1st Gen Tuff Country LiftKit ?
Discussion in '1st Gen Tundras (2000-2006)' started by Frankyfrank40, Mar 3, 2021.
  1. Mar 3, 2021 at 9:10 PM
    Frankyfrank40
    Frankyfrank40 [OP] New Member
    05 Tundra DC 2WD
    4.5in Tuff Country Lift Kit 315/75/16
    I recently upgraded from a 00’ Toyota Tacoma to a 05 Tundra, after purchasing the truck I realized the truck has the 4.5in tuff country lift installed, saw the upper ball joint spacers... and well, a little too sketchy for my liking. But I’m hoping someone on here has ran into a similar issue and found a way to eliminate the upper ball joint spacers and maybe found a longer Spindle/Knuckle to use instead? Thank In advance! :)
    2005 Toyota Tundra Double Cab 2WD
  2. Mar 4, 2021 at 12:22 PM
    Tough country has a solid spindle for the 4.5-5" lift I believe. Not sure if they are sold separately or not. Someone else may be aware of other options. RCD kit was for a 6" lift and also had a longer spindle.
