20 AG trd pro jbl premium , tech12volts audio package options?
Discussion in 'Audio & Video' started by duzt, Aug 27, 2020.
  1. Aug 27, 2020 at 8:02 AM
    duzt
    duzt [OP] New Member
    everyone seems to like the audio packages offered by tech12volts. looking at his website it seems he offers 3 packages for a '20.
    jbl/jl/hertz
    kenwood/hertz
    infinity/hertz
    can anyone tell me the differences between the 3 and why one would choose one over the other?
    some of the packages do not come with dash speakers would you add those?
    the hertz k170 components are offered with all 3 packages, i have never heard of hertz, to those of you that have them are you happy with em? would you upgrade them if you were doing it over again?
  2. Aug 27, 2020 at 8:07 AM
    Elduder
    Elduder New Member
    Hertz makes pretty decent speakers. The K170s are an entry option from them, focused more around loudness or SPL. Basically they produce sound that most people will be pleased with. If you want a system that is louder, has dynamics, like bass you can feel then you should be pleased with them. If youre more interested in speakers that have more accuracy and sound more like real instruments and vocals I would either opt for a higher end Hertz speaker, or look to Focal, Audio Frog, or Morel.
    ryanwgregg and duzt[QUOTED][OP] like this.
  3. Aug 27, 2020 at 8:18 AM
    duzt
    Thank you for the very straightforward reply, exactly the type of info i was looking for much appreciated elduder
    Elduder likes this.
  4. Aug 27, 2020 at 10:45 AM
    duzt
    Got an email back from james. apparently the website is out of date and the only package hes currently offering is the jbl/hertz package
    https://www.shop.tech12volts.com/product.sc?productId=529&categoryId=124
    1 custom sub enclosure for crewmax or doublecab .
    1 JBL Audio Club 5505 5 channel amp
    1 hertz k170 6.5 compoenents front
    1 hertz k 170 6.5 components rear
    1 JBL Audio Club 1200 12 inch subwoofers (option 2-10's)
    60 feet of 14 gauge speaker wire
    1 4 gauge EFX BY SCOSCHE OFC wire kit
    2 sets of speaker mounting brackets for doors with harnesses
    anyone care to weigh in on this setup? anybody running it?
    Jim1983 likes this.
  5. Aug 29, 2020 at 4:41 AM
    yamabob
    yamabob New Member
    Chicagoland
    2018 Limited
    Subscribed.
  6. Aug 29, 2020 at 6:16 AM
    Jim1983
    Jim1983 New Member
    IL
    2020 White CrewMax SR5 TRD off-road
    Same here...looking for any additional info as I’m looking to order this package in the next week or so.
  7. Aug 29, 2020 at 7:26 AM
    Elduder
    Elduder New Member
    What is your budget? I could give you a ton of recommendations, but budget is the first roadblock.
    Also, do you typically carry passengers in the back?
  8. Aug 29, 2020 at 7:29 AM
    Jim1983
    Jim1983 New Member
    IL
    If it helps the package he is referencing is about $1000 including shipping, so that’s a good guess (and that’s my budget as well).
    Elduder likes this.
  9. Aug 29, 2020 at 7:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    ryanwgregg and Elduder like this.
  10. Aug 29, 2020 at 8:47 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Highly Recommended James is the BOSS...
  11. Aug 29, 2020 at 1:58 PM
    duzt
    Thanks guys id like to keep everything under 2.5k with sound deadening and all, but i haven't really set a budget yet. its been a good number of years since ive looked into the whole car stereo arena, so im kinda just figuring out the new takes on everything... key considerations im looking into are
    "buy once cry once build"
    -need to keep factory hu
    - active crossover with 2 separate amps for doors and sub vs just passive crossovers and 1 multi channnel amp
    - 2-10" vs 1-12"
    -what to do about the front dash and center (dont really want to just unhook them, but i dont want them to be overpowering[so more channels on the amp or eq or something?])
    -quality components, i like midbass and depth too bright can be harsh to my ears
    I thought i was getting a "premium" system in the first place. I dont want to spend all this extra effort and cash to be second guessing myself down the road if i should have spent a little more. At the same time i dont like pissing money away.
    Im working on a couple of lists of set-ups im leaning towards that i figured id bounce off of you guys and James and make adjustments from there.
  12. Aug 29, 2020 at 2:39 PM
    Elduder
    Elduder New Member
    Not sure your level of experience here, so just going to approach this as if your asking a question with little or experience. Generally speaking, active cross using a DSP or DSP amp (because digital processing is required to be active) is geared toward stage presence and spacial dynamics of sound. Basically making it sound as real as possible, involving getting sounds to not just be left and right, but high, low, delayed or distant, advanced or close. If that's the goal, running rear speakers will work against that as it will literally pull the staging backward. Either you run subs or low band in the rear, or no speakers at all. Comps in the rear with the front active sounds like an excellent way to waste money and a lot of time. Not trying to come across like an ass here, just being straight about it. Basically if you're going to ignore the main reason for active, which is controlling the staging of each speaker, and run rear speakers, then just stay with the passive crossovers included with the speakers. Honestly a lot of passive speakers crossovers are better than some people are with tuning.
    2-10" vs 1-12"
    If youre keeping the rear seats installed, go 2-10s, all day. You will have so little excursion on the shallows available that its better to just double up the subs. To get a 12 that would perform well enough to mitigate the biggest issue we have with our trucks and space for subs, you would be looking at something like the JL TW3s which run ~$370. So either go big on one or just get two.
    Again, if youre going active, remove the center channel, you will have no way to blend it with out an additional DSP channel and then tying the wires into the DSP and back out. You wont miss it once you have good power to the doors and proper tuning. The dash corners should be removed since you will be running tweeters with your comp. set up.
    Shop for speakers known to be "warm" then. Focals arent your friend if you dont like bright. Morels are a better choice, but spendy. The Tempo Ultras are awesome and reasonably affordable. Morels passive crossovers are legit and tuned with a very low cross for the tweets. Brings the vocals higher up as well as the strings, they know their shit. Infinities higher end models are a good neutral sound, worth considering. Audio Frog is also on the warmer side and worth a look.
    Something you hadn't mentioned, but based off your comment here, I recommend getting good power to the speakers, not like 45 or 50W, more like 100W. The change in speaker dynamics, the power that drives the magnetic changes when you have more power makes things punchier, more real and distinct, gives you that depth you want. More power is better than less, you could spend a ton of money on parts and then under drive them and be left with lackluster sound and then feel like its the speakers or tuning. I know saying more is better will open the can of worms for some, triggers the " watch out for clipping", "stock wiring cant take it", or "you'll fry the speakers", its not that simple, but if you want or need to know more about that just ask.
    Of course, if I'm ranting about things you already fully understand, then excuse me and just tell me you're good, lol.
    :hattip:
    dkahs05 likes this.
  13. Aug 29, 2020 at 2:47 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    My invoice from James (he installed):
    JL package with Hertz doors
    Hertz MPK Coaxials Front Doors and DT24.3 Tweeters
    Rear JL C1 650
    RD 900/5 Amp
    2 JL 10w1 Subs and Custom Box, all wire, sail panels, and sub knob
    4 rolls of sound shield
    1 DSR1 processor (for JBL system only)
    I kept the JBL head unit...the upgrade in speakers, amp, and processor is incredible. Before, the stereo in my Crosstrek was better than the Tundra. Now, the volume on 30 rocks it out - good cruising sounds...bass vibrates the ass.
    Platinum714 and GGODON like this.
  14. Aug 29, 2020 at 3:48 PM
    duzt
    @Elduder my experience level is somewhat low and i was more just learning what the advantages there might be, again you have cleanly cleared up something that was confusing me a bit. i was thinking that i might not actually need active and it is probably a bit more involved than i need. the multi channel amps however seem like you end up underpowering the subs a little. completely agree on power so i was thinking id make my speaker choices and then choose the amp/amps based on needs. and your not ranting at all sir the info is much appreciated and there are others following along as well so please feel free...
    @GREENwithENVY that looks like a nice setup and probably very similar to what i will end up with, the jl c2 650's are on my list of possible components (also thats a nice truck ya got there!)
    Elduder and GREENwithENVY like this.
  15. Aug 29, 2020 at 3:53 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    James is great to deal with, offers specific options for the Toyota Tundra and at a more than fair price point. That said, if you’ve ever installed on your own, and are willing to do some legwork you could save a few dollars by doing it all yourself. I went with the plug and play amplifier and did my own speakers.....focal and Memphis are the brands I went with. I suggest 6x9’s for the fronts for increased bass response and 6.5’s in the rear with a pancake Powered subwoofer under the rear seat
    GREENwithENVY likes this.
  16. Aug 29, 2020 at 6:31 PM
    Elduder
    Elduder New Member
    Speakers first and then amp to suit their needs is a good way to go. I have the JL C2 690tx in our 4Runner, its the 6x9 C2 coaxial. C2s are good speakers, just dont get the coaxials for the front, go with the component set. The 4runner has tweeters in the dash and the C2 coax in the door and the sound stage is about as high as my mid chest. I dont prefer it that way, but my wife is not the audiophile and doesnt mind it.
  17. Aug 29, 2020 at 9:04 PM
    duzt
  18. Aug 30, 2020 at 9:09 AM
    duzt
  19. Aug 30, 2020 at 2:00 PM
    duzt
    Think ive narrowed it down to these 3 builds, the morrels look nice but thats starting to get out of my price range. does anyone run alpine subs anymore? i liked the type r's way back when....
    JL Audio C2650 $540
    JL Audio 10TW1-2 $520
    JL Audio XD700/5v2 $680
    Focal Performance PS 165F $770
    Focal Performance P25FS $280
    Alpine PDX-V9 $850
    Alpine X-S65C plus r-s65c.r rear $640
    Alpine SWR-T12 $410
    Alpine PDX-V9 $850
    https://onedrive.live.com/embed?res...e&wdDownloadButton=True&wdInConfigurator=True
    GGODON and 619Tundra like this.
  20. Sep 15, 2020 at 5:53 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I would really like to see how these systems respond once someone installs them in their Tundra. If any of you have tuned the system and have an RTA curve that you can provide it would be greatly appreciated.
  21. Sep 23, 2020 at 10:45 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Curious as well, but already committed, bought the system and matting from James. Shopped around audio installers in the area and just nuts on pricing for equipment and installs. Started @3K partial to 5k to 6K for someone to do it. My cheap a$$ said, you know you did this as a kid so lets give it a go again. The components in the kit are very reasonable and reviewed really well. Plus its enough to grow from if you ever you decide you want more out of it, the hard work would be done.
