20-21 OEM Radio Part Number
Discussion in 'Audio & Video' started by MaxPower, Sep 16, 2022.
  1. Sep 16, 2022 at 7:52 PM
    MaxPower
    MaxPower [OP] New Member
    18 Tundra TRD Off road
    Does anyone know the part number for the ENTUNE 3.0 non JBL head unit with factory nav?
    I am thinking it may be 86140-0C390 but would like to confirm if anyone knows for sure. I am looking to transplant one into my 2018.
    From what I understand the non nav units wont transmit info to the multi information display in the instrument cluster.
    Below is a list of available Tundra Stereo part numbers:
    RECEIVER ASSY, RADIO & DISPLAY
    86140-0C201 1
    86140-0C211 SOUTH AMERICA SPEC 1
    86140-0C340 CANADA SPEC (08/2019 - ) 1
    86140-0C350 (08/2019 - 08/2021) 1
    86140-0C380 CANADA SPEC&AUDIO-AVN & 9SPEAKER 1
    86140-0C390 AUDIO-AVN & 9SPEAKER 1
    86140-0C420 AUDIO-AVN & JBL & 12PEAKER 1
    86140-0C430 CANADA SPEC&AUDIO-AVN & JBL & 12PEAKER
  2. May 14, 2023 at 8:23 PM
    Tundramann32
    Tundramann32 New Member
    2018 SR5 CrewMAX
    Truxedo, side steps, rockstar rims, tint, red calipers
    I found one local for $100 (86140-0C390) and I want to purchase and install in my 2018 SR5, non jbl.
    Did you get yours to work?
  3. May 15, 2023 at 2:41 AM
    You will need a harness as well.
  4. May 15, 2023 at 3:18 AM
    Tundramann32
    2018 SR5 CrewMAX
    I see the main wiring adapter and a usb adapter.
  5. May 15, 2023 at 4:46 AM
    There are a few that have done it. I would have to find the thread....I think it had links and part numbers. I believe the harness was around $200.
  6. May 15, 2023 at 7:20 PM
    MaxPower
    I did. I got a Non JBL unit with NAV from a 21 TRD Pro. OEM # 86140-0C391
    I bought the following harness.
    https://www.autoharnesshouse.com/entune.html
    I also ordered their expensive USB adapter. Everything works great.
  7. May 18, 2023 at 8:41 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    2018 Silver Sky CM 1794
    Could someone post a part number for JBL units? I have an ‘18 with JBL and would love to upgrade to ‘20-21.
    (If anyone has a laying one around or knows a great place to get one please let me know)
    Much appreciated! This forum rocks!
  8. May 18, 2023 at 8:43 AM
    Don't forget to consider the cost of the harness as well. The connectors are different for the 20/21's.
    Yugo[QUOTED] and bulldog93 like this.
  9. May 18, 2023 at 9:00 AM
    MaxPower
    I am pretty sure it's 86140-0C420. If I remember correctly you have to swap out the factory JBL amp for the newer amplifier as well.
  10. May 18, 2023 at 9:54 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    Thanks! I see 86140-0C430 as well, I wonder what’s the difference. That’s a good question regarding JBL amp, I hope someone can confirm!
  11. May 18, 2023 at 10:01 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    If you have the JBL, you will also need to get the '20-'21 amp as well. Something else to consider.
  12. Oct 27, 2023 at 1:41 PM
    xcrr246x
    xcrr246x New Member
    Hi MaxPower.. would you happen to have pics of the unit before you installed it? Curious to see what the back of the unit looks like to see if it’s compatible with my current harness. Thxs
  13. Oct 27, 2023 at 6:07 PM
    MaxPower
    Here you go. This is the new 2021 unit.
  14. Oct 28, 2023 at 6:05 AM
    xcrr246x
    xcrr246x New Member
    Thanks, brother!
    MaxPower[QUOTED][OP] likes this.
  15. Dec 11, 2023 at 10:28 AM
    juan40tundra
    juan40tundra New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    Do you have apple car play feature on this unit?
    bfunke likes this.
  16. Dec 11, 2023 at 11:27 AM
    xcrr246x
    xcrr246x New Member
    Yes, you get Apple play. I purchased the exact same radio model and harness. Works perfect.
  17. Dec 11, 2023 at 12:03 PM
    SnrDisregardo
    Wade
    IL
    Have you had any issue with using off brand usb cables? I can only get the Apple ones to work properly.
  18. Dec 11, 2023 at 12:51 PM
    juan40tundra
    Juan
    none
    Do you know where I can purchase one of those head units and how difficult is to do the swap?
  19. Dec 11, 2023 at 1:32 PM
    MaxPower
    Yes I do.
  20. Dec 11, 2023 at 2:48 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I swapped non-JBL in my 2019 SR5 to non-JBL with Nav, from 2018 or 17. Bolt on.
    Wife's 2022 Sequoia has JBL with everything it can ever have. Honestly I think it is not worth it if you have to deal with amp and harness and everything. Just not much juice over what you can have on your smartphone.
    If you plan to sell yours, don't forget to factory reset it or at least remove your phone and home address before unplugging it =)
  21. Dec 12, 2023 at 6:19 AM
    juan40tundra
    Juan
    none
    MaxPower
    can you share the link where to purchase the head unit
  22. Dec 12, 2023 at 9:25 AM
    MaxPower
    I found it on eBay.
  23. Dec 12, 2023 at 12:53 PM
    SnrDisregardo
    Wade
    IL
    Same. Found on eBay and car-part.com
  24. Mar 6, 2024 at 2:14 PM
    jwebb
    jwebb New Member
    Jonathan
    Black 2017 Tundra SR5
    Can anybody give me some help about this? I have a 2017 that does not have JBL. I’m hoping to swap into a head unit from a 2020/2021. Can the new head unit have JBL or do I need one without in order for it to work in my 2017.
    Any input or advice would be appreciated. Thanks!
    -JW
  25. Dec 22, 2024 at 6:22 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    same boat here.. did you ever figure out a solution?
  26. Dec 23, 2024 at 8:03 AM
    SnrDisregardo
    Wade
    IL
    From my experience, no, you would have to get a non-JBL unit as you would need the harness for the amp. Would it be possible? Yes, but you would have to do a lot of figuring out with wiring if you wanted to add an amp.
    If I were to do it over again, I would just get an aftermarket unit. I've spent the equivalent or more to now have issues with voice operations using a iPhone 16. My thinking would be a aftermarket unit would be more stable with CarPlay.
  27. Dec 24, 2024 at 8:48 AM
    CharlestonJoe
    CharlestonJoe New Member
    Joe
    Charleston,SC
    2020 White Tundra SR5 5.7 4x4
    TRD intake, Tow Mirrors, Under seat storage, Built in bed storage, Borla exhaust, 3” Icon lift, BFG’s, Method wheels, 1794 grille, Prinsu Roof Rack,
    I have had 2 aftermarket radios in my 2020, they suck!!!! I’m going to go with a 2021 with the wireless apple play. Both aftermarket’s have had GPS issues, glitch like crazy, have to shut off the radio and restart, the only thing I like is I can click on the camera display and check on my trailer behind me, but for actually using the camera for backing up, there’s a black box with text in it, some kind of warning crap and it blocks half the screen. The first aftermarket would glitch and put me a half mile away, the guy who installed the 2nd radio said that was a gps antenna issue. Well this second radio the gps will show me driving backwards for a half mile sometimes more before it gets turned around. If I am trying to zig zag a couple blocks, I want to see where I am going, not where I’ve been. I have spent around $5k on aftermarket radios. I’m done.
  28. Dec 24, 2024 at 8:54 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The 2021 OEM radio does not have wireless carplay. It’s the same radio that was in your 2020 before you went down the aftermarket rabbit hole.
    SnrDisregardo likes this.
  29. Dec 24, 2024 at 9:01 AM
    CharlestonJoe
    Joe
    Charleston,SC
    A friend has the 2021 and his has wireless CarPlay. Must depend on radio model?
  30. Dec 24, 2024 at 9:03 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Nope. Not in the tundra - they are all wired only.
    Unless he is using an aftermarket wireless carplay dongle link CarLinkIt or similar
