19 TRD Pro lift?
Discussion in 'Suspension' started by Snowcat4360, Sep 22, 2019.
  1. Sep 22, 2019 at 7:04 AM
    Snowcat4360
    Snowcat4360 [OP] New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Sorry if this has been asked before. Did a search and could not find the answer. Does the 2019 TRD Pro have a lift in the rear and if so how high and what is used for the lift? Also are the UCAs on the Pro the same as the TRDs? Does the Pro have a diff drop?
    Thanks,
  2. Sep 22, 2019 at 7:10 AM
    15whtrd
    15whtrd Mr. Blonde
    No rear lift and same UCA on all Tundras. No diff drop either. But the rear shocks do have an inch longer travel. They droop so the ABS brake line bracket is extended.
