1st Gen lift poll - OME or Bilstein?
Discussion in 'Suspension' started by OldSoul76, Jan 6, 2016.
Which lift?
  1. Toytec Ultimate (Bilstein)
    5 vote(s)
    10.0%
  2. Old Man Emu
    25 vote(s)
    50.0%
  3. Toytec Boss
    5 vote(s)
    10.0%
  4. Bilstein 5100 (ride height adjustable)
    15 vote(s)
    30.0%
  1. Jan 6, 2016 at 8:19 PM
    OldSoul76
    OldSoul76 [OP] New Member
    Lets see what everybody thinks.
    Basically I need new shocks, and I want a lifted/leveled truck.
    http://toyteclifts.3dcartstores.com/Ultimate-lift-kit-with-Bilstein-shocks-for-Tundra_p_395.html
    or
    Old Man Emu
    http://toyteclifts.3dcartstores.com/25-OME-Lift-Kit-for-00-06-Tundra_p_1227.html
    (yes, with the OME kit a BPV bracket and diff drop kit will be purchased separately)
    or
    Toytec Boss
    http://toyteclifts.3dcartstores.com/BOSS-Suspension-System-for-2000-2006-Tundra_p_1140.html
    This will be a "daily driver" with no serious off-roading, only the occasional off road exploring.
    I'm most curious about ride quality and durability.
    I do not plan on ever adding heavy bumpers or a winch.
    Hope to stuff 285/65r18 tires.
    Ride quality of each shock/coilover?
  2. Jan 6, 2016 at 8:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have a second gen so I really can't comment on the first gens however I voted Bilsteins because that is what I purchased for my truck. I have never had OME so I can't tell you a comparison.
    I am happy with my choice. I kept them at the stock setting for now. I am pretty sure it is set at 3".
  3. Jan 6, 2016 at 9:01 PM
  4. Jan 12, 2016 at 8:44 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    I'm running the OME setup and have no complaints. It's been great on washboards. I've never run the Bilstein's on the Tundra so I can't really compare apples to apples, however I've run Bilstein's on other trucks and would expect them to provide a little more plush ride on the street.
    Just know that the OME setup was originally designed for 2nd gen Tacoma's. OME never meant for them to be used on the Tundra. I decided on the OME based on low maintenance/reliability along other reviews of people having them on their Tundra. I think Slee was the one who originally offered this setup for Tundra's.
    TLDR; I have OME and would do it again.
  5. Jun 15, 2016 at 4:11 PM
    OldSoul76
    I'd be thrilled to get a few more 1st Gen. Tundra people to weigh in on the original post, especially @ToyTec Lifts ! Its a big investment with a lot of variables and very few people have experience with all Toytec Boss, Bilstein and OME suspension.
  6. Jun 15, 2016 at 4:54 PM
    Mike Tread lightly.
    south carolina
    For my 1st gen it's still stock. I don't want really any lift on mine for reasons.
    OME I might go with but really I haven't got to that point with it. I need adjusting front ones. Toytec maybe. Alcan is the one, will do my rear springs, that's the only for sure things.
  7. Jun 15, 2016 at 5:02 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    I'm running OME 885 springs on 90004 struts. Lifted the front about 3". Love the setup. Rides amazingly on washboard and rough road..
  8. Jul 27, 2016 at 8:12 PM
    OldSoul76
    do you know why the OME setup is meant for 2nd gen Tacomas, yet will work with 1st gen Tundras? ...and it doesn't seem like all 2nd gen Tacoma lift kits work with 1st gen Tundras.
  9. Jul 28, 2016 at 6:40 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    A 2nd gen taco and 1st gen Tundra are actually fairly close in size. The extended and collapsed length of the OME strut is a perfect match for the 1st Gen Tundra (its practically identical to the 5100). The OME 885/886 coils are a HD coil for a Tacoma if you have extra weight upfront like a bumper/winch. So for a stock Tundra they match perfectly.
    The reason I went with the OME setup vs Bilstein or a coilover was the bulletproof reputation. I wanted something that would last and I wouldn't have to worry about. That said I think I'd skip putting the OME shocks out back. I'd go with a longer Bilstein.
  10. Jul 28, 2016 at 3:29 PM
    I asked ToyTec about the rears. Toytec recommended sticking with the new OME nitro charger shocks for the rear since they were specifically three staged valved for my Tundra. Don't mix and match is what was said to me. Go with the complete system. I did. No regrets at all. I would assume the same for 1st gen OME suspension. Call ToyTec.
  11. Jul 28, 2016 at 4:16 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I have ome up front, light racing spc ucas and a 3leaf aal out back with toytec boss shocks hows that for a conglomeration! I had full ome on my taco. Which is why i put it on the front of the tundra. Bullet proof on and off road and maintenance free. Cant beat the ruggedness and it still rides just fine on all terrains u throw at it. Out back i went with the boss shocks because i leanred from the taco, the ome shocks are pretty short on purpose. They limit the articulation for warranty and longevity reasons. My truck rides very well
    csuviper and twotrack like this.
  12. Jul 29, 2016 at 1:51 PM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    The OME's out back restrict down travel even with the stock leafs. I bought everything through Toytec as well, great people to work with. I'd just recommend something longer in the rear.
    Black Wolf likes this.
  13. Jul 29, 2016 at 11:40 PM
    I have zero restriction with my new OME Nitro Chargers out rear. Plenty of travel. Found out two weekends ago up in the CO Rocky Mountains when I first put my OME setup to the test. But then again this is on my 2nd gen 07. You are right about ToyTec. OME does have new shocks. Maybe longer travel for 1st gens with the new Nitro Chargers. Maybe. ToyTec folks would know for sure. :thumbsup:
  14. Oct 18, 2018 at 11:37 PM
    tpang03
    tpang03 New Member
    2002 Tundra Access SR5
    I just bought the OME front and rear with icon AALs. Would you say new UCAs would be necessary?
  15. Jan 10, 2019 at 12:47 PM
    Themud
    Themud New Member
    Themud
    Silver Trd 2006 DC 4x4
    2.5"/1.5" level OME COILS, AAL, ARB Lockers front and rear, Softopper.
  16. Jan 10, 2019 at 12:52 PM
    Themud
    Themud New Member
    Themud
    I have ome lift with front and rear and aal.
    First thing that happened was steering rack. Replaced, but busshibu went bad within weeks. New bushings.
    Felt popping up front turning. It was lca bushings. I just put new lca r and left, all new BJs too. The 4x4 shop said UCA not necessary with just the small lift, but wonder if the extension was needed.
    Of course OEM BJs all the way. My toy tech is a friend and has an 05, but no lift. Said UCA don't take the beating as lca or the ubj.
    speedtre likes this.
  17. Feb 6, 2020 at 12:02 PM
    TurtleWrench
    TurtleWrench New Member
    Dom
    2013 Sequoia Platinum
    I knwo this is old but I am wanting to buy the ARB OME LEVEL KIT - 2000-2006 TOYOTA TUNDRA Kit with 2887 springs.
    I am trying to find out if I need to buy any other parts , diff drop kit? I heard about brackets but I am having a hard time trying to find out what I need with this kit.
    Any help would be super.
  18. Mar 5, 2020 at 8:01 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    I installed a diff drop, replaced the top hats, as well as the bushings. The stock UCA contacted the spring at full droop.
    Since I posted that above I've installed SPC UCA's and switched to adjustable Bilstein 5100's on the middle perch with stock Tundra SR5 Offroad coils. I think I have about 1.5" of lift and the ride has been much smoother. For what I use the truck for now (towing, hauling, commute, rare off road dirt two tracks) this setup has been great.
    This is with the current Bilstein setup and 245/75r17 tires:
    6dLBAVN5f6HaPI7F9gSRFTFQU9hS4E8neWpJNoCk_d02133148d828c2fccd8618d26b3530a343c117e.jpg
    Splashbrother13 likes this.
  19. Mar 5, 2020 at 9:18 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have had OME on a 4runner and it was a great install it and forget it suspension. Very durable, helped with off road and towing and stopped load induced bottoming (4 adults, fully loaded on a family trip). Handled load much better than the stock suspension. OME does ride firmer.
    If softness of ride is most important, then I suggest 5100s or the Toytec lifts...any of them you will be happy with, just depends on your budget.
    If you are ok with a firmer ride, needs some better handling of load or towing, then you can't go wrong with OME.
  20. Jul 1, 2020 at 7:30 PM
    Ludogg808
    Ludogg808 New Member
    Luis
    2001 Tundra Sr5
    Weather Tech floor liners, Debadged
    Hey guys. I’m don’t know much about suspension but I know my rear is starting to go so I figured time to buy the old tundra something nice. I got some moog lower ball joints, a diff drop kit, and this OME kit https://www.lowrangeoffroad.com/199...it-2-lift-by-old-man-emu-lr-ometun99lksb.html
    What do you guys think? do I need upper/lower control arms?
    Also trying to pick out a decent set of bump stops if anyone has any suggestions that’d be rad. Thanks Tundra gangly
