19 tundra pro shocks on a trd
Discussion in 'Suspension' started by Honda287, Nov 26, 2020.
  1. Nov 26, 2020 at 10:35 AM
    Honda287
    Honda287 [OP] New Member
    19 tundra trd
    Will a set of 19 tundra pro shocks fromt and rear bolt right up to a 19 trd off road . Have a chance to get a set jist want to make sure it will fit . I have the bilstein shocks now . Thank you
  2. Nov 26, 2020 at 10:38 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Yes. It will raise the front 1.5” or so, and you will need an alignment, but that’s the only difference. Direct bolt up.
  3. Nov 26, 2020 at 10:44 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    The control arms are the same on every tundra. It will bolt up to the pro suspension just fine.
    Edit: If I were you, I’d snatch up that suspension on that other FS ad. Pro suspensions go QUICK! I’d buy that Pro suspension right now if I didn’t have a set in my basement.
    JLS in WA and RainMan_PNW like this.
  4. Nov 26, 2020 at 11:03 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yep, straight swap. Just get it aligned when you’re done.
