1st gen with King Coilovers and spindle lift?
Discussion in 'Suspension' started by AWilliams, Apr 21, 2021.
  1. Apr 21, 2021 at 8:36 AM
    AWilliams
    AWilliams [OP] New Member
    As it stands I currently have a 2003 1st Gen tundra AC 4x4 with King coilovers, TC uca's, rear 5100, 285/16 tires, and diff drop mod. I'm wanting maybe a couple more inches of lift. I think my king coilovers are putting me at about 2.5" so it's basically leveled. Can I do a spindle lift without causing any major wear problems on the front end like cv boots/ joints, lbj, wheel bearings etc? I like the size tire I have but they look stuffed I want a little bit more clearance between the top of the tire and the top of the fender well..like 2". If I can do this without causing more problems what would be a decent kit to get...thanks
  2. Apr 21, 2021 at 8:41 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you have cv boots you cannot do a spindle lift(2wd only)
    des2mtn likes this.
  3. Apr 21, 2021 at 9:42 AM
    AWilliams
    Bummer.... I looked it up and I thought I saw spindles for the 4x4s I could be wrong though. Anything I can do to get another 1.5-2" in the front?
  4. Apr 21, 2021 at 12:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are probably spindles, but they are beefier, not lifting.
    no you cannot go any higher without an RCD drop bracket lift (which wont work with your coilovers properly) anyways
    des2mtn likes this.
  5. Apr 21, 2021 at 12:40 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Hbjeff likes this.
  6. Apr 21, 2021 at 3:07 PM
    AWilliams
    Ok,. Sorry still learning. So what sort of front suspension shocks springs if I would want to run those brackets getting rid of my Kings?
  7. Apr 21, 2021 at 3:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is more lift gonna make that much of a difference? Are the tires rubbing?
    des2mtn likes this.
  8. Apr 21, 2021 at 3:28 PM
    des2mtn
    SW
    Tonto cover
    I agree, does it make that much of a difference? You'll be sacrificing your ride quality getting rid of the Kings as well. What all do you use the truck for?
    A body lift might be what you want. It won't affect your ground clearance but it will affect your appearance.
    Hbjeff[QUOTED] likes this.
  9. Apr 21, 2021 at 3:58 PM
    Professional Hand Model
    Hand Protectors
    Hbjeff likes this.
  10. Apr 21, 2021 at 6:10 PM
    AWilliams
    Just for looks...it's a 3rd vehicle that hardly gets driven. Don't use it for any work type duty. Pulls my bass boat a few times a year.
  11. Apr 21, 2021 at 6:22 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Body lift would probably suit you best if they make one
    des2mtn and AWilliams[OP] like this.
  12. Apr 22, 2021 at 9:11 AM
    des2mtn
    SW
    Tonto cover
