1st gen high mileage
Discussion in '1st Gen Tundras (2000-2006)' started by Maine restorations, Dec 5, 2019.
  1. Dec 5, 2019 at 8:04 PM
    Maine restorations
    Maine restorations [OP] New Member
    2005 tundra quad cab sr5
    Stainless steel dual exhaust 2inch lift 22inch rims turbo charger
    Wondering what people are getting for mileage on there 1st gens. I purchased 05 quad cab sr5 4.7 with roughly 150,000 miles. I was just reading somewhere on here that is considered high mileage. I'm closing into the 250,000 mile mark and this thing runs like the day I got it maybe better. I changed my oil a month ago and checked it the other day amd thought the dipstick was dry and oil either burned out of it or leaked. To my surprise after driving 2300 miles on oil it was almost clear amd I couldnt see it on the dipstick.
    I've never seen this before not even on a new engine. I'm running 0/20 in it and been changing faithfully every 5000 miles. I dont think this truck will have any problems surpassing the 500,000 mile mark and beyond. 2nd owner and 1st owner always dealer maintained. What you guys have and thoughts?
    1794TX and OR18TRD like this.
  2. Dec 5, 2019 at 8:18 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    I have 213,000 on my 06. Still runs like a champ. I'm running 5w30 synthetic and change it every 5k.
    MS22 likes this.
  3. Dec 5, 2019 at 8:21 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    194k on my 05 that has been upside down at 70mph, runs like a top. Just minor transmission hiccup when cold. Cheap fix hopefully.
    5w-30 Mobil synthetic
    kodyquist21 likes this.
  4. Dec 5, 2019 at 8:38 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  5. Dec 6, 2019 at 4:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I just rolled over 3 million miles. Original timing belt. I change the oil every 50k. Right around the time it starts to thicken. That's the sweet spot. The only repair I've made is a burned out brake light. Shame on Toyota for giving us cheap bulbs.
    ljburns, thunder100, Beans and 7 others like this.
  6. Dec 6, 2019 at 4:42 AM
    Professional Hand Model
    Hand Protectors
    Same here on the engine running as good as day one. 166k miles here.
    Can I ask why you are using 0w-20?
    Our 4.7 engines spec 5w-30 (preferred) or 10w-30 in warmer climes.
    revtune likes this.
  7. Dec 6, 2019 at 9:20 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    275k and purring like a kitten.
  8. Dec 6, 2019 at 11:35 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I was gonna ask the same thing. I think only the 2.7 i4 engine might use that oil:notsure:
  9. Dec 6, 2019 at 11:40 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    My 02 has 130k, runs great
    And my 06 has 145k, and runs great as well. Conventional oil (5w30) change every 3-5k.
  10. Dec 6, 2019 at 1:45 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    2nd gen Tundras run 0-20.
    revtune[QUOTED] likes this.
  11. Dec 9, 2019 at 6:14 PM
    Aerindel
    Aerindel New Member
    Montana
    I don't know what it is either but I've noticed this too. My subaru oil will be black the day after an oil change, but my tundra is still pale yellow after 5K.
  12. Dec 9, 2019 at 7:08 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Naw they are spec'd for 5-30 or 10-30.
    I've been running M1 10-40 in my 3RZ since I bought it 10 years and 145K miles ago (now at 245K). I went with 10-40 because I used to live in Southern California so theoretically the thicker oil would stay thick at extremely high temperatures which wasn't uncommon in the desert.
  13. Dec 9, 2019 at 8:39 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    My wife's Lexus gx460 runs 0-20
  14. Dec 9, 2019 at 9:04 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I run 10/w30 Castrol syntec in my 2000 Toyota tundra and it just turned 384,000 miles. I bought it new with 45 miles! No oil leaks,no smoke from engine and used no oil between changed.I change my oil every 7500 miles and I can look in the valve cover and it is clean as a whistle! I should get 500,000 miles easy,! I kind of raced around with a newer Camaro the other day and covered it up with white tire smoke going around a curve! It still runs strong!!IMG_20190831_195607024.jpg
  15. Dec 9, 2019 at 9:37 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    That's a good looking 1st Gen.
    Wvmoonshiner likes this.
  16. Dec 10, 2019 at 3:07 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    0W-20 oil is spec-ed for fuel economy in an effort for auto manufacturers (in this case, Toyota) to increase their fleet average MPG numbers to meet CAFE standards. Elsewhere in the world, you'll find the same vehicle -- whether a Tundra, Camry, Prius -- the oil spec is 5W-30.
    I've research this a fair amount online. Most of the articles I've found relate to the trucking industry where fuel costs are such a big part of their business expenses, so increasing fuel efficiency -- even a small amount -- is a high priority. What seems to be the consensus is that dropping "one weight", say from a 30 weight to a 20 weight oil will net "as much as 1% fuel economy increase" (read: less than 1%). That's not a lot for you and I, but if you're Toyota, every bit counts toward meeting your goals.
    However, logic would dictate (and these research articles point out) a thinner oil doesn't lubricate as well, so it's a balance between economy and engine longevity. From what I've read, 30 weight seems to be the sweet spot.
    Personally, I won't run 20 weight oil in anything I own -- it just doesn't make sense. And for those focused on the "0W" rating for cold-start protection, there are plenty of 0W-30 and 0W-40 oils on the market.
  17. Dec 10, 2019 at 5:08 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    My 2000 SR5 has 190k, it runs like a champ. The only repair i've done to mine is replacing the TPS, but she's been golden ever since. I change the oil every 5k miles. I'm the third owner and it was an old farm truck, so she is just being broken in.
  18. Sep 14, 2021 at 5:56 AM
    Lucky0402
    Lucky0402 New Member
    Dane
    3/2 Lift Gear Double Pump rims 295/70r18 Nitto Terra Grappler G2s
    I realize this is an old post. But could any of you with these high mileage tundras tell me if/when you changed your transmission fluid? Some say not to do it at all, some say it should be done every 30k to 60k....but none of them have tundras with that great of lifespan. Was curious to know what experience says.
  19. Sep 14, 2021 at 6:42 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You either change it regularly or not at all. That's been the general consensus I've seen. There are reasons to this approach; none of which I prefer to go into now.
  20. Sep 14, 2021 at 7:02 AM
    Lucky0402
    Dane
    Ok, this may be edging into "none of which I prefer to go into now" but i am at 119k. Fluids were checked around 60k, not changed. Is it too late to change it now, or leave it and forget about it.
    No issues with transmission so far, and I do not tow anything. A lot of my reason for asking is that i was quoted between $355 and $600 to have it done...and if it's not necessary, why spend the money and potentially cause tranny issues (which I've read can happen).
  21. Sep 14, 2021 at 7:33 AM
    Generally speaking, I come from a background with GM most of my life. In that world, especially when the 700R4 got an electronic upgrade to the 4l60e, which had a swath of shortsighted mistakes, the consensus was, "if you don't know the fluid change history, once you top 100-150k, don't bother".
    The "logic" to that, if there is any logic in it, is/was if you've never had the tranny fluid changed for that long, there are virtually no detergents or cleaners in the fluid, and should you fully flush the old fluid and apply new, modern fluid with lots of detergents and cleaners, you're liable to break some gunk loose and clog a port somewhere that's going to hose your transmission.
    There are countless horror stories on the internet which support this viewpoint, but I've never seen science to prove it. To be safe, a lot of guys will either go the SeaFoam route and do light additions to slowly add a light cleaner and dissolve stuff, OR just drain the pan and replace a few quarts every few thousand miles in intervals until you'd gone through a dozen or two quarts, to gradually add in.
    The topic is like religion or politics though, which may be why @Jack McCarthy didn't want to go there. Also, if there is any credence to shop/internet lore, giving bad advice could put someone or the forum's reputation on the line.
    I would say, I don't feel like 115-120k is a hell of a lot of miles for these trucks. I also don't think a full flush of transmission fluid is ever necessarily warranted except in one case: Look up 'pink milkshake' for one case why you may need a full flush on these trucks. Aside from that, maybe consider an incremental replacement of a few quarts at a time.
    Lucky0402 likes this.
  22. Sep 14, 2021 at 7:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If the fluid doesn't look burned, I would change it personally. I would do 3-4 drain+fills over the course of a few months or a few thousand miles. This is what many of us have done to our 1st gens.
    I've shared this video a few times over the years but I think there is some good info in it.
    https://www.youtube.com/watch?v=o690DovjDAc
  23. Sep 14, 2021 at 8:07 AM
    Would or wouldn't? Seems counter-intuitive. If it looks burnt, I would change it. If that's a typo and you edit, I'll be deleting this reply.
  24. Sep 14, 2021 at 8:14 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If the fluid is in horrible shape, my understanding is that you might create more problems by changing it. Or at least that is what I've always heard. Is that backed up by anything concrete? I doubt it. Some people don't believe in changing it ever which I think is stupid.
  25. Sep 14, 2021 at 8:31 AM
    Ah, so basically what Chris was on about. Makes sense (I watched his vid just now)
    I think not changing at some point in time is pretty stupid too. Manufacturers don't write manuals as if they expect the car to last much past 10-20yrs or 100-200k miles. There are additives in drivetrain fluids for a reason, and age definitely breaks down everything, except maybe my libido. :dancingbacon:
    I would say 'if burnt, proceed with caution' but definitely avoid an outright flush. At least that way you're likely to get some early warning signs after the 1st fluid change, like slipping, odd or erratic shift times, which would be a sign you just escalated your need for tranny service.
  26. Sep 14, 2021 at 8:42 AM
    tvpierce
    Maine
    119K miles is not high mileage -- hell, you're just past the first timing belt change interval. There's no reason to be concerned about refreshing the fluid in the tranny either 3-4 quarts at a time (spill & fill), or by flushing via the ATF cooler return line. Let it go another 119K miles and then you'll be in the high mileage range. (For clarity: do not let it go another 119K miles!)
    As to the prices you were quoted, they're outrageous. I presume those quotes are from dealers and they're suggesting a full flush? What year is your truck?
  27. Sep 14, 2021 at 9:03 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I had an '06 with 238k, still going strong. I drove it like I stole it for 100% of those miles, but I maintained it very well. I loved that truck. I traded it for a '20 because my wife wanted me to carry her around in something more up to date. I loved that truck.
    The transmission quandary exists because extremely dirty and/or burnt transmission fluid can gum up valves, and draining it generally leaves the worst dregs at the bottom of the pan ready to do their nefarious thing. (I'm not a mechanic, but I play one on TV) If you're worried about it, take out and add a bit at a time over a few weeks or months, until any you're taking out looks relatively new. Guessing 1/3 or so each time, until you've changed 2 or 3 times the volume of the pan. Then do a full flush and replace and start changing it more regularly.
    I loved that truck.
    FrenchToasty likes this.
  28. Sep 14, 2021 at 10:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Your wife made you trade in your 1gt? I'd be trading in my wife....
    DaWhiteTundra and Toyoda Tundra like this.
  29. Sep 14, 2021 at 11:19 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I'd drive her around in a pink F250 if that's what she really wanted. Happy wife, happy life.
    shifty` likes this.
  30. Sep 14, 2021 at 5:54 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    why do you change oil so often? I wait till it either drips out, or turns to sludge. Then I run it on ATF for a thousand miles. Drain that out, and then refill with used oil from the drain bin at Walmart.
    My timing belt shredded years ago, I use a giant rubber band now.
    bmf4069 likes this.
