2002 Sequoia instrument cluster bulb #s
Discussion in 'Lighting' started by JebemTiHaiku, Nov 29, 2020.
  1. Nov 29, 2020 at 7:16 PM
    JebemTiHaiku
    JebemTiHaiku [OP] New Member
    2002 Toyota Sequoia
    The Toyota parts manual identifies the assembly part numbers for the three bulb types used in the instrument cluster as:
    83120-04090
    83120-60020
    83120-0C010
    Does anyone know the numbers of the actual bulbs and not the bulb/holder assembly ? e.g. #E74 bulbs are used to illuminate the Heating/AC panel
    Just looking for the original bulb part numbers and not interested in LED replacements.
    Thanks!
  2. Nov 29, 2020 at 7:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I went through this with the HVAC backlight bulbs. According to @Roman, whom is our on forum parts master...
    You cannot buy the bulbs with green rubberized coating separately. They must be purchased with the twist-lock base.
    Here's a picture of a cluster thats been LED converted.
    There are others here that have done a red cluster, and others that have done a blue cluster.
  3. Nov 29, 2020 at 7:57 PM
    JebemTiHaiku
    2002 Toyota Sequoia
    Hmm. Thanks for the reply.
    I already did this with the bulbs in the center dash AC/heating controls. The bulbs are type E74 which you can find on the Internet and the green covers are fairly easy to remove and replace on the new bulbs.
    As for the instrument panel some bulbs have the green covers but most don't. I'm just looking for the original bulb type numbers that are used in the Toyota assembly numbers:
    83120-04090
    83120 - 60020
    83120-0C010
    No interest in LEDs at all. Just looking for the bulb numbers. Thanks.
  4. Nov 29, 2020 at 8:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm assuming that the Sequoia, and Tundra clusters are the same.
    The blue circles are 194/T10 style incandescents.
    Link to Non-OEM incandescent replacements.
    Link to OEM replacements with the twist lock base.
    The pink highlights are 74/T5 style incandescents. I wouldn't buy OEM on this personally.
    The green highlights are the Gear indicator lights. Those are pretty much an OEM only type.
    Link
    You can get led replacements for all of these including the gear indicator, but I see you're not interested.
    Edit: Spelling.
  5. Nov 9, 2021 at 12:07 PM
    Jeremiah.a.devine
    Jeremiah.a.devine New Member
    Jeremiah
    2014 Tundra Crewmax Platinum
    Could you tell me what bulbs you used to do the leds for the instrument cluster? I have a 2004 sequoia I just bought
