gotta be the amp at this point
  14. Jun 28, 2023 at 7:54 PM
    Michealmyers99
    2015 Tundra
    MedCityMoto likes this.
