2.5-3 inch lift - diff drop longevity?
Discussion in 'Suspension' started by Big J, Feb 2, 2019.
  1. Feb 2, 2019 at 8:59 PM
    Big J
    Big J [OP] New Member
    2020 4x4 crewmax
    Curious since a "diff drop" only angles the front down a little ... have any of you had problems from this? :confused:
    How long have you been running it?
    Any issues?
    How much did it really help CV angles? Pics maybe?
  2. Feb 2, 2019 at 9:52 PM
    08sequoia
    08sequoia New Member
    Beaumont ca
    08 Sequoia 4x4 SR5
    I did the diff drop on my Sequoia, I haven’t had any problems but it’s still been within a year. What pictures were you looking for? I can’t get them to you tonight, but after it stops I’d be happy to try and get some.
    Big J[OP] likes this.
  3. Feb 2, 2019 at 9:54 PM
    TheBeast The Beach
    not needed, it brings other issues by adding it.
    15whtrd likes this.
  4. Feb 2, 2019 at 10:03 PM
    08sequoia
    Beaumont ca
    08 Sequoia 4x4 SR5
    What issues?
  5. Feb 2, 2019 at 11:37 PM
    Big J
    2020 4x4 crewmax
    Pics of CV angles. Wondering if it is better to just chop, do a bigger lift, and drop the whole diff down.
  6. Feb 3, 2019 at 11:14 AM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Hello, dropping diff changes the front drive shaft angle to change at the u joint. No drop diff will change CV angles. Its It's a toss up to which one is easier way long term to change out. Some say oil level in diff is different when you change it and that can cause issues. Overall, after thousands of miles its usually boots that crack. The mod were you pull the boots more twords the inside on both inner boots might help. I say I want zero vibration. Diff drop spacers come in many sizes. I prefer the ones that dont drop it so much as to pinch the rear support or third one to cause metal to metal.
  7. Feb 3, 2019 at 11:58 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Lifted the front up 2.5” no diff drop at 40,000 miles, it’s now close to 70,000 and I haven’t had an issue. I hear a diff drop is for 3” and above.
  8. Feb 4, 2019 at 8:45 AM
    Big J
    2020 4x4 crewmax
    This was exactly why I asked ... wasnt sure if diff drops cause any other effects (like oil level changes) and the long term effects.
  9. Feb 4, 2019 at 9:15 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    I did a 3 inch lift a few hundred miles ago without a diff drop. I’m fairly certain I need one now. That or modify the boots somehow?
    Inner boot fins rubbing and showing some wear.
    Mountun Goat likes this.
  10. Feb 4, 2019 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t think it’s going to change that too much.
  11. Feb 4, 2019 at 12:39 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'm getting the diff drop when I purchase my 3" complete lift kit from @Toytec Lifts
  12. Feb 4, 2019 at 1:38 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    I put the 3" Toytec kit on at 40K.. At 99K now without any issues. I had to add a spacer to my Bud Built skid plate.
    Mountun Goat and Big J[OP] like this.
  13. Feb 4, 2019 at 1:48 PM
    Big J
    2020 4x4 crewmax
    Super nice pics! Angles look very good ... wonder why the other 3 inch pics look so different. Heck your angles look better than the trd pro pics. Lol
    TexMedic and Mountun Goat like this.
  14. Feb 4, 2019 at 2:26 PM
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    Yes, I was surprised to see the angles on the other trucks. Not sure what's different. Maybe the shock length is longer on the newer trucks?
  15. Feb 4, 2019 at 2:46 PM
    Big J
    2020 4x4 crewmax
    Not sure ... I didn't think there was a huge difference between 2nd and 3rd gen trucks for this. :confused:
  16. Feb 5, 2019 at 1:19 PM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    here is a shot of my 2011 on 6112s top setting no shims or anythign else with a diff drop. Was it needed or does it help I dont know for sure.
    I have since removed the sway ( Ilike it better without it) and put the stock skid plate back on
  17. Feb 8, 2019 at 2:57 PM
    Big J
    2020 4x4 crewmax
    I am noticing that some vendors tell you how much the diff spacers drop. BDS and Readylift as an example state 1" drop . Seems about right as a 3" lift with the diff drop gets you down to a about 2" (what a trd pro is) seems not all vendors say his much they drop with their spacers. Guessing this could also be a variable in if there a "problems" or not
  18. Feb 8, 2019 at 3:15 PM
    TheBeast The Beach
  19. Feb 8, 2019 at 4:36 PM
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    I think that was an accident waiting to happen due to poor install/design of the skid plate. The diff mount was left vulnerable when they made the ledge with the skid plate. I used a spacer to lower my skid plate at the front which keeps a smooth surface to slide over obstacles. I've slid the plate over several obstacles without damage. I also take it a bit easier if I know there may be contact at that location. There's also an oil pan under there that I like to keep in one piece whenever possible.
    Are there any failures linked to the use of the spacers themselves or is it only from making contact with an object?
  20. Feb 8, 2019 at 6:42 PM
    Big J
    2020 4x4 crewmax
    Curious.... this I'd exactly why I made this thread. Wanted to see if anyone had problems from these spacers. Not sure but glancing through the Tacoma thread ... looks like he hit something. But who knows :confused:
  21. Feb 10, 2019 at 7:04 PM
    r1-superstar
    DB
    UTAH
    Looks like an EXTREME example. I'm sure that OP was jamming when he nailed a boulder.
  22. Feb 10, 2019 at 7:07 PM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    Just a thought, and I may be wrong, but wouldn’t taller tires get ur CV back in alignment raising the hub? Obviously not cost effective, but if one is needing new tires or just got +3 of lift and new tires are on the shopping list then perhaps no need to drop (tilt) the diff. Those with more knowledge than me will hopefully chime in.
  23. Feb 10, 2019 at 7:44 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Please think about what you said, bigger tires will raise the whole hub along with the whole truck.
    Angry Gunny likes this.
  24. Feb 13, 2019 at 8:16 PM
    Big J
    2020 4x4 crewmax
    Yeah and that will bust just about anything. Lol
  25. Feb 18, 2019 at 12:42 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I thought perfectly straight was not good? Aren’t they made to be at an angle? Granted not an extreme angle.
  26. Feb 18, 2019 at 1:48 PM
    Big J
    2020 4x4 crewmax
    No idea what the angle should be. Maybe pics of OEM to compare :confused:
  27. Feb 18, 2019 at 4:51 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Then if lots of people are saying diff drops are not that good. Why are differential relocation brackets not being recommended more.
  28. Feb 18, 2019 at 4:55 PM
    Big J
    2020 4x4 crewmax
    I just started this thread to see if anyone could give some long term feedback of how running diff drops effected anything.
    Plus since it only rotates the front down, was interested to see if that caused any problems (like fluid shifting forward and messing up toyotas design)
    Oh and there seems to mixed reviews to make it more confusing as to how much it even helps angles Lol
  29. Feb 18, 2019 at 4:59 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    For cv joints specifically. If you can diff drop the same amount of lift you have should be exactly the same angle as oem. I don’t see how this would change any longevity at all? The driveshaft angle obviously will be different though. That being said, u joints are fine with a ton of different angles. As long as they don’t bind I can’t see it being an issue...
    I bought a diff drop kit but have yet to install for my 3.5” lift. Judging by my cv joint angle I will install.
    I guess I see how it goes in 10 years haha
  30. Feb 18, 2019 at 5:01 PM
    Big J
    2020 4x4 crewmax
    Lol true .... and in 10 years it won't matter. By then my boy will probably inherit it ... and ruin it as kids often do. Ha ha ha
    Black Wolf and Mountun Goat like this.
