1st Gen OME lift kit issues
Discussion in 'Suspension' started by rock climber, Oct 7, 2019.
  1. Oct 7, 2019 at 3:33 PM
    rock climber
    rock climber [OP] New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Hi All,
    I installed the OME lift kit from toytec with the progressive 3 leaf aal in the back (left in the overload leaf). I've got a couple of problems.
    My alignment shop could only get 0 caster and recommends new upper control arms. My front end also sits higher than the rear and it feels like I got at least 4 inches of lift, but I don't know if that's because it was sagging before (I didn't think to measure before). I'm 24 inches from the center of the hub to the fender.
    I'm worried that I'm going to run into other issues with the lift like cv axles and ball joints so I'm debating going with a smaller lift up front.
    Couple of questions
    1. What are my options for a 1.5 lift? The only one I know of is Bilstein 5100
    1a. I Don't have stock coils so if I got EIbach coils with bilstein 5100 at the lowest setting how much lift would that be?
    2. I I go 1.5 lift will I still need new UCA's?
    3. If I get new UCA's should I be ok or am I going to keep running into wear and issues?
    I do 4 wheel occasionally like Moab, but nothing where I need a huge lift
  2. Oct 7, 2019 at 3:59 PM
    rock climber
    Thanks!
    It's a 2001. Lift has been on for a month and I've been to moab in that time so I'm guessing it's mostly settled.
    Tundyfundy likes this.
  3. Oct 7, 2019 at 4:12 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    OME Makes different front springs for the same truck. Which ones did you get? Why not go down in the springs?
    Ex: my Tacoma I could get OME 880, 881, 882, and 883.
    880 would be stock height replacements. 883 would only be recommended for a crew cab with a heavy bumper and would still provide 3” of lift.
    Black Wolf, Mountun Goat and 15Yota like this.
  4. Oct 7, 2019 at 4:12 PM
    15whtrd
    15whtrd Mr. Blonde
    How much lift did the OME kit claim to give?
  5. Oct 7, 2019 at 4:17 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You only need upper control arms over 3 inches or so although they will help with the ride and off road durability. If your going to get aftermarket coils just get the bilstein 6112, you can set it at 1.9 inches and be done. I love mine. The bilstein 5100 and 6112 are adjustable but not sure what exact heights but you should be able to get anywhere from .6 or so inches to 2.5 inches with both the 5100 and 6112. New UCA's wont wear anything prematurely persae but they allow the shop to properly align the truck with the lift, If you are worried about maintenance do with a Moog style ball joint type A arm. Not having the truck properly aligned will cause it ride poor and wear parts, especially tires, faster. Your truck is different so it all depends on what parts are available but im sure theres a bunch of options.
  6. Oct 7, 2019 at 4:47 PM
    rock climber
    Unfortunately for the 1st gen options are pretty limited. Toytec said they actually designed the OME lift for the tundra and the coils I have are the only real option. I was hoping maybe they goofed and gave me heavier duty springs.
    Thanks! I've really debated the 6112, it's just hard to spend that money when I just spent more on the OME lift.
    2.5 inches. I asked Toytec and they said it's hard to say for sure on the 1st gen because it was so low already in stock form.
    15whtrd[QUOTED] likes this.
  7. Oct 7, 2019 at 5:01 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds iffy. You’re around 4” from a claim of 2.5. Doesn’t sound right. I know with the 5100s they can be assembled wrong. The lower spring cup can be mounted upside down and give excess lift. Very unsafe since it’s not encapsulating the C-clip. I’m not sure how the OME works. Maybe a pic could help.
  8. Oct 7, 2019 at 7:56 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The 884's are 1/4" shorter than the 885's and carry the same spring rate.
    I would start there.
    Tech specs for 2885
    • Free Height: 395mm
    • Bar Diameter: 17mm
    • Spring Rate: 590 lbf/in
    Tech specs for 2884
    • Free Height: 390 mm
    • Bar Diameter: 16.5 mm
  9. Oct 7, 2019 at 7:59 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    You didn't include what model or year you had.
    Toytec didn't develop anything OME.. ARB did.
    See my above reply for different springs.
  10. Oct 8, 2019 at 8:14 AM
    rock climber
    Thanks! That's great information!
    Black Wolf likes this.
  11. Oct 8, 2019 at 8:24 AM
    @Scuba is correct. As mentioned the OME properly configured for the weight load up front is around 2.5". Mine on my 4X4 07 ended up with 2.75". I think ToyTec meant that they will configure the coilovers to your needs.They didn't design them. I had an AAL and Toytec shackles out back. Keep in mind I had the 2nd gen.:thumbsup:
  12. Oct 8, 2019 at 8:26 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Love my OME 612 system
    got 2.75 lift
  13. Oct 8, 2019 at 8:28 AM
    rock climber
    Yeah, I misspoke, Toytec didn't design them what I've heard is that they kind of cobbled together different parts that fit, but weren't actually designed for the first gen Tundra.
  14. Oct 8, 2019 at 8:40 AM
    The 2.5" is for the 2nd gen and up Tundras and you will get at least 2.5" easy. The OP's coilovers seem to be a custom setup so there is no way to know how much lift you get until installed.:thumbsup:
  15. Oct 9, 2019 at 12:05 PM
    rock climber
    Sorry, another question. The OME ride is amazing in almost all situations, but when the front end drops from flat like in a construction area where part of the road is lower, it's very rough. Almost like a solid hard hit. Same when going down the back side of a speed bump. I'm wondering if the spring rate may be slightly too stiff and so I don't have any sag or negative travel. Thanks to Scuba's awesome research it looks like I can get OME 2882 coils which are the same length but a 500LB spring instead of 590LBS. Theoretically that should lower my front end and also provide a softer ride, but is it going to be too soft?
    I don't have any options on the front, it's all stock. Stock bumper, stock winch.
    Also, does anyone know the stock ride heights of the 1st gen access cab measured from the center of the hub to the fender?
  16. Oct 9, 2019 at 1:36 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I love my 6112/5160s. I have my 6112 set at the Bilstein recommended max height for my truck, 1 inch. The front is 22 1/4" from center hub.
  17. Oct 10, 2019 at 2:55 PM
    rock climber
    Perhaps this is a really stupid question, but I if went with the OME 2883 coil, it's 20mm shorter but same spring rate. Would I run into any issue doing that? Would the spring actually be loose in the shock at full extension or would there still be enough preload?
  18. Oct 11, 2019 at 7:38 AM
    rock climber
  19. Oct 11, 2019 at 7:55 AM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    With you Gen 1 if you go over 1.5" -2" of lift, then you really need to strongly consider other mods.
    You may be getting more lift than advertised due to your aftermarket springs.
    In addition to alignment issues, the UCAs of 1st gen can't handle much lift. 1.5" over stock is fine, but anything more and the stock ball joints can't articulate enough and the shaft of the ball joint will slam against the rim of the female part of the ball joint everytime the front suspension is overextended, (like when dropping off of the back side of a speed bump.) This will make a loud clunk and also ultimately cause failure of the ball joint.
    Also over 1.5" -2" of lift on a 4x4 1st gen you will need a diff drop. If you don't, your cv boots will be over extended and tear apart. The cvs themselves are going to see premature wear.
    Bilstein 5100s are awesome shocks for the 1st gen.
  20. Oct 11, 2019 at 8:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I’m not certain man, sorry.
    We used the 883’s on 1st gen Tacoma’s and 3rd gen 4Runners back in the day.
    It would be worth while to start searching and seeing if the part number for your shocks matches the part number of the shocks one would use for a, say, 2000my 4Runner.
    I can do some searching later when I’m next to a computer.
  21. Feb 11, 2021 at 1:02 PM
    Kings
    Kings New Member
    Reviving this thread because I have a similar issue. I installed an ARB OME front lift kit with 2884 springs and shocks. Was supposed to give 2" of lift and I got closer to 4", partially due to how saggy my original springs were.
    Did you get your lift issue resolved?
  22. Feb 11, 2021 at 1:11 PM
    rock climber
    I did, but I wouldn't recommend the route I took. I sold the OME shocks to a member here and bought the toytec adjustable coilovers, they're great, but it ended up costing me a lot. I would get new OME coils.
    Two questions, are you sure you got 2884 coils and not 2885? Also, what is your hub to fender measurement?
  23. Feb 11, 2021 at 1:18 PM
    Kings
    Kings New Member
    I had the same hunch. The sticker on the spring said 2884 but I wonder if it was mislabeled. Got it from 1stGenOffroad.
    My before measurement (from center of hub to fender) was 19 1/4" and the after measurement is 23" after driving on it for an hour.
  24. Feb 11, 2021 at 1:21 PM
    rock climber
    I think stock was around 20" so you got 3" over stock which is at the upper end of what our trucks can do without other issues. I ran my toytec coilovers at 23, but had SPC upper control arms. If I were in your shoes I'd either keep the lift and get new UCA's or go down one level to the 2883 coils. You can sell the 2884 for pretty close to what you paid for them.
    Kings[QUOTED] likes this.
  25. Feb 11, 2021 at 1:51 PM
    Kings
    Kings New Member
    Thanks for the replies, this forum is fantastic. The two options you laid out are what I've been bouncing around. I don't need this much lift and I only plan on running 265/75r16 so I'll probably be stepping down to the 2883 coils.
  26. Feb 11, 2021 at 4:09 PM
    rock climber
    I think that makes the most sense and is the most cost effective.
    I loved how well controlled the OME shocks were.
  27. Jul 19, 2021 at 12:59 AM
    gascap
    gascap New Member
    2002 Tundra
    Your thread is very informative. Tell us what springs and shocks you have decided to run with. Your trk year and model, etc might be same and would help more than you think with some here.
  28. Jul 19, 2021 at 9:25 AM
    Kings
    Kings New Member
    Got an 06 DC 2wd. I ended up selling the OME shocks and keeping the 2884 coils. I put Bilstein 5100s (on the lowest perch) in the 2884 coils and the lift was much more what I was hoping for. My front measurement is now 22" and I expect that to settle down a little further. Turned out to be the right combination for my truck.
    gascap[QUOTED] likes this.
  29. Jul 20, 2021 at 11:45 PM
    gascap
    gascap New Member
    2002 Tundra
    Anyone know what the inside diameter of OME coils are? Heard the OME coils will need 05+ Tacoma coil seats because OME springs are to narrow for OEM Tundra coil seats.
  30. Jul 21, 2021 at 7:31 AM
    Kings
    Kings New Member
