18 cm trade in
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rski85, Aug 24, 2019.
  1. Aug 24, 2019 at 9:27 PM
    Rski85
    Rski85 [OP] New Member
    Currently have 18 cm with 20k miles on it. Added running boards. Liner. Bull bar small simple things. But since day one I had a shudder/vibration issue between 46-51 mph. No steering wheel wobble just whole truck vibrating. Numerous dealer visiting and no help. It’s either normal or can duplicate. I’m on a verge of trading it in for another 19 cm but this one has the trd off road package. What do you think is a good price for the new ‘19 and what should I expect for my 18 cm(4.6l). !!?
  2. Aug 24, 2019 at 9:37 PM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Check Kelley blue book for estimate trade in value..also what does the 19 tundra sell for in the dealer email about 5 dealers in the area and see who gives u the best discount trust me they will fight for ur business
    Winning8 likes this.
  3. Aug 24, 2019 at 9:43 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You’re gonna pay through the teeth on this. Seems like the dealer should replace the tires under warranty since it sounds like they cannot balance them.
  4. Aug 24, 2019 at 9:47 PM
    Rski85
    It’s not the tires. Had a different set of wheels and tires on it and made no difference. Has to be something with drive train or differential or something else
  5. Aug 24, 2019 at 10:09 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    check the u joint see if it have any play, if not check all diff fluid level, if not check all wheel bearing up, down & side to side for play, if not check rear rotor for warp.
  6. Aug 24, 2019 at 10:41 PM
    Rski85
    Everything is tight and no play. My best bet would be. Drive shaft. ? Carrier barring ? Torque converter. But it’s under warranty so I don’t want to take anything apart Myself?!
  7. Aug 24, 2019 at 11:04 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    get a drive cam and record every time you drive, get evidence, and see if toyota could fix it. if they can't use lemon law to get full refund.
  8. Aug 26, 2019 at 6:58 AM
    bigandtall
    bigandtall New Member
    Indianapolis Motor Speedway
    I bet the driveshaft threw a weight. The weights are glued on at the factor now, not welded like the old days. Happened to my recently traded in F150 after 60K miles. Had the same vibe in the same speed range. Entire driveshaft was replaced under extended warranty and it fixed it.
    mambo143 and Hbjeff like this.
  9. Aug 27, 2019 at 12:01 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    This is worth a try...
  10. Aug 27, 2019 at 12:04 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    So it's a 2018 and they can't/won't fix it? Did you take 'em on a drive so they can feel the vibrations? Seems to me this is something they should address as a defective vehicle (lemon law?)
    Brownsfanhere likes this.
  11. Aug 27, 2019 at 12:05 PM
    Rski85
    Yep drove it. And can’t duplicate or say it’s normal.
  12. Aug 27, 2019 at 12:05 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Torque converter?
    TXMiamiFan likes this.
  13. Aug 27, 2019 at 12:57 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    I have the exact same situation. I'm trading for a 2020 Pro.
    I've spent hundreds in alignments and tire balances. Got a new tire since Road Force balance said it had a hard spot (Tire Rack replaced it for free).
    Toyota says they can't duplicate it and when the can it's normal. I assure you, it's not. Sometimes it doesn't do it, most of the times it does. Feels like it's coming from the rear.
  14. Aug 27, 2019 at 1:07 PM
    Rski85
    Yep that’s why I traded mine
