1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. Apr 5, 2021 at 9:49 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Thanks to everyone who posts and gives advice. I’m not sure I should dedicate a thread, but Gen 1 owners can be in the minority, so here is a bit that I learned here or just did.
    2005 DC 2WD 4.7 4.88 & E-Locker
  2. Apr 5, 2021 at 9:56 PM
    alb1k
    Left Coast
    It's good
    Needed tires, decided to get wheels as well. Learned here and on google what was a good fit for me. method 316s 17x8.5 0 offset. Firestone XT 275/70/17
  3. Apr 5, 2021 at 10:01 PM
    alb1k
    Left Coast
    It's good
    King 2.5 performance. Not EXT, I messed that up, now want a rebuild.
    Navi, dadjazz, georgiey22 and 2 others like this.
  4. Apr 5, 2021 at 10:08 PM
    alb1k
    Left Coast
    It's good
    Added those extended sway bar links on top of the box, good move, found out later that I had already bent one link.
    dadjazz and Darkness like this.
  5. Apr 5, 2021 at 10:09 PM
    alb1k
    Left Coast
    It's good
    Now I’m juiced, Total Chaos UCAs.
    dadjazz, toyofan87 and Darkness like this.
  6. Apr 5, 2021 at 10:14 PM
    alb1k
    Left Coast
    It's good
    TC and King in, that was a bitch, Pm me if you want to know why. Spoiler, have a puller to get the upper ball joint out.
  7. Apr 5, 2021 at 10:22 PM
    alb1k
    Left Coast
    It's good
    I went back and forth with spacers on the Durobumps. None, washers, these 3/8”....still not sure because I pulled the coilovers and after backing off the collars, still could not remove the springs. Need a better spring compressor set up. Used the 3/8” spacers and feel pretty safe I’m not jamming my shocks.
    EDIT: spacers came out - not needed.
    Darkness likes this.
  8. Apr 5, 2021 at 10:25 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    How’s the ride with the kings? You rubbing on those mud flaps?
  9. Apr 5, 2021 at 10:35 PM
    alb1k
    Left Coast
    It's good
    Aside from trying to improve my paint, LEDs have been sweet and pretty easy, although I haven’t tackled headlights.
    2006Tundradc, georgiey22 and Darkness like this.
  10. Apr 5, 2021 at 10:42 PM
    alb1k
    Left Coast
    It's good
    With my tire size and wheel offset, I couldn’t rub or bump anything if I wanted to. Maybe I haven’t jammed it in the right way yet, but seems to be clear all around.
    edited because I better read @jerryallday , the ride is great, although I’m mostly a mall rat. I’m still trying to squeeze some more travel. But, although not an off-road guru, I have some time behind that wheel. It makes me want to drive a long travel. I’m screwed, I see the lowers on the Raptors when I drive past, and then think about what to do with my next Tundra...
  11. Apr 5, 2021 at 10:46 PM
    alb1k
    Left Coast
    It's good
    I think I have swapped 12 bulbs to LED, I have a few to go. But, yes.
    2006Tundradc and Darkness like this.
  12. Apr 5, 2021 at 11:15 PM
    alb1k
    Left Coast
    It's good
    Here’s the truck a week or two ago, on its way to next level....
  13. Apr 7, 2021 at 4:07 AM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    lookin good! :popcorn:
    alb1k[OP] likes this.
  14. Apr 7, 2021 at 4:22 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Very nice thread! Keep it coming and great job!
  15. Apr 7, 2021 at 7:51 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Love it!
  16. Apr 7, 2021 at 7:33 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Nice write up. Good mods and improvements..
  17. Apr 11, 2021 at 8:36 AM
    alb1k
    Left Coast
    It's good
    Those tabs are plastic heated and bended, looks like a tape job.
  18. Apr 11, 2021 at 9:02 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I did my grill about 2 weeks ago, I thought it looked best to just do it all black and tape the edges off. I did it about 3 times. Once just the chrome, then chrome and outer trim... Just doing the chrome looked weird imo.
    it’s easier to remove the grill also
    Darkness, Voss and georgiey22 like this.
  19. Apr 11, 2021 at 9:24 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I don’t make it into LA much but when I do, I hope I see this nice truck on the ride. Nice build. Really looks good and I enjoy reading how you are doing all the work.
    alb1k[QUOTED][OP] likes this.
  20. Apr 11, 2021 at 9:37 AM
    alb1k
    Left Coast
    It's good
    Here’s the test piece with primer. Gonna go full throttle and follow what @jerryallday did.
    jerryallday and Tundra2 like this.
  21. Apr 11, 2021 at 9:39 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Just a quick rinse to get all the dirty and grim off. Some alcohol and rustoleum plastic dip forms Home Depot about 6-8 coats.
    I did the yoda and V8 emblems off the grill to get all the edges.
    Have good lighting and take your time and make sure everything is dry and don’t move to fast trying to reassemble.
  22. Apr 11, 2021 at 9:46 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    It’s going to look great, I wish I did primer
    Are you removing the grill, it’s like 8 nuts and 2 bolts. Take a photo of the latch cause it can be a pain to remember the direction.
    if your are in LA there was a big Toyota meet yesterday in the OC. Tons of great tricks and huge turn out.
  23. Apr 11, 2021 at 9:50 AM
    alb1k
    Left Coast
    It's good
    Yeah, I pulled the grille. Was going to tape in the garage. Now just going to prep and shoot. Saw that event, was working, but seemed like a great thing to go to if possible.
    jerryallday[QUOTED] likes this.
  24. Apr 11, 2021 at 9:50 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I had this Image from another truck For a reference with all black grill + trim
  25. Apr 11, 2021 at 9:57 AM
    TheBeast The Beach
    looks great. I tried the CG Barebones treatment past winter. It worked out good cleaning up all the salt from the mountains roads.
  26. Apr 11, 2021 at 10:20 AM
    alb1k
    Left Coast
    It's good
    What could go wrong? LOL
  27. Apr 11, 2021 at 10:42 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Heavy test fishing line works best.
  28. Apr 11, 2021 at 10:44 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Are you doing anything with the chrome side mirrors?
  29. Apr 11, 2021 at 11:12 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  30. Apr 11, 2021 at 11:12 AM
    TheBeast The Beach
    yes I let it sit on the car. It drips on the floor a bit and smells like grape in the garage for a while..lol
