2 WD front wheel bearings
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Oct 17, 2021.
  1. Oct 17, 2021 at 8:02 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I’m fairly sure I have a bad front right wheel bearing. I removed the caliper and the disc.
    It had a little grinding and had play when I spun the spindle. Truck has 95K miles.
    From my research, it looks like a technical and not easy job.
    How do you guys address a wheel bearing job?
  2. Oct 18, 2021 at 4:36 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    In the past, I've pulled the knuckle and taken it to shop to press a new one in.
  3. Oct 18, 2021 at 4:48 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Ok,
    What is the OEM Bearing?
    I could find Timkin and Koyo
  4. Oct 18, 2021 at 6:42 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Either brand is good, mine were Koyo. You'll definitely want to call around and find a shop that can do it, sometimes a 20 ton press isn't enough. If you pull the knuckle and bring it you'll only pay about an hours labor. I wish I kept the receipt to tell you what parts to look for. I replaced the bearings, the dust shield and I think the nut. Nut can probably be reused.
    bmf4069 likes this.
  5. Oct 18, 2021 at 6:57 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Here's the Toyota parts diagram breakdown:
    https://parts.toyota.com/showAssemb...ne=74552&ukey_trimlevel=144287&modelYear=2005
    I used the Limited as a reference since they don't list the XSP as a separate model in this case. I dont think the wheel bearings would be different. Note that left and right part #'s are different.
    As far as approach to the job goes unless you are prepared mechanically with the skill-set and the tools I would do as described and pull the knuckle only and let someone else qualified do it.
    Darkness likes this.
  6. Oct 18, 2021 at 7:24 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its really a head scratcher that Toyota made bearings for these trucks such a pain. Most Toyota are a bolt in affair.
    Siebler likes this.
  7. Oct 18, 2021 at 8:36 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'll sum it up for you:
    I'm sure 2wd is probably the same.
    Jack McCarthy, JasonC., w666 and 2 others like this.
  8. Oct 18, 2021 at 8:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Had a local tire shop replace mine. Installed Koyo bearings with new nuts and reused the dust shields. Brought them the knuckles and they pressed them in for me.
    If you have a press and want to tackle it yourself, Sue does a great job showing how to replace them.
    https://youtu.be/_Yy9-VLahbA
    bmf4069 likes this.
  9. Oct 19, 2021 at 4:04 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Toyota's FWD cars are like this too. I just did the front bearing on my daughter's Matrix. It's honestly not too difficult a job if you have a press. But it does also require that you have some tooling (blocks, large sockets, etc.) to allow proper placement on the press.
    That's a great video. I'd almost guarantee the bearing on that truck failed because the bearing wasn't properly supported when the hub was pressed back in.
    Darkness[QUOTED] likes this.
  10. Oct 19, 2021 at 10:00 PM
    artsr2002
    'Yonder
    JasonC. and bmf4069 like this.
  11. Feb 20, 2023 at 12:13 PM
    S-Man
    S-Man New Member
    2002 Tundra
    Sounds like my 2wd front bearings need replacing too. Are there recommended parts to replace in addition to the bearings or just the bearings? Should I be ordering seals and spring clips etc?
  12. Feb 21, 2023 at 4:12 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Upper and lower ball joints, tie rod ends, and sway bar links all attach to the knuckle that comes out. It's worth checking them while the knuckle is out. OEM only for the ball joints, and don't forget new bolts for the lowers.
    Also, is your truck tan on the bottom?
  13. Feb 21, 2023 at 2:13 PM
    S-Man
    S-Man New Member
    2002 Tundra
    Thanks, I just replaced all that back in August last year. I just wish I would have thought to replace the hubs while I was in there :(
    My truck used to be Red/Silver two-tone when I bought it new but I've recently painted it all red.
    16CMTXED and bmf4069[QUOTED] like this.
  14. Feb 21, 2023 at 2:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Sunshine Red Pearl by chance ?
    Sharp lookin and like it almost as much as Salsa Red Pearl !
    FrenchToasty likes this.
  15. Feb 21, 2023 at 3:54 PM
    S-Man
    S-Man New Member
    2002 Tundra
    Sunfire Red Pearl is the actual name. Thanks!
    BubbaW[QUOTED] and FrenchToasty like this.
  16. Feb 21, 2023 at 8:39 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sweet. I only ask because I've only seen 1 of mine.
  17. Feb 21, 2023 at 8:43 PM
    S-Man
    S-Man New Member
    2002 Tundra
    Yeah they're definitely rare. Mine was done by the dealership I believe. I've only seen one other like it with the red and silver combo. I have seen a few red and tan however.
