20,000 mile maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by T-Guy69, Sep 7, 2025 at 1:07 PM.
  1. Sep 7, 2025 at 1:07 PM
    T-Guy69
    T-Guy69 [OP] New Member
    Long Island
    Black 2020 Tundra SR5
    I put my owner’s manual in a safe place. So safe, I can’t locate it. :(
    Time for me to do my pre-winter maintenance. I just hit 20,000 on my 2020 Tundra. I plan to
    • Do an oil and filter change
    • Note: just changed the air filter.
    • I plan to bleed the brakes.
    What other maintenance would Toyota recommend for 20,000??
    2mchfun likes this.
  2. Sep 7, 2025 at 1:18 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Have you done rear diff yet? If not I would. I would put a new pcv as well for 8 bucks. Wouldn't hurt to suck out your power steering fluid and fill with new.
    2mchfun likes this.
  3. Sep 7, 2025 at 1:20 PM
    Mr Badwrench
    Mr Badwrench New Member
    I think that pretty much covers it. There's not a lot of maintenance before 50,000. I don't know that I'd even bother bleeding brakes at only 20k.
    Check the cabin air filter maybe. Mice and bugs find their way in there in the Fall and Winter.
    2mchfun likes this.
  4. Sep 8, 2025 at 2:44 AM
    T-Guy69
    Long Island
    Checking the cabin filter is a good idea. It can't be hard to relace and not an expensive item.
    Bleeding the brakes has more to do with time rather than mileage. Five years is the maximum I usually go. In my past, I have not been so diligent, and the insides of the calipers rusted. The rebuilt calipers I purchased never seemed as good.
    2mchfun likes this.
  5. Sep 8, 2025 at 3:45 AM
    2mchfun
    rotate tires, pour 2 cans Berryman's B12 injector cleaner into a half tank of fuel, wiper blades, drain and fill coolant, too old. Brass drain valves on both sides of block can be accessed behind tires through wheel well with steering turned, way up in there. Just crack them open to drain the block. That coolant turns acidic with heat cycles over time and eats head gaskets. Also replace the radiator cap, the rubber seal fails and gets stuck inside the water jacket or pump.
  6. Sep 8, 2025 at 4:19 AM
    MadMaxCanon
    Radiator caps a good one
    2mchfun likes this.
  7. Sep 8, 2025 at 4:36 AM
    Honestly, just the normal oil, filter and air filter change is all that’s needed at that age and mileage. Tire rotation. No need to swap parts that haven’t even had a chance to give you some service life.
  8. Sep 8, 2025 at 5:22 AM
    T-Guy69
    Long Island
    I am going to take a six-hour drive to the Finger Lakes. I planned to add two cans of BG 44K Fuel System Cleaner Power Enhancer 4. It was recommended to me by a gentleman on this board who is one of the engineers that formulate Shell gas. I use it in all my cars.
    2mchfun[QUOTED] likes this.
  9. Sep 8, 2025 at 5:23 AM
    T-Guy69
    Long Island
    I forgot to add tire rotation. I do that in the fall when I do my oil change.
    2mchfun likes this.
  10. Sep 8, 2025 at 5:26 AM
    2mchfun
    Just so you keep em clean, you will not regret it.
  11. Sep 8, 2025 at 7:26 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Don’t bother with the brake bleed/brake fluid change. You can buy brake fluid test strips to test for moisture. If the fluid looks golden and there’s no moisture you’re golden.
    AZBoatHauler likes this.
