2 inch lift?
Discussion in 'Suspension' started by AeChoy, Sep 5, 2023.
  1. Sep 5, 2023 at 10:25 AM
    AeChoy
    AeChoy [OP] New Member
    I have bilstene 5100 in the front set with the middle setting.
    Rear is stock
    Want to install a 2-3 inch lift,i don’t go off road much at all.
    what is best set up?
  2. Sep 5, 2023 at 10:32 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    theres a ton of answers based on what peoples opinion of "best". Sounds to me like you want a basic lift for low cost. Set your billys up front for the 2 inch lift and you can get +3 coachbuilder shackles in the back for a little shy of 2 inch lift, or you can go blocks or a combo. No frills and pretty cheap.
    AeChoy[OP] likes this.
