1st gen DC Tundra window trim
Discussion in '1st Gen Tundras (2000-2006)' started by jberkut4, May 22, 2020.
  1. May 22, 2020 at 10:29 AM
    jberkut4
    jberkut4 [OP] Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    The window trim on my truck has lost it’s black rubber molding, and is showing chrome. Not a huge fan of the chrome, what have you guys done to fix the problem? But new trim? Paint it?
  2. May 22, 2020 at 10:42 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    My rear slider trim was the same. Pulled it off and a couple coats of plastidip and new again!!
  3. May 24, 2020 at 9:29 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    I used the duplicolor bumper and trim paint (flexible) with a nice satin finish. Much cheaper than buying new.
  4. May 24, 2020 at 9:43 AM
    Professional Hand Model
    Hand Protectors
    Nice. I sanded mine and sprayed it with Rustoleum Bed Liner and then top that off with a satin spray. Its been holding nicely for almost two years now. $ave!
  5. May 24, 2020 at 10:04 AM
    noahrexion
    Washington
    2005 4WD DC
    o_O
    Got a pic of that? I'd like to see the texture finish - that may be closer to factory anyway.
  6. May 24, 2020 at 10:23 AM
    Hand Protectors
    I can post an archive pic of the door trims/side stepboards/wheel flares painted with just the liner stuff (no top coat). The red accent is a Duplicolor Acrylic Enamel top coat. Not really a good angle of the window trims. Mine were not as bad as some others I have seen, but in time would have gotten to be. I just taped things off and prepped and sprayed all of my black trims with the Bed Liner. Its a nice light textured grit with a good matte type sheen.
  7. May 25, 2020 at 4:13 PM
    stevechumo
    stevechumo New Member
    I removed the trims on my Tundra, used the heat gun to soften the remaining rubber, and used razor knife to remove them. Once there's only the chrome left, sanded rough with 120 grit sandpaper. I then sprayed primer on it, then sprayed with matte black paint, and finally is matte clear coat. They look like new.
  8. Jun 10, 2020 at 10:30 AM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    are there any videos on how to remove the trim pieces?
  9. Jun 10, 2020 at 5:26 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Vinyl car wrap works great and you have options for finish. I've done the carbon fiber look on another vehicle
