2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. May 12, 2021 at 2:20 PM
    #61
    Karambit
    Karambit New Member
    2008 Toyota Sequoia Limited
    Take a picture of this let’s see
  2. May 12, 2021 at 2:27 PM
    #62
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I got the fogs on eBay, .5 cents cheaper than from DD & free shipping.
    https://www.ebay.com/itm/373147922015
    My driver side vent would not stay pointed where I wanted. Toyota retail was over 100, got it from a dealer on eBay in the UAE for 68 bucks shipped, it just came well packed and it's the right one!
    #62
  3. May 12, 2021 at 2:32 PM
    #63
    e30cabrio
    Mine is different.
    But has a separate fog switch similar to that. I have tried it in every possible configuration. The anytime fog mod makes it so the switch is bypassed, I don't have power/light with that pin grounded.
  4. May 12, 2021 at 3:08 PM
    #64
    Karambit
    Karambit New Member
    Ah ok gotcha. Might have to run it the OEM way for now then
  5. May 12, 2021 at 3:40 PM
    #65
    e30cabrio
    Outside the DD fogs it is OEM. The DD fogs connect directly where the bulb goes, they work on both sides connected to the headlight connector, an OEM bulb connected to the fog does not work either.
  6. May 12, 2021 at 3:43 PM
    #66
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yes they fit. I have them on mine.
    Trdwillie14[QUOTED] likes this.
  7. May 12, 2021 at 5:27 PM
    #67
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Fit our 2017 just fine.
    S. Equoia likes this.
  8. May 13, 2021 at 7:09 AM
    #68
    e30cabrio
    Hertz speakers installed in Tacosomething 6x9 adaptors for the front doors, Image Dynamics in Tacosomething spacers for the back doors.
    Amps ready to go, Opened the box of interfaces/adaptors from Crutchfield, sat radio & nav antenna connectors missing, ordered from Amazon install delayed. grrrrr
    omgboost likes this.
  9. May 13, 2021 at 9:12 AM
    #69
    e30cabrio
    OEM harness desoldered from the Kenwood harness, Maestro harness soldered up.
    BrandonL812 likes this.
  10. May 14, 2021 at 5:06 AM
    #70
    e30cabrio
    Last night I tore into the dash, replaced the vent & hooked up the radio. I have no sound or steering wheel control. Checked the troubleshooting and found I had not connected the harness with the RCAs. Tried to connect them but the harness is wrong.
    The standard Toyota power connector connects to the Maestro harness, but then I can't connect to the radio:
    I need the female of the above male, I have this completely different connector.
    I do have interaction with the Maestro & get the backup camera to come up in reverse but no picture, just the guide lines, hopefully, that is just a setting. Waiting for 6am when Maestro opens.
  11. May 14, 2021 at 6:50 AM
    #71
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    This may be a stupid question, but did you flash the Maestro? Simple process but it took me a couple of times to get the steering wheel functionality correct during the flash process.
    e30cabrio[OP] likes this.
  12. May 14, 2021 at 7:18 AM
    #72
    e30cabrio
    Not a stupid question at all. I have done this before so knew about flashing, yup, it's set up. It sees the truck (see pics) Crutchfield sold me the wrong harness. They are paying for next day so I'll have it tomorrow.
  13. May 15, 2021 at 8:44 AM
    #73
    e30cabrio
    Fogs!
    drobb likes this.
  14. May 15, 2021 at 8:52 AM
    #74
    Karambit
    Karambit New Member
    How did you get them to work?
  15. May 15, 2021 at 8:56 AM
    #75
    e30cabrio
    Cheated. I spent hours trying to find the fault unsuccessfully & then gave them their own circuit.
    Karambit likes this.
  16. May 15, 2021 at 5:03 PM
    #76
    e30cabrio
    Stereo is in, need to install the amps & speakers/sub, so far so good. Everything works.
  17. May 16, 2021 at 9:15 AM
    #77
    e30cabrio
    Buttons match the truck, TPMS & OBD2 functions done.
    Ran the power cable through the firewall, it's already 90, need to run the RCAs, USB cables & install the amps, hoping to be able to shoehorn my JL stealthbox inside the driver rear 1/4 but its probable it won't fit. Those tasks are for next week.
    PermaFrostTRD, Karambit and omgboost like this.
  18. May 16, 2021 at 3:06 PM
    #78
    Karambit
    Karambit New Member
    Looking super clean man. Installing an aftermarket amp?
  19. May 16, 2021 at 6:47 PM
    #79
    e30cabrio
    Yup, posted a while back.
  20. May 16, 2021 at 7:46 PM
    #80
    e30cabrio
    There's gauges too!
  21. May 18, 2021 at 4:49 PM
    #81
    e30cabrio
    Tried three antenna adapters for the XM radio & NAV, none worked so I did what I should have in the first place, spliced the bi0tches.
  22. May 21, 2021 at 8:09 PM
    #82
    e30cabrio
    Radar detector running through the Kenwood. Need to run the cable around the windshield into the headliner.
  23. May 21, 2021 at 8:12 PM
    #83
    Karambit
    Karambit New Member
    Wait till you add the Pioneer amp, you’re really gonna love your setup
  24. May 21, 2021 at 8:19 PM
    #84
    e30cabrio
    I ran the RCAs for 8 channels, remote amp turn on and power, I'll be installing the D9601 and sub in the morning.
  25. May 22, 2021 at 7:06 AM
    #85
    e30cabrio
    Ran the cable, like having access through the head unit.
    Getting ready to wire up the amp & sub.
  26. May 22, 2021 at 8:32 AM
    #86
    e30cabrio
    Sub is in it's temporary location. I will try to get it into the stock location, I may try to put the DD driver in the stock box if the JL box does not work. I replaced the OEM crummy JBL "woofer" with the slim JL driver from this box about the second day I had the truck.
  27. May 23, 2021 at 12:50 PM
    #87
    e30cabrio
    Moved the sub to the back of the truck.
  28. May 23, 2021 at 2:18 PM
    #88
    e30cabrio
    My Wife constantly tells me not to save things. I have had these since 2015, bought for my X5 that I sold. I just ordered the 5th quart the Sequoia needs.
    And yes, I still have a fully functional VCR.
    lol
    tacoguybill, omgboost and kittyhawk like this.
  29. May 24, 2021 at 12:49 PM
    #89
    e30cabrio
    5th quart & pump came, needs a solution to the stupid Redline bottle opening.
    So I dug an even older partial (very little) Amsoil bottle out of the archives.
    farnsrocket likes this.
  30. May 25, 2021 at 10:43 AM
    #90
    e30cabrio
    I was finally able to get a pic of the radar detector screen on the Kenwood. 24 dollar harness is a bargain!
    A month before I got the Sequoia I threw away my Tundra skid plate that had been sitting in the garage for over 2 years.
    Picked this one up from BiggHertz It was clean and I painted it. Thanks!
