1st Gen Light Bar Placement
Discussion in '1st Gen Tundras (2000-2006)' started by rock climber, Dec 17, 2019.
  1. Dec 17, 2019 at 4:06 PM
    rock climber
    rock climber [OP] New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Trying to find a good spot to put a light bar. My last truck I just attached to the top of the front bumper and it worked fine, but I'd prefer a more stealth install this time. What have you all done?
    I've thought about installing it in this gap, but do you know if it's a critical airflow area?
  2. Dec 17, 2019 at 4:23 PM
    Professional Hand Model
    Hand Protectors
    That an ideal spot for stealth. Its also a critical area for air flow. How critical and how much would your light reduce the flow? Nobody knows.
    FrenchToasty and Aerindel like this.
  3. Dec 17, 2019 at 4:50 PM
    Outbound
    Aaron
    Northern Alberta
    Loads of people put them in that spot on all makes and models of vehicles. I highly doubt it's going to cause any issues with airflow. I'll be putting a lightbar in there myself next summer.
  4. Dec 17, 2019 at 4:52 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Ill do one one day.....
    No money any time soon :(
  5. Dec 17, 2019 at 5:56 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Prior owners of my trk had brackets for a light bar permanently attached within upper front grill. The light bar would attach to the brackets that extended out from the grill by an inch or so. The light bar itself was easily put on the bracket for going out in the woods and easily removed by 2 screws. Nice setup by not mounting it permanently, but instead using the light bar as a removable attachment. A good move when being in populated parts of Central FL and down.
    Without the light attached, the brackets were not noticeable from a short distance and didn't stick out like a sore thumb when right up close to the hood.
    The prior owner did a good job.
    Or, cut out or drill a line of 2" or larger circular holes across the upper portion of the skid plate. That should replenish the lost air intake from bumper.
    bmf4069 likes this.
  6. Dec 18, 2019 at 7:02 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Mine was already installed under the bumper. I've never had any problem with it but, it is, without question, low hanging fruit. The opening you reference is blocked in the middle by the license plate on my truck. I've thought about putting light bars on each side, though. For now, my current bar has worked well enough and I've yet to encounter any problems.
  7. Dec 18, 2019 at 7:07 PM
    Aerindel
    Aerindel New Member
    Montana
    Luckily, our trucks come with a temperature gauge, so we can know if they overheating or not.
    I read somewhere that most vehicles have something like 600% more cooling capacity then they generally need, because they have to be able to cope with cruising at 60 on a nice fall day, and pulling a load up a hill when its 120º outside and the AC is running equally as well.
    Most likely, the reduction in cooling is trivial compared to what you actually need. But like I said....we have a gauge. If you are worried, make a cardboard model of your light bar, tape it in place, drive, observer the results.
    Mt.Andoo likes this.
  8. Dec 18, 2019 at 7:17 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    MVIMG_20190831_192312176.jpg I've had my 32" light bar on my tundra for 3yrs with no problems with overheating and it is low so it projects light out very well.
  9. Dec 18, 2019 at 11:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The bumper should be fine. I’m looking at a slim 30” to put there myself. Most of your cooling comes from the grill
  10. Dec 19, 2019 at 4:17 AM
    Hand Protectors
    For this instance the concern (albeit small) would be for the A/C coil air flow reduction. The A/C coil is the first rad coil in front before the the actual engine radiator.
    FYI, I have a required front license plate covering about 1/3 of that lower opening. Wish I could move it, but laws. My A/C works fine.
    evanhmn likes this.
  11. Dec 19, 2019 at 7:58 AM
    rock climber
    HAdn't thought of that, but it's a great idea. Have to wait for summer though for it to really make a difference, right now in 17 degree weather I don't think overheating would be a problem :)
    I think what I'll most likely do is put it where you have yours, but I"m going to cut out the bumper and recess the light bar. As others have mentioned lower and the license plate blocks out part of the light bar, I was just going to deal with it, but up higher I don't have any concerns with airflow or the license plate.
  12. Dec 19, 2019 at 9:18 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I mounted my light bar that exact spot and it doesn't cause any issues. My front license plate bracket was already missing/broken so I just mounted my plate directly to the bumper. There is enough room around the light bar that is not going to cause any air flow restriction so don't let that stop you lol. I'm all about hiding stuff and there was no way I was going to mount it outside of the truck. I made some 'brackets' and used existing mount points so I did not have to drill any new holes. It can all be removed and you would never know it was there.
  13. Jan 9, 2020 at 11:13 AM
    Mid-Atlantic Slots
    Mid-Atlantic Slots Living the semi retired life, Life is good!
    Wayne
    Franconia Va
    2004 Tundra Dbl cab SR5 / TRD 4wd
    A few little things
    I have mine here.
  14. Jan 9, 2020 at 2:05 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's a pretty precarious location with it sticking out like that. I'd be worried some jabroni would take it out when parallel parking in front of me.
    SouthPaw likes this.
  15. Jan 9, 2020 at 9:05 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Just mounted my two fog lights to the brush guard I got for Xmas. Wife bought me the Tyger Brush Bar and it is amazing.
    Then found out you can't run 6 lights at one time....lol....after local PD pulled me over on the way home from the gym at 1:30 am. So I run stock fogs OR my new fogs, not both...LOL..
  16. Jan 10, 2020 at 7:39 AM
    tenntundra
    Walter
    Tennessee
    I haven't had it hit yet,but that's not to say it won't happen.It seems like it doesn't matter any more where you park someone isn't paying attention to what they are doing!!
  17. Oct 24, 2021 at 7:24 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Wanting to do this to my 06 Tundra…anyone have a how-to thread for this?
    niblick_10 likes this.
  18. Oct 24, 2021 at 8:12 PM
    Bubbadog
    Bubbadog New Member
    I am also interested in placing a light bar in this area. Any install advice/tips?
  19. Oct 24, 2021 at 8:58 PM
    SouthPaw
    2000 Limited 4x4 AC
    1stgentundradriver likes this.
  20. Oct 25, 2021 at 9:21 AM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Unfortunately this is the best picture I have of the light bar placement. As stated above i didn't want to mount it in the existing space for air flow reasons. So I cut my bumper and mounted it behind, made brackets and welded them on. It's still low enough, and recessed into the bumper so it's a little more protected, hidden, and cleaner
  21. Oct 25, 2021 at 4:54 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
  22. Oct 25, 2021 at 4:54 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Looks good!
  23. Oct 30, 2021 at 9:03 AM
    smokey0810
    Here a pic of the brush guard installed. Has a mounting point on the plate above the stars. Wiring was pretty easy, except for trying to find a place to run the wire into the cab. Hit a live wire and bare metal with the screwdriver I was using, and lost my electronic throttle for a few. Otherwise, mounted the switch in a blank space next to my heated mirror button.
    abcinv likes this.
  24. Apr 15, 2025 at 10:49 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Reviving old thread. Looking for something like this I found on FB. Anyone install one of these? Owner says he bought it with the truck and doesn't know who made it.
    Elevatorguy and Kimosabe like this.
  25. Apr 18, 2025 at 11:35 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I've been looking for something similar without much success. I think you can find those for the tacoma and newer tundras but I haven't wanted it bad enough to try and see if any others will fit.
