2 weeks in and already issues
Discussion in 'General Tundra Discussion' started by trey3476, Nov 20, 2019.
  1. Nov 20, 2019 at 5:49 AM
    trey3476
    trey3476 [OP] New Member
    Jay
    2017 TRD/SR5 Tundra
    So, coming home from work last night, my "new to me" 2017 started cutting out when I would hit around 35 mph. I get home, and my brake lights and cargo light would not shut off unless I pulled the power from the battery.
    2 WEEKS?!? I am not trying to be overly pessimistic here, but I can't imagine, after all the good I have read in this forum about how well built our tundra's are, that this happens to me (not that I would have ANY luck, if it weren't for bad luck).
    Thank you!
  2. Nov 20, 2019 at 5:54 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    CPO truck? Purchased from Toyota dealer? Warranty?
    HappyGilmore and Pinay like this.
  3. Nov 20, 2019 at 5:54 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Under warranty?
    Rex Kramer and Pinay like this.
  4. Nov 20, 2019 at 5:56 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Hate to hear that. Any warning lights? Maybe it went into limp mode but I'd think you would get a check engine light.
    Pinay likes this.
  5. Nov 20, 2019 at 5:59 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have no idea of you situation, but I just fixed a Nissan with all kinds of craziness like that. Some sort of animal (small rodent) chewed on some of the wires in the engine bay. Just something to maybe look at, cold weather makes some animals nuts.
    Shark Bait, CMB, GODZILLA and 3 others like this.
  6. Nov 20, 2019 at 6:02 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    This right here...
    08crewmax likes this.
  7. Nov 20, 2019 at 6:06 AM
    trey3476
    Jay
    2017 TRD/SR5 Tundra
    Purchased from a Dealership, not a Toyota Dealer, I purchased the warranty as well. The Wife is taking it to the Dealership we purchased it from today, and they will be going over it (regardless that I do not believe they checked it out from the beginning). The lady I purchased it from, seems to think that it is a fuse... I find that hard to believe because, if a fuse was out, wouldn't I lose all the lights that are powered by said fuse?
    Darkness likes this.
  8. Nov 20, 2019 at 6:09 AM
    Rex Kramer
    Georgia
    I would have the local Toyota dealer check it out first, then go to the seller armed with whatever the Toyota dealer discovered.
  9. Nov 20, 2019 at 6:10 AM
    trey3476
    Jay
    2017 TRD/SR5 Tundra
    I climbed in the hood, while it was still light out, and looked as best I could. The blower housing is still solid attached, (I wanted to check this because after the wife's nissan was in for an oil change the idiot didn't connect the blower housing up and her car was cutting out bad), I didn't see any wires that I remember (GREAT idea, even tho we live in town there are a SHIT TON of flippin cats in my neighborhood). This is bad cuz I am a stereo guy, but I couldn't find the Fuse Box (is it under the hood?), AND I noticed that the interior kick panel (on the left foot side) of the drivers seat was loose.
  10. Nov 20, 2019 at 6:12 AM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    There’s a fuse box on the driver side footwell. It’s hard to see if you haven’t located it before. It’s a skinnier than normal fuse panel.
    trey3476[OP] likes this.
  11. Nov 20, 2019 at 6:37 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Code reader?
  12. Nov 20, 2019 at 7:43 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Fuse box under the hood is next to the battery. In the cabin it is near the kick panel actually above the parking brake. Small and hidden well.
  13. Nov 20, 2019 at 7:59 AM
    Stig
    Stig New Member
    Never know what you're getting when buying used. That's the risk you take for saving money over new. All you can do is PPO and/or buy CPO and hope for the best.
    Cpl_Punishment likes this.
  14. Nov 20, 2019 at 9:14 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Try lifting the brake pedal with your toe. If the brake lights are staying on, you’ll lose throttle thanks to the brake override programming.
    That doesn’t explain the cargo light, but maybe it’s just the normal timer after you close the door?
  15. Nov 20, 2019 at 9:56 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    You will have to almost break your neck and throw out your back to work on the footwell fuse box!
    plumber802 and unclebeejo808 like this.
  16. Nov 20, 2019 at 9:56 AM
    This^^^^^^^
  17. Nov 23, 2019 at 3:45 PM
    Obtunded
    Obtunded New Member
    San Antonio
    2016 Tundra CrewMax XPS-X 4x4
    Carbon fiber dash, leather seats
    Im trying to find out why my brake light is continuously on. Parking brake.
  18. Nov 23, 2019 at 8:05 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Did you check the brake fluid level?
  19. Nov 24, 2019 at 8:20 AM
    Obtunded
    Obtunded New Member
    San Antonio
    Just did. It was above minimum but not up to the full level. Nope. Didn't do anything. About to do zero point calibration
  20. Nov 24, 2019 at 8:35 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Probably brake light switch. I would try what @landphil said, it sounds reasonable. Cargo light could be a separate issue. I doubt it is fuse related.
    Are you sure it's the cargo light and not the third brake light?
    Pinay likes this.
  21. Nov 24, 2019 at 2:13 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    A weak battery will trigger some weird gremlins as well. Take it to your local auto parts store and have the load test the battery.
  22. Nov 25, 2019 at 8:06 AM
    trey3476
    Jay
    2017 TRD/SR5 Tundra
    So, the mechanic at the dealership says, one of my tire sensors went out and it caused a second sensor to go out, thus causing the loss in power and the cargo and brake lights to stay on regardless if the truck is on or not.
  23. Nov 25, 2019 at 8:39 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @trey3476
    Is there any mods to the truck? Is there any indication that the previous owners have had modifications done to the truck and then removed?
    Since you didn’t buy the truck new and have no real history on the truck, it’s not really reasonable to blame Toyota. What is happening definitely sucks and I hope you can get it resolved with little loss of your time and money. I would absolutely push back hard and fast on the seller.
  24. Nov 25, 2019 at 9:24 AM
    plumber802
    Andy
    Vermont
    Sorry Jay, I don't see how 1 TPMS sensor could cause that chain of events. So, changing 2 tpms sensors resolved the issue?
  25. Nov 25, 2019 at 9:27 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m thinking it was the ABS wheel sensor not the TPMS
    georgiey22 likes this.
  26. Nov 25, 2019 at 9:59 AM
    trey3476
    Jay
    2017 TRD/SR5 Tundra
    It was the ABS sensor....
    15whtrd and georgiey22 like this.
  27. Nov 25, 2019 at 10:03 AM
    trey3476
    Jay
    2017 TRD/SR5 Tundra
    It blew my mind that the ABS sensor could cause all these other issues
  28. Nov 25, 2019 at 10:09 AM
    Obtunded
    Obtunded New Member
    San Antonio
    I filled all my fluids and a zero point calibration and all my light are off except my tpms. My 08 CM is running good. Th out about trading but I think k I'll do another year of no payments. Thank you to all for your advise.
