1st gen crap lift
Discussion in 'Suspension' started by SShounds, May 31, 2020.
  1. May 31, 2020 at 11:10 PM
    SShounds
    SShounds [OP] New Member
    2005 double cab
    New to here.
    I recently bought a 05 double cab with low miles for a steal.
    unfortunately, this truck has a tuff country spacer lift. I hate it.
    I spend a lot of time in the woods and I mean a lot. At this point my ranger is more comfortable to take up in the hills.
    the crossmember has been cut out for this. I want to revert it back to a smaller true suspension lift. Has anyone done this? I know I will have to acquire some factory brackets and what not and probably find a crossmember to weld back into place.
    what’s the experts here opinion on this?
  2. Jun 1, 2020 at 12:40 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It can be done. But it will be expensive. Toyota might still sell the x member you need. But cheaper solution would be fabricate the section your missing and weld it in.. then everything else should be bolt and go
