1st Gen cloth driver seat bottom help!
Discussion in '1st Gen Tundras (2000-2006)' started by srobinson789, Jun 23, 2022.
  1. Jun 23, 2022 at 6:23 PM
    srobinson789
    srobinson789 [OP] New Member
    2002 Tundra
    Just got a 2002 Tundra. Love it! But I need help finding a replacement cloth bottom drivers seat cover. I’ve looked everywhere and no luck. The color is the blueish/gray color. It seems that they are extinct…I’ve looked on EBay, Facebook Marketplace etc but no luck. Anybody have a place you could direct me to to find one? Or anybody have one by chance they would sell me? Any and all help would be appreciated. Thanks guys.
  2. Jun 23, 2022 at 6:35 PM
    shifty` In South Dakota Trouble ain't hard to find
    You just reminded me, I needed to check in with The Seat Shop to see where they are with their OEM-quality replacement covers. I'll let you know what they say.
    I need to replace my driver seat leather upper and lower. I'm not sure if the '06 Lexus RX or GX would fit.
  3. Jun 23, 2022 at 7:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I needed to get the bottoms redone on my taco before I sold it and my uncle had a guy, did a great job for like 70 bucks, I could never remember where it was. I recently re found it right near one of the HVAC suppliers warehouse! Looks like the same fire hazard I remember!
    FirstGenVol and shifty`[QUOTED] like this.
  4. Jun 23, 2022 at 9:40 PM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Check out lseats.com. I ordered front leather replacement covers from them and for the price they're really good. I don't recall if they have cloth options, but would be worth checking.
    Note that I've seen some mixed reviews for lseats.com (even though I had fairly good service from them). I haven't seen any issues on cover quality, but some issues on customer service if there's any need for follow up. I had someone else recommend them to me, so rolled the dice anyway and would probably order from them again if needed. YMMV.
  5. Jun 24, 2022 at 6:00 AM
    srobinson789
    2002 Tundra
    Thanks for the replies so far. I’d like to keep the seats original if possible but switching to a leather package could ultimately be an option if I can’t come up with cloth. Thought I found some yesterday but they were too gray. Mine are the tweed locking ones with a bit of a bluish tinge to them. Not sure what that’s called. Does anybody know?
  6. Jun 24, 2022 at 6:03 AM
    srobinson789
    2002 Tundra
  7. Jun 24, 2022 at 6:04 AM
    srobinson789
    2002 Tundra
    Thought I’d send a couple of pics along. Thanks for help y’all.
  8. Jun 24, 2022 at 8:10 AM
    I can't tell what's wrong with it. Is the cover thinning, or is it just dirty? I can't tell if it's dirt, or if the foam is showing through.
  9. Jun 24, 2022 at 8:49 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Put a "wanted" ad in the classifieds, as some members are replacing their seats with Katzkins, etc. making their old seat covers available.
  10. Jun 24, 2022 at 10:43 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Duct tape...
  11. Jun 24, 2022 at 11:09 AM
    Daaaang that's almost invisible in the pic. Good color match :D
  12. Jun 24, 2022 at 2:05 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    upholstery shop can fix that right up I bet.
    tunyota and shifty` like this.
  13. Jun 24, 2022 at 4:30 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I too have a 2002 Tundra. Base model so it's a bench. I want to redo the bottom of it cause it's pretty bad as well.
  14. Jun 24, 2022 at 5:17 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Chances of you finding a used one in good shape will be slim
  15. Jun 24, 2022 at 6:28 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Separate buckets, or split bench?
    also, what is the trim code on your door sticker? I can look up the part numbers on toyodiy, but they are probably long out of stock.
  16. Jun 25, 2022 at 3:37 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I have the same in oak on my 2000 and it’s worn through same spot. I just stitched it with needle and thread but really need to redo the seat. I’m getting crumbles of foam under my seat as well
