2" lift with bigger tires changed my Tacoma's handling. Should I lift my Tundra?
Discussion in 'Suspension' started by ToyotaGirl67, Apr 13, 2024.
  1. Apr 13, 2024 at 6:30 PM
    ToyotaGirl67
    ToyotaGirl67 [OP] New Member
    Pennsylvania
    2020 silver Tundra Limited
    I've been thinking about a 2 inch lift with bigger tires on my Tundra.I had both
    on my Tacoma and it looked awesome,but it changed the way the truck handled.
    Should I lift it or leave it...
  2. Apr 13, 2024 at 6:35 PM
    JohnWhicker
    JohnWhicker New Member
    Some people do it for the looks I guess? or off roading? I mean the look is OK but I think it changes the way it drives and it handles? And I am very particular about that. Like the way my 21 drives right now is like butter and I wouldn't change anything about or sacrifice it just for a cool look? On my 13 I have the KO2 tires but on my 21 I am all stock and I will absolutely not change anything about it. Keep it simple I guess is my take on my 21.
  3. Apr 13, 2024 at 6:49 PM
    ToyotaGirl67
    Pennsylvania
    I would do it for looks only.I get teased for having a "pavement princess"with both
    my truck and buggy.Thanks for your input!
  4. Apr 13, 2024 at 7:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Would you get new wheels or use the stock wheels?
  5. Apr 13, 2024 at 8:04 PM
    ToyotaGirl67
    Pennsylvania
    I would get new rims too,although I kept the stock rims on my Tacoma
  6. Apr 13, 2024 at 10:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Reason I asked, if you were going to keep your stock wheels I would’ve said no. They look good on your truck currently but look a bit too “luxurious” with big tires. Also, I really don’t like lifted trucks with the stock offset. Makes the truck look too tall and imbalanced. In my opinion, a 2”-3” lift needs atleast 34” tires, on a 17” or 18” wheel and a +25 offset or less to look good.
    BillyB and ToyotaGirl67[OP] like this.
  7. Apr 14, 2024 at 6:34 AM
    ToyotaGirl67
    Pennsylvania
    Thanks for the info,it's everything I needed to know:)
  8. Apr 14, 2024 at 9:01 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Even just changing your tires to around 295/70-18 makes a huge difference.
    ToyotaGirl67[OP] likes this.
  9. Apr 14, 2024 at 9:05 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    Here's a little picture lesson through stages.
    All stock-
    Just 295/70-18 Ridge Grapplers. Still 100% stock suspension, +60 offset on TRD Pro wheels-
    Level at 1.5" lift in the front with same 295/70-18 Ridge Grapplers-
    And how it sits today, 2.5" lift in the front, 1.75" in the rear, +25 offset wheels, 315/70-18 ( listed as 35.6"x 12.4") tires.
  10. Apr 14, 2024 at 9:13 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Any rub or experience to pass on? Because I will do the same with wildpeaks.
    Edit- would like to keep things stock for now if possible.
  11. Apr 14, 2024 at 9:15 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    With just the 295/70-18 on stock suspension, I removed the front little mudflaps. I also have an aftermarket front skid plate. And of course, the wheels were stock +60 offset.
    I'm assuming that's what setup you are inquiring about?
    OHwendTrd[QUOTED] likes this.
  12. Apr 14, 2024 at 1:03 PM
    ToyotaGirl67
    Pennsylvania
    thanks so much for all the info!! that truck looks super sharp with the lift,etc.I like all the bells and whistles on my truck but I like the outside to look more rugged.Im
    just afraid to mess with the smooth ride.
    BillyB likes this.
  13. Apr 14, 2024 at 1:46 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I think putting on a slightly aggressive tire in a size up that your truck can fit without a lift would look great. I've ran the cooper AT3 4s in the past and has great street manners and looked a little tough. Easy dirt roads they were fantastic.
  14. Apr 14, 2024 at 2:10 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I would stay if you have to ask about the handling, then leave it stock.
  15. Apr 14, 2024 at 7:44 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    You can actually gain in the handling if you choose the correct parts.
  16. Apr 19, 2024 at 8:16 PM
    AtomicToyo
    AtomicToyo New Member
    Ontario, Canada
    Swap the stock UCA to correct the caster when lifting and you won't have that 'wandering' steering feeling post lift.
    BillyB likes this.
  17. Apr 19, 2024 at 8:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yeah the uca is the biggest need. Its a 100% must have when you lift otherwise the handling is terrible
    BillyB likes this.
