1st gen fog light mod
Discussion in '1st Gen Tundras (2000-2006)' started by Drfarquad, Nov 10, 2019.
  1. Nov 10, 2019 at 4:56 PM
    Drfarquad
    Drfarquad [OP] New Member
    Bobby
    Milford
    2005 Tundra Limited DC
    OME 3 inch lift level, UCAs, Icon AAL
    Ok, I know it has been discussed numerous times before. BUT I cannot seem to find an exact method for the first gens it seems as if all of the mods are for newer gens or unfortunately they bring you to a different thread. So if anyone out there has some insight/pictures on how to do the fog light anytime mod on the double cab DRL system I'd be a very happy camper. I have the wiring diagram for the fog lights but cannot find the red wire under the column. I had a very hard time moving the fuse panel that's underneath the kick panel. I removed damn near everything underneath the column and unfortunately I ran out of time and needed my truck back so I had to put it all back together. Someone please help me!! I really want this mod done.
  2. Nov 10, 2019 at 5:01 PM
    Drfarquad
    Bobby
    Milford
    From what I understand, to do this on the wiring side. I should ground the G-W wire under the column. And I should be able to use these.
    Tap into any accessorie circuit and supply power to the pink wire. I believe this is correct but I'd like to see if someone has done this or has done a different mod to get me to have fog lights on with anyother lights on.
    MS22 likes this.
  3. Nov 11, 2019 at 5:18 PM
    Drfarquad
    Bobby
    Milford
    Anyone have any insight?
  4. Nov 11, 2019 at 5:35 PM
    Professional Hand Model
    Hand Protectors
    No sir, but if I did I help you. I’ve seen people really mess things up trying these light mods. Hopefully this bumps your thread. You may be a pioneer here on this one.
    Drfarquad[OP] likes this.
  5. Nov 11, 2019 at 7:01 PM
    Drfarquad
    Bobby
    Milford
    Well unfortunately im not as good at reading these diagrams as I used to be. Although im not old, it's just been a few years since ive had to read things like this. Im going to talk to my old co worker who has years of experience in electronics. He should easily be able to help me. As soon as we figure it out I'll make a separate thread, most likely in lighting.
  6. Nov 11, 2019 at 7:43 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  7. Nov 11, 2019 at 9:40 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    According to that wiring diagram looks likes could disconnect the hot wire (#2 on the relay) coming from the headlight fuse and hook ignition +12v there.
    Then hook constant ground to #10 on the dash switch.
    Then you have switch controlled fog lights. :notsure:
    Now somebody try it!!
    TRDGen and Drfarquad[OP] like this.
  8. Nov 12, 2019 at 1:24 AM
    Drfarquad
    Bobby
    Milford
    This was my initial thought. So you are assuming that the wire going through the body ECU is just grounding out the circuit. Honestly that's all that is needed to complete the loop. I just wanted to hear it from someone else lol. Hopefully see my buddy this week I'll assume that's what we will come up with.
    Squeakysequoia likes this.
  9. Nov 12, 2019 at 1:38 AM
    Drfarquad
    Bobby
    Milford
    This bashes be hesitant only because it looks as If the 4 runner doesn't grind through the body ECU. I wonder what that is looking for when the fog lights are turned on. Not 100 percent I need to find the diagram for the ECU to fully understand why this circuit terminates there.
  10. Nov 12, 2019 at 5:48 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Before finding Tundras.com, I frequented TundraSolutions and one of the DIY links I saved was the one below. Someday down the road I'll be looking to do this Mod but will be following the instructions by Eddie in his pdf that's linked to at bottom of first post in DIY link below. There may be wire color differences in my 2004 but will follow the general principle...."segregate the Fog Light Relay Coil “Ground” as well as the Fog Light Stalk switch from the Main Body ECU"....and I should be good to go.
  11. Nov 12, 2019 at 6:22 AM
    Drfarquad
    Bobby
    Milford
    I believe this is will help. My concern with this is the wires and connector numbers dont match to what my truck diagram is. Which makes me hesitant to follow his plan directly. I'll reread what he posted about how the ECU works and maybe make a decision from that.
  12. Nov 12, 2019 at 6:27 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I am not discounting all the good info that was posted in the whole thread, I just did not wish to go the add a relay part and simply chose Eddies single wire solution shown in his pdf.
    Drfarquad[QUOTED][OP] likes this.
  13. Nov 12, 2019 at 6:32 AM
    Drfarquad
    Bobby
    Milford
    Have you don't this to a 2005 with drl. I think that's where my confusion is. I just don't want to ruin anything and take a free mod and turn it into a paid fix for something I did wrong.
  14. Nov 12, 2019 at 6:41 AM
    Hand Protectors
    This is what I’m talking about with you being a pioneer. You’ll either be a hero or end up in agony!
    If it were me, I’d leave it based on all the gremlins that crop up after these type mods.
  15. Nov 12, 2019 at 6:42 AM
    Drfarquad
    Bobby
    Milford
    What type of gremlins? Never really asked anyone how it was after being done.
  16. Nov 12, 2019 at 6:42 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Why do you need you fog lites on all the time, especially during the day? I never understood daytime running lights, kind of stupid really. If you lites are on all the time, they don’t last as long burn out costing you money.and don’t do much except light up for nothing. It’s another way for manufactures of lites to make more money.
  17. Nov 12, 2019 at 6:45 AM
    Hand Protectors
    Other stuff that was working... now doesn’t work or it acts strangely. The good thing is the wires can always be put back to how they were.
  18. Nov 12, 2019 at 6:45 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    No, as mentioned earlier, I have 2004 and should also add I do not have DRL but with 40 yr as elec tech for uncle sam, I better not have issues figuring it out or tax payers wasted their money on me :)
    Hopefully your co-worker with years of experience will be able to help.
    Tundra2 likes this.
  19. Nov 12, 2019 at 6:45 AM
    Drfarquad
    Bobby
    Milford
    This isnt to have drl fog lights. This would be used for when you want to have any lights on you can have your fog lights on also.
    From factory with your high beams on your foglights go off. With this mod you can have your fog lights on also.
    Or if you just turn your parking lights on you can turn your fog lights on also, which you cant do from factory.
  20. Nov 12, 2019 at 6:46 AM
    Drfarquad
    Bobby
    Milford
    If you don't mind I'll draw up what I believe is the correct way to do it on the 2005 and could you kindly tell me if it looks good?
  21. Nov 12, 2019 at 6:48 AM
    Hand Protectors
    I look at the DRL as a safety feature. Kinda like motorcycles using them so we can see them better. Funny thing is, since I switched to LED lights, more people pull out in front of me. Hoot!
    Tundra2 likes this.
  22. Nov 12, 2019 at 6:48 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Very much aware of that and only mentioned DRL because you referenced it in your first post....."fog light anytime mod on the double cab DRL system"
  23. Nov 12, 2019 at 6:50 AM
    Hand Protectors
    I love some pictures with arrows.
  24. Nov 12, 2019 at 6:50 AM
    Drfarquad
    Bobby
    Milford
    So the fuse onto that I drew in would be am added fuse that I would supply power to from else where. On the bottom side of the switch going to ECU just ground out the switch side of the wire. Hopefully just creating the loop.
    My concern is would like screw up the ECU, now having no communication with the switch.
    TX-TRD1stGEN likes this.
  25. Nov 12, 2019 at 7:07 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Just a quick look at the diagrams shows that the ECU is providing a ground to the fog lamp switch. If the ground is there when the fog lamp switch is on, then the Fog light relay will be energized and the fog lights come on.
    If the ECU decides that it doesn’t want to provide a ground (like when the high beams are on) then the Fog lamp relay can’t be energized.
    So the solution is to provide a constant ground to the fog lamp switch via the Green/black wire going in to pin 10 on the switch. If it were me, I would cut the G/B wire, (taking control away from the ECU) and ground the input to the switch side (pin 10). Then tape up the ECU side.
    Edit: If power for the fog relay is also switched on from the low beams, then the alternate constant power would also need to be added per OP’s drawing above.
    Tex
  26. Nov 12, 2019 at 7:18 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Your half way there.
    The drl relay switch side is powered by low beam light fuse so I would only come on with low beams on.
    How @Drfarquad drew it should be correct.
  27. Nov 12, 2019 at 7:27 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Ahh, good catch. I don’t have the rest of the power schematic in front of me, so Yes, if the relay power is switched rather than constant, and the desire is to have fogs on when nothing else is on, that will do it.
  28. Nov 12, 2019 at 8:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    For what it's worth, agree with TundraTex along with what TX-TRD added !
    Tundra2 likes this.
  29. Nov 12, 2019 at 9:58 AM
    Drfarquad
    Bobby
    Milford
    Well than I'll have to report back over the weekend with what happens. Fingers crossed nothing weird happens with the body ECU. I'll try my best to take pictures. Thanks everyone for the help.
  30. Nov 12, 2019 at 9:59 AM
    Drfarquad
    Bobby
    Milford
    Damn I dont know how to type hahaha
