20% MPG Increase!
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Feb 13, 2017.
  1. Feb 13, 2017 at 9:00 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Okay, so I lied. Sorry! But here's what really happened, and I hope someone can explain it.
    My '15 SR5 entune has been super frustrating. Freezing up, GPS turning on by itself and going berserk...pandora never working, etc. So I finally called toyota and they said take it to the dealer and have the audio driver updated to D4 or D54.
    ...so back from the dealer (they upated to D4) and I noticed something really interesting. After I filled up, Miles-To-Empty was 428. The highest I've ever seen is 355.
    Obviously my gas mileage did not improve by 20%. Only thing I can think of is the update allows the computer to acknowledge the fuel reserve.
    Anyone out there know for sure?
  2. Feb 13, 2017 at 9:02 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  3. Feb 13, 2017 at 9:06 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    If they reset the ECU or disconnected the battery in the process then your miles to empty may be reading just on the miles since you got the work done, which if you were turning higher MPG's over the short period since the reset vs your usual average then it'll show higher now and then taper back down over time
    HUTCHJ and 14burrito like this.
  4. Feb 13, 2017 at 9:07 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Na it just reset the system. Drive a few weeks for the truck to relearn and it will be back where it was.
  5. Feb 13, 2017 at 6:46 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Takes a while for the computer to get reintroduced to reality.
    HUTCHJ likes this.
  6. Feb 14, 2017 at 10:28 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    WOW, nothing like taking the wind out of a guys sails. :boink:
    Notachickmagnet likes this.
