1UPPER’s 17 CM SC Platinum Custom Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 1UPPER, Oct 20, 2016.
  1. Nov 6, 2016 at 6:44 AM
    #61
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    After removing the trim you can see there is lots of room below for the switches and wiring.
  2. Nov 6, 2016 at 6:46 AM
    #62
    1UPPER
    TEXAS
    Flux capacitor!
    I marked off my locations for the two switch holders. Now I'm going to cut them out. I wanted to make sure the switches will lay flat against the trim so I'll notch the raised edges on the side of the switch mounts.
  3. Nov 6, 2016 at 7:05 AM
    #63
    1UPPER
    TEXAS
    Flux capacitor!
  4. Nov 6, 2016 at 7:11 AM
    #64
    1UPPER
    TEXAS
    Flux capacitor!
    Here are the switches mounted in place. Next I'll do all the wiring to the switches.
  5. Nov 6, 2016 at 7:19 AM
    #65
    Man that's a lot of lights
  6. Nov 6, 2016 at 7:20 AM
    #66
    1UPPER
    TEXAS
    Flux capacitor!
    The radiance lights need two switches each. So four switches are just for two lights. But I still need to install rock lights and later roof rack lighting. Lol
  7. Nov 6, 2016 at 7:23 AM
    #67
    Mad max or what!?! lol all good man great job
  8. Nov 6, 2016 at 7:23 AM
    #68
    I'm looking to do single row led bar above license plate 30"
  9. Nov 6, 2016 at 7:29 AM
    #69
    1UPPER
    TEXAS
    Flux capacitor!
    Go to https://www.otrattw.net/ if you want to design or select a custom switch layout. You can select your switch holder, then your switch, color of you switch lighting, custom make your own images and wording. I got mine about four days after I placed my order.
    rons23 and 14tundra like this.
  10. Nov 6, 2016 at 7:31 AM
    #70
    1UPPER
    TEXAS
    Flux capacitor!
    I still have just enough room for an eighth switch.
  11. Nov 6, 2016 at 8:22 AM
    #71
    1UPPER
    TEXAS
    Flux capacitor!
    There are pressure clips on the switch holder and the switches themselves. So you can simply remove them with a flat screwdriver if needed.
  12. Nov 6, 2016 at 8:24 AM
    #72
    1UPPER
    TEXAS
    Flux capacitor!
    You can see the clips on the backside.
    Worriedman50 and NewImprovedRon like this.
  13. Nov 7, 2016 at 12:12 PM
    #73
    1UPPER
    TEXAS
    Flux capacitor!
    Getting ready to install my Rigid Radiance 40" light into the front grill.
    T-Rex266 likes this.
  14. Nov 7, 2016 at 2:44 PM
    #74
    1UPPER
    TEXAS
    Flux capacitor!
    Installed 40" Blue Rigid Radiance light in my TRD Pro grille. It turned out really good!
  15. Nov 7, 2016 at 2:51 PM
    #75
    TheBeast The Beach
    dang ! you are ready for Christmas !
    1UPPER[OP] likes this.
  16. Nov 7, 2016 at 10:23 PM
    #76
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    :thumbsup: Very impressive build!
  17. Nov 16, 2016 at 2:25 PM
    #77
    1UPPER
    TEXAS
    Flux capacitor!
    I finally got time to wire up my 40" Rigid Radiance front grill. I have the blue Radiance on in the photo. I'll be posting more picks soon of the rest of the build.
    darkknight2014 and T-Rex266 like this.
  18. Nov 16, 2016 at 6:47 PM
    #78
    1UPPER
    TEXAS
    Flux capacitor!
    My front 40" Blue Radiance bar in the TRD pro grill at night.
    rons23, CM-LENNY and TNTundra08 like this.
  19. Nov 16, 2016 at 6:54 PM
    #79
    Royalpeeps
    Royalpeeps Awesome!!!
    Chad
    2017 Blazing Blue Pear Tundra SR5 TRD Package
    20" Fuel Vapor wheels 35" Toyo A/T II Tires 3 inch Toytec Boss kit with SPC UCA NFAB Wheel to Wheel Black Textured Nurf Bars OCD Center Storage Organizer and tray
    So how hard was it to install the light int he grille? I like that look. And where did you get the light? It's a blue light?
  20. Nov 16, 2016 at 6:55 PM
    #80
    1UPPER
    TEXAS
    Flux capacitor!
    My 50" rear facing Radiance back light. I wanted to use the red light as part of my rear facing lights.
  21. Nov 16, 2016 at 6:56 PM
    #81
    1UPPER
    TEXAS
    Flux capacitor!
    TNTundra08 likes this.
  22. Nov 16, 2016 at 7:00 PM
    #82
    1UPPER
    TEXAS
    Flux capacitor!
    It's not that bad to install the light if your tedious about the install. You can install a 40" light bar perfectly in the TRD pro grill. I decided to use the rigid radiance light because you can run the backlights in red, blue, green, amber or white. Then you still have the spot lights like any normal bar light. My wiring was the biggest install since I have so many lights in various locations on the truck.
    040Tundra likes this.
  23. Nov 16, 2016 at 7:02 PM
    #83
    Royalpeeps
    Chad
    Yeah I saw that setup you have. Impressive. So while bar did you get? You can change the colors?
  24. Nov 16, 2016 at 7:08 PM
    #84
    1UPPER
    TEXAS
    Flux capacitor!
    The rigid radiance only allows you to have only one back light color and then the main spots are white of course. So I picked a blue back light for the front and the rear is a red back light that I can legally run while on the road. I already stopped a DPS cop to double check and save me from a possible ticket. Haha
  25. Nov 16, 2016 at 7:11 PM
    #85
    Royalpeeps
    Chad
    I like the blue backlight on the front. Would work well with my truck.
  26. Nov 16, 2016 at 7:50 PM
    #86
    1UPPER
    TEXAS
    Flux capacitor!
    You have a good looking truck Royalpeeps! I noticed you have black handles and almost no chrome except for the front bumper ends. Have you ever thought about doing the bumper ends in black or the same blue color?
  27. Nov 16, 2016 at 7:52 PM
    #87
    Royalpeeps
    Chad
    Planning on having them line x'ed. Or powder coated. The last of the evil chrome. LOL. Plasti dipping all the badges maybe tomorrow night.
    TRD15559 likes this.
  28. Nov 27, 2016 at 11:07 AM
    #88
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @TX 2017 Platinum Tundra Dude!! You have a sweet ride!! Damn nice truck bro. All those wires would send me into a frenzy. I do want a 40" for my Pro grille but thats about it. Maybe change out my fog lights with some Rigid lights. All I can say is I'm very impressed with what you have done! Great job!
  29. Nov 27, 2016 at 5:20 PM
    #89
    Tfri4x4
    Tfri4x4 New Member
    14' tundra
    Perfect spot for your switches that's where mine are. I was worried about the reach but it doesn't bother me at all. Regarding rehearing to 4:88...is it fair to say it unneeded if you supercharge it. Would the power make it level back out for lack of a better term?
  30. Nov 27, 2016 at 5:29 PM
    #90
    1UPPER
    TEXAS
    Flux capacitor!
    Since I'm running 37" tires it would be a lot easier on the drivetrain, gas mileage and performance to run the 4:88 gears versus the stock 4:30 gears.
