1st Gen Tundra Tire Setup
Discussion in '1st Gen Tundras (2000-2006)' started by YOUNGBUCK34, Aug 16, 2020.
  1. Aug 16, 2020 at 11:02 AM
    YOUNGBUCK34
    YOUNGBUCK34 [OP] New Member
    Rico
    2005 Double Cab 4x4 SR5 V8
    So I just got my 2005 DC Tundra a little more then a month ago and its ready for some new tires! I am running 265/70/17 right now and would like to achieve the biggest tire I can without a lift kit. I believe the truck has a leveling kit on it and I think I can fit 285/75/17 with some spacers so they don't hit the upper control arm. Any thoughts?
    YardBird likes this.
  2. Aug 16, 2020 at 11:44 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    285’s will fit with a leveling kit and wheels that run 4.5 inch backspace. Still probably have some rub at full lock on the frame. Just part of it. You can go aftermarket for wheels or run wheel spacers, whichever your more comfortable with
    give this thread a look too, it’s been a ton of help planning out what I’m gonna need for 33’s
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    Stuck in the '00s likes this.
  3. Aug 16, 2020 at 12:17 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    285/75/17 and 285/70/17 is quite a bit different in terms of rub factor. Stick with the latter.
  4. Aug 16, 2020 at 2:13 PM
    Casper421
    In the woods
    06 DC
    Don’t try 285/75’s without at least a 2” lift and a lot of cutting and bashing. Stick with 285/70’s and trim.
    Sunnier and abcinv like this.
  5. Aug 17, 2020 at 1:18 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I vote 275/70's :thumbsup:
    Lupe, Toyoda Tundra, whittkl4 and 9 others like this.
  6. Aug 18, 2020 at 1:23 AM
    abcinv
    Tommy
    South of ATL
    KO2's 275/70/17's
  7. Aug 18, 2020 at 3:55 AM
    Professional Hand Model
    Hand Protectors
    So far the MAX on 285/75/r16 that still rubs slightly at full full, but isn’t a deal breaker is Michelin Defender.
  8. Aug 18, 2020 at 4:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There is one, but it's a bit out of the way and not in first gen territory.
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
  9. Aug 18, 2020 at 5:13 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  10. Aug 18, 2020 at 5:40 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
  11. Aug 18, 2020 at 6:42 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I have 285/75/17 with a 3" lift and I rubbed. I had to trim the pinch welds on the firewall and very little trimming on the front bumper plastic. Currently still using the stock UCA's too.
    MNtundra likes this.
  12. Aug 18, 2020 at 6:47 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    What brand model tires are you running?
  13. Aug 18, 2020 at 6:48 AM
    2006Tundra
    Lou
    Long Beach, CA
    Toyo Open Country ATll
    revtune and MNtundra[QUOTED] like this.
  14. Aug 18, 2020 at 6:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    revtune and MNtundra like this.
  15. Aug 18, 2020 at 10:51 AM
    YOUNGBUCK34
    Rico
    So what I have gathered from is that I can fit 275/70/17 no problems since I have the leveling kit. Do you think i could get away with 275/75/17 if I added 1.5 inch spacers, or even bigger?
  16. Aug 18, 2020 at 11:01 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Just go with 285/70/17 and adjust/trim if needed. Do you plan on aftermarket wheels or stockers?
  17. Aug 18, 2020 at 11:02 AM
    YOUNGBUCK34
    Rico
    I plan on getting some methods on down the road.
  18. Aug 18, 2020 at 11:03 AM
    YOUNGBUCK34
    Rico
    I would like not to do any trimming though if possible.
  19. Aug 18, 2020 at 11:38 AM
    Casper421
    In the woods
    06 DC
    265/70/17
    revtune likes this.
  20. Aug 18, 2020 at 1:53 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Yep, had a similar experience running 295/70/17 with a 3 inch lift.
  21. Aug 18, 2020 at 2:42 PM
    Casper421
    In the woods
    06 DC
    FWIW: 285/75r17 st maxx on scs stealth 6’s, Spidertrax spacers on 2” lift and still rub after cutting pinch weld and taking a bfh to the firewall. Firewall tubing is in my future.
    Darkness likes this.
  22. Aug 18, 2020 at 7:12 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    I think you will be fine with 275/70R17 if you have a leveling kit. That’s the route I am going after just putting 5100’s on all around.
    First Gen Tundra (2000-2006)
    1.5 – 2″ Leveling Kit (or less)
    When installing a leveling kit, you might be able to fit some wider tires than what we have listed. It may require some trimming though, but it is possible.
    Max tire sizes are:
    • 16″ rims: 265/75 R16 – one inch taller but same width as factory
    • 17″ rims: 275/70 R17 – 1.5 inches taller and 4/10ths wider than factory
  23. Aug 18, 2020 at 7:27 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  24. Aug 18, 2020 at 7:52 PM
    Casper421
    In the woods
    06 DC
    It’ll happen at some point. But then I’ll want to swap in some 4.56’s and an arb. I’ll need the gears if I get a camper but then I’ll probably want to stick with 34’s. All I know is that I still rub when stuffed and I need to fix that.
    bdbrown528 and Darkness[QUOTED] like this.
  25. Aug 31, 2020 at 4:18 PM
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Mannnn that isn't what I wanted to hear. I reaalllly want 285/75s :(
  26. Aug 31, 2020 at 5:46 PM
    2006Tundra
    Lou
    Long Beach, CA
    I have a 3" lift with 285/75/17. I shaved the pinch welds and installed 1.25" spacers with no issues.
    itsWarrior likes this.
  27. Aug 31, 2020 at 6:26 PM
    If you ever want to move to another setup, I may want your dregs :D
    abcinv[QUOTED] likes this.
  28. Sep 1, 2020 at 5:25 PM
    abcinv
    Tommy
    South of ATL
    I’ll keep you posted!
  29. Nov 5, 2020 at 2:05 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    How much lift do you have?
  30. Nov 5, 2020 at 3:26 PM
    abcinv
    Tommy
    South of ATL
    Just 2" in the front; leveled out nicely
    onesojourner[QUOTED] likes this.
