'18 Tundra Switchback Front Turn Signals???
Discussion in 'Lighting' started by D3Tundra, May 9, 2019.
  1. May 9, 2019 at 5:47 AM
    D3Tundra
    D3Tundra [OP] New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    Has anyone got any switchback turn signals to work on an '18 Tundra?
    I found a pair from Headlight Revolution that I am sure will work. However, they are $200. I'd rather explore other options first before I break down and buy these...
    https://headlightrevolution.com/vleds-14-18-tundra-switchback-front-turn-signal-kit/
    I also found this pair from Diode Dynamics for a much reasonable price of $60 but the way they have it presented it appears as if it will but then they have a note that states "NOTE: If the turn signal bulb for your vehicle acts as a daytime running light, HP24 Switchback LED bulbs are not compatible with your vehicle." So I'm not sure if this will work.
    https://www.diodedynamics.com/switc...0AS3Z_WAeVEMMpRTciCLQr73PH-sjgisaAqO2EALw_wcB
  2. May 9, 2019 at 6:38 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    The 18's with OEM led's turn signal isn't always on...just when activated to turn. Therefore a switchback would be useless
    Newm and D3Tundra[OP] like this.
  3. May 9, 2019 at 6:43 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
