'18 Platinum - Going From Stock 20" to Pro 18" Wheels - Question
Discussion in 'Wheels & Tires' started by superx421, Apr 22, 2023.
  1. Apr 22, 2023 at 5:43 AM
    superx421
    superx421 [OP] New Member
    2018 Toyota Tundra Platinum - White
    Hello,
    I have a 2018 Platinum with the stock 20" wheels on them. Truck is bone stock, no lift...spacers...suspension mods...etc. I do currently have 275/60/20 tires installed onto the stock rims (I believe stock is 275/55/20).
    I recently purchased a set of 18" TRD Pro Forged black wheels. Anyone have any suggestions/know what the biggest tire size I could put on these rims would be? Also, any suggestions as to wanting to push the wheels/tires outwards just a bit simply for looks...not much, maybe an inch?
    Thanks,
    Blake
  2. Apr 22, 2023 at 8:35 AM
    cowbear
    cowbear New Member
    chris
    2018 tundra platinum
    this is where i got my tire info:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    copy pasta, should check out link though for more options and pics.
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
    • 20″ rims: 275/60 R20 – one inch taller but same width as factory
    superx421[OP] likes this.
  3. Apr 22, 2023 at 8:42 AM
    seydou
    seydou Distinguished Member
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
    Without changing the wheel, the only way to get them further out is to use spacers. But then you may have rubbing issues depending on what size tire you go with. I swapped out my Limited's 20" wheels for another stock design but 18". I have 285/60 without spacers.
  4. Apr 22, 2023 at 11:42 AM
    superx421
    Thanks! That's pretty much exactly what I wanted to know. As that sits in that photo, is that stock....ie no lift, no suspension mods, no spacers, etc.?
    Thanks man!
  5. Apr 22, 2023 at 1:20 PM
    seydou
    Correct. All stock except for the wheels which came off of another Tundra. I got them off of Craigslist but do not know what model, year or trim. I bought them because I wanted 18" wheels and these match my MGM.
  6. Apr 22, 2023 at 4:24 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Forget that "max size" thread. You can fit much larger tires if you are willing to make clearance for them. My 325/65r18s (35x13) on 9" +25 rims fit with no lift and zero rub.
    You should have bought different rims if you want them more outboard...
    Look at 295/70r18 (34.3") and 285/75r18 (34.8"). These fit on your stock rims and require minimal work to keep them from rubbing. If you make them stick out farther (using spacers), more work will be needed. Or you could run a smaller size.
