2.5 trans fluid check mode
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tsm503, Jan 24, 2023.
  1. Jan 24, 2023 at 7:23 PM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Got the wire in the OBD2 but not blinking for fluid check mode
    2021 SR5
    Saltyhero13 likes this.
  2. Jan 24, 2023 at 7:26 PM
    I'm not familiar with what you are trying to do but I am curious.
  3. Jan 24, 2023 at 7:28 PM
    Tsm503
    2021 DC SR5
    Trying to put the tundra in transmission fluid level check mode to check transmission fluid level
  4. Jan 24, 2023 at 7:33 PM
    Maybe try the method that @2020Platinum provided during the transmission cooler install...
    https://youtu.be/5DLkja6vXvc
    2020Platinum and bulldog93 like this.
  5. Jan 24, 2023 at 7:35 PM
    pursuit2550
    pursuit2550 New Member
    The is a procedure that has to be done, its just not put the jumper in. My take on this is, Drain out the pan, measure what you took out, and put the same back in. Usually 4 quarts. No sense in making your life hard.
    AZBoatHauler likes this.
  6. Jan 24, 2023 at 7:36 PM
    Tsm503
    2021 DC SR5
    Yeah I did that with the trans cooler install but wanted to try the “Toyota Approved” method. I’m told that it puts it into a lower idle for a more accurate level check. I dunno wanted to give it a shot
  7. Jan 24, 2023 at 7:36 PM
    pursuit2550
    It's out there. Toyota actually has instructions on doing it this way.
  8. Jan 24, 2023 at 7:37 PM
    Tsm503
    2021 DC SR5
    Yeah I know that, but wanted to figure out what’s the deal with not even getting past this point
  9. Jan 24, 2023 at 7:39 PM
    pursuit2550
    Did you do the procedure? I believe you have to shift from N to D back and forth till the D lights up then put it back in park, then sometime else. Something to that effect.
  10. Jan 24, 2023 at 7:39 PM
    Tsm503
    2021 DC SR5
    I’ve read and watch videos on it, just not sure what up.
  11. Jan 24, 2023 at 7:40 PM
    Tsm503
    2021 DC SR5
    Yup did that as well, with no avail
  12. Jan 24, 2023 at 7:40 PM
    pursuit2550
    Never mind my last question then.
  13. Jan 24, 2023 at 7:42 PM
    pursuit2550
    Maybe the jumper was in the wrong place or not far enough in to make contact. I did this before but can't remember on what vehicle. It worked out perfect.
  14. Jan 24, 2023 at 7:43 PM
    pursuit2550
    A scan gauge work also and is good for monitoring engine data. You should look into one.
  15. Jan 24, 2023 at 7:44 PM
    Tsm503
    2021 DC SR5
    Well if I can’t figure it out tonight I may just stick to the ScaneGauge temps from now. Just trying to do my best to stick to the “Toyota Method”. Thanks for the input though
  16. Jan 24, 2023 at 7:46 PM
    Tsm503
    2021 DC SR5
    Yup got her right here
    pursuit2550[QUOTED] likes this.
  17. Jan 24, 2023 at 7:48 PM
    AZBoatHauler
    So.Arizona
    I monitored the on-board data to watch the temp and it worked perfect. Coincidentally I shot the pan with an infrared and it was only a couple degrees cooler than the OBD reading so I think that would work in a pinch.
    Rocko9999 and pursuit2550 like this.
  18. Jan 25, 2023 at 8:54 AM
    Rocko9999
    Rocko9999 New Member
    This is good to know. I saw a few posts saying the infrared thermometer method was completely inaccurate-which I didn't believe. Good to know it's only a couple of degrees difference. Not enough to warrant the hassle of jumping the obd port and going through the procedure.
