18 vs. 20 inch - Any advantage to either wheel size?
Discussion in 'Wheels & Tires' started by gdog_Tundra, Feb 21, 2019.
  1. Feb 21, 2019 at 5:07 AM
    gdog_Tundra
    gdog_Tundra [OP] New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
    I have 20 inch rims now and am considering dropping back to an 18 inch.... yes or no and why?
    Thanks
    G
    yoshi82 and midnight like this.
  2. Feb 21, 2019 at 5:12 AM
    midnight
    midnight IXLR8
    Todd
    GPT MS
    2024 Toyota Tundr TRD Pro
    Color matched mirror covers Color matched door handles Added TRD Performance package Changed the OEM fog lights to Rigid Industry Added AFE tow points TRD Performance Package
    I am fixing to pull the trigger on this very same mod Saturday. I have 20 inch Black TSS wheels with BFG KO2 and going with the 18 inch TRD pro wheels and tires. Hope it makes the truck ride better.
    yoshi82 likes this.
  3. Feb 21, 2019 at 5:41 AM
    If you want more sidewall rubber for wheeling then the 18"s have the advantage. 17"...even better. If I didn't like my current 18" set up so much I'd be running on 17's.
  4. Feb 21, 2019 at 5:42 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I'm putting TRD Offroad wheels on mine as soon as my current tires wear out. I've got 20" BBS wheels now.
    Pkahir12, Turtle88 and Black Wolf like this.
  5. Feb 21, 2019 at 7:05 AM
    Sunnier
    Sunny
    San Diego, CA
    What Grey Woll said. Smaller wheels allow you to fit more tire in same space = more rubber cushioning between you and the road. Also, if you like to drive off-road, airing down increases comfort. Smaller wheels, more rubber = more comfort aired down... and less chance you'll get a flat.
  6. Feb 21, 2019 at 7:09 AM
    novae500
    novae500 New Member
    2016 Tundra DC SR5 upgraded package
    20s look nice, but sometimes i wished i should just have purchased larger tires for the TRD 18 rims i have.
    yoshi82 and 040Tundra like this.
  7. Feb 21, 2019 at 7:11 AM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    This!
    Sleeper16plat likes this.
  8. Feb 21, 2019 at 7:25 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    Also been wondering about this myself. But, some say all the system in/on the truck (say my 2019) was designed to run with 20" wheels, going down to 18" would change all this. Any concerns here? And, when we talk 20" wheel, we're talking width of wheel, right? Any diff in height of the wheel vs 18 or is it other way around?
  9. Feb 21, 2019 at 7:44 AM
    Ntmid8r
    Ntmid8r New Member
    TBA
    Height, not Width.
    Navi[QUOTED] likes this.
  10. Feb 21, 2019 at 7:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Zero advantage of having 20’s on a truck. Go 18’s or better yet 17’s.
  11. Feb 21, 2019 at 7:50 AM
    Navi
    Navi New Member
    Will changing the height of the truck screw up all the TSS crap? any real concerns with that?
  12. Feb 21, 2019 at 12:04 PM
    Ntmid8r
    Ntmid8r New Member
    TBA
    It should not. Guys are lifting trucks with no issues. I went down from 20s to 18s with zero issues.
    yoshi82 likes this.
  13. Feb 21, 2019 at 12:37 PM
    flying dave
    flying dave New Member
    NC
    This is more of a curious question than anything. If you have the same diameter which setups generally tend to be heavier? A 20 with a smaller sidewall tire or a 18 or 17 with a larger sidewall tire? Let's say at a 35" tire
    Mnorris1206 and Medic343 like this.
  14. Feb 21, 2019 at 12:39 PM
    15whtrd
    15whtrd Mr. Blonde
    The only advantage a 20 inch rim has over an 18 inch rim with the same tire diameter, would be a little less tire roll in the corners. The truck would probably corner a little better. Other than that the 18 inch rim wins all day.
    Chadwicktr, gosolo, yoshi82 and 2 others like this.
  15. Feb 21, 2019 at 12:40 PM
    15whtrd
    15whtrd Mr. Blonde
    I’d say negligible differences.
    Wahayes likes this.
  16. Feb 21, 2019 at 12:41 PM
    Marty McFly
    Morty McBoonJug
    Just to play devils advocate, if your truck is just for show, some 20s look pretty badass :oops:
    BestGen, atl1glf, Sunnier and 3 others like this.
  17. Feb 21, 2019 at 12:42 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    So I am not here to start a war but just to speak my mind and opinion. The vast majority of people on here will all say that 20s are worthless and 17/18s are the way to go. The reasoning for most as depicted above is because of the amount of rubber available for either off-road or cushioning on-road. But in reality aren't we talking about 1 inch here? I do not personally see that having 1 extra inch of sidewall is going to "tremendously" improve your off-roading capabilities or on road performance. That's just me.
    For conversation sake, let's take a 35" tire. 35x12.50r20 versus 35x12.50r18
    • 20 inches of that 35 is taken by the wheel leaving 15 inches of "rubber" or sidewall. Divide that in half you in theory have 7.5 inches of sidewall on top and bottom
    • 18 inches of that 35 is taken by the wheel leaving 17 inches of "rubber" or sidewall. Divide that in half you in theory have 8.5 inches of sidewall on top and bottom
    Now weight, that is the only real advantage I could possibly see coming out of this conversation.
    albass, Kratos, Jeff_1974 and 4 others like this.
  18. Feb 21, 2019 at 12:47 PM
    15whtrd
    15whtrd Mr. Blonde
    On my old Dodge I went from 17 inch to 20 inch and I could feel the difference. It looked bad ass but I definitely felt the bumps more. It did corner better though. I’d say that 1-1/2” of extra rubber is important if you’re doing any type of fast off roading. Airing down, it will leave you that much more room before rim contact. It certainly makes a difference and I have felt it.
  19. Feb 21, 2019 at 12:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It actually makes a huge difference. Especially when you're aired down, you're not at 7.5-8.5" anymore. More like 4-5" One inch doesn't seem like much but that's basically 20% more sidewall and air you're riding on.
    gosolo, BestGen, GodlessPro and 2 others like this.
  20. Feb 21, 2019 at 1:07 PM
    Navi
    Navi New Member
    If 18 seems to have advantages discussed here, why did Toyota put 20's on the Limited? i'm not sure if 20's come across the board on 2019's but they did come on my truck (Limited 4x4). i'm not sure what TRD and others get (SR5 vs 1794, etc). just a looks thing??
  21. Feb 21, 2019 at 1:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Because they look nice and some folks don’t really take their 4 x 4‘s off road they just need them for bad weather. Also when you buy the truck you can have them put 18s on if you like.
  22. Feb 21, 2019 at 1:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There's absolutely nothing wrong with 20's on a street rig. You'll actually improve performance on the road. And I think a lot of people actually prefer the looks of a larger wheel. It's just not enough sidewall when you go offroad. Hence the 18" wheels on the Pro and they swap to an 18" for the TRD Offroad package.
  23. Feb 21, 2019 at 1:17 PM
    easleycrawler
    Travis
    I agree, I think 20's look good on the tundra. I've got 20's with no plan to lift, so the 285/55's ride like shit. That's why I picked up a set of 18" TRD Offroad wheels.
    Marty McFly, joonbug and 15whtrd like this.
  24. Feb 21, 2019 at 1:17 PM
    easleycrawler
    Travis
    Plus I can get white letters back.
    Sunnier and joonbug like this.
  25. Feb 21, 2019 at 1:40 PM
    Sunnier
    Sunny
    San Diego, CA
    I can't say it better than these guys but can add, I've taken my stock 2017 TRD 2WD off-road several times. I air down the stock Michelins more or less depending on how many sharp rocks I expect to encounter. I'm careful not to turn while stopped, as precaution to avoid a pinch flat. The tires have chunks of tread missing-- I've possibly used them for applications "above" that intended-- but they've performed well. I've looked at other guys' tires aired down, and I feel really sure that extra inch of rubber makes a positive difference off-road.
  26. Feb 21, 2019 at 2:31 PM
    Marty McFly
    Morty McBoonJug
    if I went bigger on a lift 6+ I’d go 20s and give up the dirt life LOL :anonymous:
  27. Feb 21, 2019 at 2:40 PM
    Sunnier
    Sunny
    San Diego, CA
    :censored: :crapstorm: :quickdraw: :smack::angrygirl:
    joonbug and Marty McFly[QUOTED] like this.
  28. Feb 21, 2019 at 2:42 PM
    Marty McFly
    Morty McBoonJug
    joonbug and Sunnier[QUOTED] like this.
  29. Feb 21, 2019 at 2:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If I had to guess, the 20's will be heavier. The tire will be the same with a tiny bit of additional sidewall which weighs very little. And you're replacing that with 2" more of metal wheel, which weighs a lot more.
    BestGen and GodlessPro like this.
  30. Feb 21, 2019 at 2:58 PM
    Sunnier
    Sunny
    San Diego, CA
    But it depends on which wheels. Even within same diameter, I've seen 6# difference from one model to another. Hardly anyone compares the same wheel for multiple diameters.
    Black Wolf and joonbug[QUOTED] like this.
